Samsung 4K UN55KU6490 backlight issue
  • Forks
    • Aug 2019
    • 6
    Hey,
    I have a Samsung 55” 4K curves TV UN55KU6490F.
    The TV started flashing it's backlights on and off. On for not even a second and stay off for up to a minute.
    I pulled the back off and checked the voltages on the power board they seemed ok. I'll post a photo with them.
    I pulled the panel off and checked the LEDs when they flash on they all flash on so I don't think it's the LEDs.
    I started playing with the settings and found that when I have the backlights at 20 (scale is 0-20) the tv stays on and quickly flashes off once every couple of minutes.
    The back lights are only at 71V across both sets when they are on. When measured individually set 1 is 43V set 2 is 41V. Doesn't seem high enough to me.
    With the back lights at 10/20 (backlights off) there is still voltage on them set 1 34V and set 2 34V
    Anyone had a similar issue or have any tips?
    Sorry for the long winded message.
  • R_J
    • Jun 2012
    • 9514
    Re: Samsung 4K UN55KU6490 backlight issue
    Place your meter positive on the test point CH1, and meter negative on chassis ground, then turn on the tv, what is the voltage? it should be around 270vdc
    • Forks
      • Aug 2019
      • 6
      263V.
      A bit more playing around with it. When I get the Netflix sign in page up on it the tv acts normal. I can adjust the backlights to minimum. At max backlight I have 255v across my backlights.
      Checking the ana_dim pin from the main board with the backlights at 20 it’s 3.3 and drops by .3V each step down on the backlight. So at 19 it is 3.0V, 18 2.7V, 17 2.4V, 16 2.1V, 15 1.8V, 15 1.5V until down to 10 when it get to 0.
      So it seems it just has issues when there is no input so a blank screen.
      • Forks
        • Aug 2019
        • 6
        At a blank input screen the Ana_dim acts the same although backlights turn off when the backlights get to 18
        • R_J
          • Jun 2012
          • 9514
          The power supply is supplying the proper voltage to the led's so you likely have at least one bad led in the string.
          • Cornito
            Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
            by Cornito
            Hello Team,
            I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
            Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
            Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
            08-08-2024, 08:09 AM
          • cheebster
            iPad Pro 12.9 5th Gen Backlight Issue
            by cheebster
            Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
            Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
            Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
            The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
            Anyone...
            05-20-2025, 09:17 AM
          • soler88
            Samsung UN46H5203 backlight issue - stumped
            by soler88
            I am trying to fix this tv that has image and sound but no backlight. Replaced all led strips and each strip turns on using a led tester but do not get any backlight when the tv turns on.
            I disconnected the main board from the PS but still no backlight.
            Looking at previous threads, nothing is jumping out at me and I'm stumped.
            Here are the voltage measurements:
            ON STATE
            CNM803 on PSU from Main
            Pin 1 A13v - 13.09v
            Pin 2 OD_UD - 3.3v
            Pin 3 A13v - 13.09v
            Pin 4 BLU_PWM - 1.6v
            Pin 5 A13v...
            10-09-2024, 07:28 AM
          • kdaniel
            Samsung UE55JU6800 Issue with new backlight
            by kdaniel
            Recently bought faulty Samsung UE55JU6800 which when collected was faulty and was not turning on or at least there was jo picture on it. After taking it home and turning it on the TV was working fine.
            However, there were dark spots all around just like faulty backlight looks like. After replacing the backlight for new one, there is the same issue where black spots can be seen at the point of each led.
            Any advice ore recommendations what could be the possible issue? Could it be cheap backlight i got from china?
            Thanks in adv...
            11-03-2022, 06:12 PM
          • Cornito
            TCL 65C715 backlight issue
            by Cornito
            Hello team,
            I'm back with another topic.
            It's a 65C715 TCL tv with backlight issue.
            But the problem is a bit strange.
            When I took this tv from the marketplace backlight didn't work but picture was ok.
            Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
            Putting all back together the tv worked fine for weeks. => Contact issue??
            Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
            06-09-2024, 02:24 AM
