Celcus 48UHDSB-0/1 - intermittent shut down
  • dailewis
    • Sep 2019
    • 10
    • United Kingdom
    I've got. Celcus TV in that shuts down usually after about 45 minutes. It can then be turned back on but then shuts down in between 2-5 minutes each time.
    The backlights look like they're all lighting up however the screen when a picture is on it is very dim. I haven't stripped tv yet to check backlights with my tester.
    I have pulled all caps from the board and tested them with my ESR meter and they all appear good on the cold side.
    one thing to note is that when the tv powers up there is a high pitched whine and a faint crackling noise coming from the Vestel 17IPS20 power supply.
    It appears to be near the transformer TR200.
    I've also replaced all the F5404 diodes as a precaution.
    Any pointers would be helpful, I'm determined not to swap this PSU out if I can fix it at board level :-)
    Cheers
  • dailewis
    • Sep 2019
    • 10
    • United Kingdom
    Re: Celcus 48UHDSB-0/1 - intermittent shut down
    I'm getting 88.6V at the output filter caps (56uF - 160V).
    If I disconnect backlight, getting 140v on startup then it drops to 79.4V
    When backlights disconnected the whining stops
    • R_J
      • 9628
      I don't know the version of your power supply so post some pictures, I would suspect the small elec. caps. like C240 & C207
      • dailewis
        • Sep 2019
        • 10
        • United Kingdom
        just checked and D101 MUR460G is shorted fully both ways. Just ordered some from cpc farnell.
        I'll update when they're fitted.
          Where is this D101 located on the board? Pictures of the board will help.
          I cannot see how shorted diode will allow the TV to be working for 45 minutes then shutdown.
          • R_J
            • 9628
            Looks like the diode is in the B+ line just after the PFC fet, so it was likely a low B+ condition allowing the tv to work for a short time.
            • dailewis
              • Sep 2019
              • 10
              • United Kingdom
              Here are the pics of the board
                So that means boosted PFC Voltage is not present if the PFC Diode shorted out and the circuit does not have have PFC Voltage shutdown either to keep the cost down
                • dailewis
                  • Sep 2019
                  • 10
                  • United Kingdom
                  Replaced Diode and running perfectly now😊
                  Thanks for the explanation of what was happening.
                    Thanks for the follow-up on the repair.
                    • frica
                      • Nov 2017
                      • 37
                      • Spain
                      +1
                      • protocold
                        MacBook Pro 15" 2010 820-2850 intermittent charging
                        by protocold
                        I would like to get some help on a 820-2850 logic board with intermittent charging problem. Sometimes the battery will charge all the way and sometimes magsafe would be cycling between green and orange.
                        I have already tried replacing dc-in board, swapping good battery, swapping genuine 85w chargers. None of that helps..
                        when it is not intermittent:
                        PPVBAT_G3H_CHGR_R is 12.07v
                        when it is intermittent:
                        When the light is green, PPVBAT_G3H_CHGR_R is 12.99v
                        when the light is orange, PPVBAT_G3H_CHGR_R is 11.62v
                        data line on the battery...
                        07-25-2025, 08:18 PM
                      • max789
                        Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                        by max789
                        Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                        I made the following tests:
                        1. Disconnected the main board from Power Board = backlight works.
                        2. Connected the main board and disconnected the T-Con = backlights does not work.
                        So I ordered a main board from Ebay also BN41-02156A but from...
                        01-18-2024, 06:56 AM
                      • bpcannan
                        VIZIO M557-G0: Backlights or ???
                        by bpcannan
                        'Morning,
                        I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
                        Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
                        I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
                        I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
                        10-29-2023, 06:36 AM
                      • jesterace
                        Samsung UE49MU6400 acts dead until disconnecting backlights, then works.
                        by jesterace
                        Hi everyone I have this TV which was dead one day when I tried to turn it on. I've had the cover off and there was just a pulsating/electrical clicking/ticking noise from the PSU. I disconnected the mainboard as sometimes this works to just fire it up with backlights on? That didn't help. Same noise. Then I disconnected the backlight cable from the PSU and the TV came alive. It appeared to respond to the remote and i'm pretty sure it's fully operational when there is no backlight connected.
                        However, I am in a dilemma.
                        I tested the backlight outputs with the lights disconnected...
                        10-20-2024, 10:15 AM
                      • CDNBrewer
                        Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                        by CDNBrewer
                        Hello Everyone,
                        I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                        Symptoms:
                        • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                        • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                        • I swapped the Left and Right surround
                        08-05-2025, 09:29 PM
