Sharp Aquos LC-49CFF5001K firmware/dump
  • birchy7
    • Mar 2018
    • 25
    Please can anyone supply or point me in the direction of the above set,
    My set was stuck in standby, this set uses same boards as Blaupunkt, and indeed the firmware available from UMC got the set up & going,
    but with the wronged name splash screen 7 my main problem of having no remote control operation,
    This is due to the Sharp tv using a RF remote & not the standard IR remote as the Blaupunkt uses,
    I believe if I had the proper Sharp firmware all would be well,
    I have already tried at the Sharp support site, but with my tv missing its label from back I cant enter a serial number...
    thanks in advance
    Paul
  • birchy7
    • Mar 2018
    • 25
    Re: Sharp Aquos LC-49CFF5001K firmware/dump
    hi, I'm still struggling to find the firmware
    I have contacted UMC so fingers crossed,
    I've found out that this TV is part of the F5000 SERIES from Sharp,
    other firmware that might help would be for the following model numbers:
    LC-49CFE5002E
    LC-49CFE5001K
    LC-49CFE5001E
    cheers
    • birchy7
      • Mar 2018
      • 25
      this is a long shot, but would anyone happen to have a serial number for the above set, maybe someone have a scrap one lying in the workshop?
      this way I can enter it on Sharps website & get the firmware from there?
      cheers in advance
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
      • raileanu
        TV SHARP LC-26P50E KD186 QKITPD186WJN3 (WE015169S) need working firmware dump set
        by raileanu
        Hi.
        Please if someone help me with a functional firmware dump for this KD186 QKITPD186WJN3 (WE015169S) motherboard from TV SHARP LC-26P50E.
        I think this motherboard it is found in several models.
        What I need is firmware for the NOR chip SST39VF1682 (IC2003) and for the two EEPROMs 24C64 (IC2002) and 24C32 (IC4501).
        I am especially interested in the NOR firmware because I think it has problems.
        The TV initially came only with the red STB LED on and it did not respond to any commands.
        I checked the power supply...
        07-11-2022, 10:07 AM
      • Tamo Neko
        Request for MX25VB8035F (1MB) Firmware Dump – Asus TUF Gaming H670-Pro
        by Tamo Neko
        I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
        What Happened:
        I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.
        • I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
        • My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
        What I Need:
        • A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
        02-12-2025, 11:29 PM
      • Mephysis
        DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
        by Mephysis
        Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
        I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
        03-27-2025, 02:34 AM
      • gun4as
        Need firmware dump for LG 23MP48HQ-P
        by gun4as
        Hello everyone, I have an LG 23MP48HQ-P with a mainboard EAX65543134. After a power flicker, the monitor only shows the "No Signal" message but goes to a black screen with a brief flash when an HDMI/VGA cable is plugged in. I cannot enter the OSD menu. All main voltages (18V, 5V, 3.3V) are stable under load. I made a backup of the firmware, but it was *after* the fault occurred, so my backup is likely corrupted. I flashed it back with no change in behavior. I can only find the firmware for the 24M38H model online. Could someone please share a working firmware dump for the 23MP48HQ-P?...
        08-25-2025, 04:28 AM
