Samsung UN75MU6300 FXZA FA01 - Troubleshooting screen problems
  • SDG1855
    • Feb 2020
    I just bought a monster 75" Samsung UN75MU6300 with the hope of fixing problems with the screen. I initially thought it was just a backlight issue, as the picture darkens gradually from right to left (meaning that the far left side is super dark, and far right side is seemingly normal). Once I got it home, however, I ran some screen tests and see that there are possibly more issues.
    There seems to be a timing issue on the left side, as there are weird artifacts and transitions from one color to another leave horizontal streaks that take a few seconds to fade away. Once they catch up, the left side seems to produce the colors normally, at least to my novice eye. While there does appear to be a backlight problem in the center of the screen, it seems to be a fairly minor problem, at least relative to what I initially thought. I now suspect either the T-con board, bad connectors or cables or a completely smoked panel.
    I posted a video of the full screen test here: https://youtu.be/FpPzSDXP3LY
    I also attached a few screenshots to this post
    I would greatly appreciate any insights you guys may be able to offer, as this is actually my first TV repair project. I'll catch up pretty quickly, I hope. Worst case scenario, I wasted $80 for the experience.
    Thanks in advance,
    SDG
  • budwich
    • Jul 2015
    • 3097
    Re: Samsung UN75MU6300 FXZA FA01 - Troubleshooting screen problems
    can't see the video but my guess from the description is that the set suffers from issues with the tab bond on the side of the panel that is the darkest. You can read a number of posts in and around this type of problem. preliminary test involves disconnecting, one at a time the cabling from the tcon to the panel (done with power off of course) and then checking the resulting picture. Go from the result and some reading of the forum. IF you are fast (with disassembly / assembly) and lucky, you might be able to watch the second half of the super bowl on the 75.... :-)
    • jean luc ferre
      laptop hp g72 b52sf screen problems
      by jean luc ferre
      on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
      the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
      i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
      i don't understand the reasons of the white stripe at the bottom of the screen below the task...
      06-07-2025, 03:27 PM
    • jean luc ferre
      display screen problems after changing motherboard
      by jean luc ferre
      First on my laptop i had a motherboard with a pentium 6100 processor. Installing w11 i was blocked on the 23h2 version...impossibility to upgrade toward 24h2 because the SSE4.2 functionnality of the cpu was missing. About displaying and screen looking all was perfect.
      I changed of motherboard with an intel I3 processor...and now i don't find the previous aspects of the displaying.
      Now i have a veiled screen and pixels are missing though the graphics parameters have not changed.
      Desinstalling and reloading the drivers in the same time on the graphic card (intel hd...
      09-11-2025, 10:28 AM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
    • Chrissygizmo
      by Chrissygizmo
      02-10-2025, 12:33 AM
