LG 42LN543V one flash error code?
  • 6BW6
    • Jan 2015
    • 55
    42LN543V LED standby LED comes up then flashes once then goes out with no screen activity.
    All the voltages are up, I'm wondering if it's a main board or a dreaded LED back light problem. Anyone know the one flash error code?
    Thanks, Dave.
  • nomoresonys
    • 12331
    • U.S.
    Re: LG 42LN543V one flash error code?
    Try press and hold down the OK button on the TV panel for 15 seconds or so.
    • neilc6
      • Nov 2015
      • 1550
      LGs dont have blink codes. Backlight failure very common in LN series.
      • R_J
        • Jun 2012
        • 9625
        With the tv off, monitor the voltage on the power supply LED+ (or J14), then turn on the tv. If the voltage peaks over 160vdc, you very likely have an open led string.
        • 6BW6
          • Jan 2015
          • 55
          Ah, thanks RJ, I think you nailed it, I did just that before posting on here but wasn't quite sure what the peak was, was over 160 for sure, 180ish if I can recall..... I should have known, just didn't 'click' at all - I should have disconnected the plug and then compared.
          To do a proper job I wanna be changing the lot of em' so that means a set of strips, trouble with changing one or two of them you don't know when the other's will 'pop', two minutes ,two day's you just can't say.
          Thanks to the other posters. Dave
          • Curtissimo
            HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
            by Curtissimo
            Hi everyone.
            I have a HP Elitebook 850 G8.
            Serial: 5CG2324XM0
            ProdID 6L8D5EC#ABA
            It has a Winbond W25Q256JVEN Chip.
            I need to remove BIOS Password.
            I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
            Attached my dump.
            I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
            I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
            What I did:...
            08-26-2025, 04:42 AM
          • Grouickman
            Hofmann geodyna 6300 Wheel balancer
            by Grouickman
            Hi there,
            First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
            Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
            I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
            I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
            03-31-2025, 05:29 AM
          • bohaboha
            error code 0x80072f8f 20000 When widows upgrade to 10
            by bohaboha
            when upgrading windows 7 to windows 10 i get this error code (title).then to correct the error i have to enable tls 1.1 and tls 1.2 in registry editor. but there I do not find TLS 1.1 and TLS 1.2 instead there is SSL2.0
            in REGISTER EDITOR on windows 7 ad can one do to correct the problem?
            Error Code 0x80072f8f 20000
            08-30-2023, 07:06 PM
          • Sus256
            HISENSE 65E7KQ PRO - no boot
            by Sus256
            Hi all!
            HISENSE 65E7KQ PRO
            RSAG7.820.13512 - chassis
            MT9618BAATAB - cpu
            RSAG7.820.12059 - power
            HD650Y3U77 - panel
            KLM8G1GETF - emmc
            Replaced emmc.
            Terminal log
            UART
            AC_ON
            E-B
            FDE enabled
            06-01-2025, 02:11 AM
          • CdDvdFlash
            Hitachi HTA-DD3W AV Receiver Error Code -Protect-
            by CdDvdFlash
            I have a Hitachi HTA-DD3W AV receiver and when I got it I tested it working fine with speakers but it needed a clean inside because it had signs of moisture in it but it was fully dry with bits of wood chips, I guess this was left in a shed so I fully disassembled it and cleaned it with isopropyl alcohol very carefully, some de-soldering was also needed but now its very clean, luckily there was no rust on any components and all the capacitors are fine with no bulging. When I turn it on I hear a relay switch on then a few seconds later another relay switches on or off and the display has a "-PROTECT-"...
            07-10-2023, 06:05 AM
