error code 0x80072f8f 20000 When widows upgrade to 10
  • bohaboha
    • Nov 2012
    • 1044
    • sweden
    when upgrading windows 7 to windows 10 i get this error code (title).then to correct the error i have to enable tls 1.1 and tls 1.2 in registry editor. but there I do not find TLS 1.1 and TLS 1.2 instead there is SSL2.0
    in REGISTER EDITOR on windows 7 ad can one do to correct the problem?
    Error Code 0x80072f8f 20000
  • R_J
    • Jun 2012
    • 9625
    Re: error code 0x80072f8f 20000 When widows upgrade to 10
    Does this help?
    https://support.microsoft.com/en-us/...0392#bkmk_easy or this:
    https://ugetfix.com/ask/how-to-fix-m...72f8f-0x20000/
    • bohaboha
      • Nov 2012
      • 1044
      • sweden
      Thanks R_J I have tried the first link and this is where I find that I hag not have TLS 1.1 and TLS 1.2 on my register except there was SSL2.0 is that normal?
      • R_J
        • Jun 2012
        • 9625
        From what I read you must create the new registry keys
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8352
          What a coincidence… sorry to hijack the thread, but I got the same error code when I installed Win 7 32bit on an older laptop that I am going to use for Motorola programming. I couldn’t activate my machine and got the same error.
            • 31294
            been there on a 64bit machine.
            it's not a registry key, you need the actual code.
            i used this:
            authroot.stl
            KB3004394-v2-x64(breaks shit).msu
            KB3024777-amd64(fixes break).exe
            • bohaboha
              • Nov 2012
              • 1044
              • sweden
              i used this:
              authroot.stl
              thanks again how and where you use them here
              Explain are you kind
                • 31294
                the files are from m$
                i cant remember how i used the stl
                if TC o.k.'s it i can post them here
                • bohaboha
                  • Nov 2012
                  • 1044
                  • sweden
                  What a coincidence… sorry to hijack the thread, but I got the same error code when I installed Win 7 32bit on an older laptop that I am going to use for Motorola programming. I couldn't activate my machine and got the same error.
                  here you say that you have received the same error code but do you have SSL2.0/Client instead of TLS1.1 and TLS1.2 in your REGISTER EDITOR? and how you solved the problem very grateful if you can elaborate a little more
                  • bohaboha
                    • Nov 2012
                    • 1044
                    • sweden
                    Please STJ you have well noted that I do not have TLS1.1 and TLS1.2 in my registry except I have SSL2.0/client
                      • 31294
                      try this
                      • bohaboha
                        • Nov 2012
                        • 1044
                        • sweden
                        try this
                        i did and i get " The update is not applicable to your computer for the"K3004394 and the other one run in the bakgrund i do not se what it does but in the end no changes
                          • 31294
                          thats for win7 64bit
                          what are you running?
                          • bohaboha
                            • Nov 2012
                            • 1044
                            • sweden
                            widows 7 64
                              • 31294
                              then you probably already have a newer update installed
                              • R_J
                                • Jun 2012
                                • 9625
                                Can you do a clean install of windows 10, If you have your windows 7 activation code it will activate windows 10. If you have another hard drive, install it, install windows 10 and see if it activates with a digital license.
                                I have upgraded a few windows 7 to 10 and never saw this error.
                                There are code finders that will pull the cd code if you don't know it, but if it is an oem install that might not work.
                                • bohaboha
                                  • Nov 2012
                                  • 1044
                                  • sweden
                                  Hi everyone I do not know how to "quote" each one to answer in the same answer then I take the last one that gets R_J: I have solved the problem by doing a recover disk from a windows 10 and made an installation in the active windows 7 that has this problem code by set up in the installation disc and it went really smooth
                                  Thank you all for your help
                                  stj no it had no new update installed i installed SP1 manually since there were several second update that failed to complete
                                  If anyone has a specific question just let me know
                                  • CapLeaker
                                    Leaking Member
                                    • Dec 2014
                                    • 8352
                                    I think I am going to make a separate thread about this error activating Win7 - 32bit. I specifically need the 32 bit version in order to run certain software. So for me I don't want to upgrade that machine at all. Was hard enough to find all the drivers for it, since the laptop actually was shipped as Win8. I did find all the drivers I needed and got stuck activating it online. Anyway... weekend now and finally some sun... better grab a nice cold beer.
                                      • 31294
                                      64bit o.s. will run 32bit applications
                                      • CapLeaker
                                        Leaking Member
                                        • Dec 2014
                                        • 8352
                                        Not always. Specifically not older Motorola software.
                                          LCD LED TV Service Menu Codes
                                          TCL LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          10-31-2024, 03:58 AM
                                        • Curtissimo
                                          HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
                                          by Curtissimo
                                          Hi everyone.
                                          I have a HP Elitebook 850 G8.
                                          Serial: 5CG2324XM0
                                          ProdID 6L8D5EC#ABA
                                          It has a Winbond W25Q256JVEN Chip.
                                          I need to remove BIOS Password.
                                          I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
                                          Attached my dump.
                                          I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
                                          I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
                                          What I did:...
                                          08-26-2025, 04:42 AM
                                        • Sorrow1
                                          Intergraph TDZ 2000 mainboard post code 2F/2E
                                          by Sorrow1
                                          I try to repair an old Intergraph TDZ 2000 from 1998. It is a dual Pentum II machine based on Intel 440LX chipset. There is a non-removable bios chip named PhoenixBios B1787840. I cannot see any physical damage to the board. All caps look OK.
                                          It shows no picture and POST stops with code 2F/2E regardless whether or not any graphic card is plugged in. If memory is removed, it stops on previous code 28/17 and stars beeping. I tested both CPUs in another machine and I also use RAM from another machine.
                                          When I recorded video of POST card and played it in slow...
                                          01-03-2024, 04:13 AM
                                        • DynaxSC
                                          MSI PRO Z690-A DDR4 (MS-7D25) - stuck during boot every second time - debug code 16 & A1
                                          by DynaxSC
                                          Hi Folks
                                          I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
                                          Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works
                                          09-29-2024, 04:27 PM
                                        • saghi88
                                          looking for part number (Marking code 46BF) Case DFN8 3x3
                                          by saghi88
                                          I am looking for the part number of this component so I can order it. I cannot identify it based on the marking code; I think it is an LDO IC. Can anyone determine the manufacturer's part number from the marking code?
                                          I have uploaded images showing the dimensions and the marking code of the IC. I believe the package is a DFN-8 with dimensions of 3 mm × 3 mm × 0.9 mm.
                                          Thank you in advance for your support
                                          11-21-2025, 03:38 AM
