Sony KDL-47V5100
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    Sony KDL-47V5100
    Picked this tv up for $10. The backlight comes on as seen in the picture but nothing on the screen.
    At this point I'm thinking it's a mainboard issue.
    If needed I can take readings if you want.
    • 12323
    • U.S.
    Re: Sony KDL-47V5100
    Maybe take the shield off the tcon board and see if you have about 12 volts on each side of the fuse, black probe- on chassis ground, red probe+ on each side of fuse.
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      Yes, 12v on each side.
        What happen if you have ribbon cables between T-CON and the LCD panel connected one at a time?
        Can we see good clear pictures of the T-CON board?
        • Malachi
          • Dec 2015
          • 1077
          • Usa
          T-con.
          No change when trying either ribbon disconnected.
            Try the test in my post #4.
            • Malachi
              • Dec 2015
              • 1077
              • Usa
              Sorry. I edited my above post to say that didn’t change anything. Didn’t see you had posted again. Trying to avoid too many posts.
              • Malachi
                • Dec 2015
                • 1077
                • Usa
                Typo in the title also. It’s a KDL-46V5100
                  • 12323
                  • U.S.
                  Do you have a solid green led on the front?
                  • Malachi
                    • Dec 2015
                    • 1077
                    • Usa
                    No, just a solid red standby and amber pic off/timer led.
                    I also just noticed the backlight turns off after about 15 seconds and then come back on. It repeats that, nit sure if it’s because the shield and heat sinks are off of the t-con.
                    I will put it back on this afternoon.
                    Also it doesn’t respond to the side buttons. I have to plug it in and unplug it. I don’t hav the remote.
                    • Malachi
                      • Dec 2015
                      • 1077
                      • Usa
                      Should I toss it?
                        I also just noticed the backlight turns off after about 15 seconds and then come back on. It repeats that, nit sure if it's because the shield and heat sinks are off of the t-con.
                        Also it doesn't respond to the side buttons. I have to plug it in and unplug it. I don't hav the remote.
                        Aha, important info.
                        What happen if you disconnect HSR board connector?
                        Service manual:
                        • Malachi
                          • Dec 2015
                          • 1077
                          • Usa
                          Already tried disconnecting the buttons. I’m assuming that’s what HSR board is? No difference.
                            Already tried disconnecting the buttons. I'm assuming that's what HSR board is? No difference.
                            Nope!
                            Did you download the service manual to know where HSR board is?
                            https://www.shopjimmy.com/catalogsea...?q=KDL-46V5100
                            • Malachi
                              • Dec 2015
                              • 1077
                              • Usa
                              Yes I downloaded it. Didn’t see a reference. I did a search fir HSR. I’ll check again.
                                Look at shopjimmy link to see what the HSR look like.
                                • Malachi
                                  • Dec 2015
                                  • 1077
                                  • Usa
                                  Found it, no change. Btw, it's different than the one on shopjimmy. Only 1 connector.
                                    • 12323
                                    • U.S.
                                    Did you try a firmware update? One there says for 46V5100, did not see 47V5100, maybe recheck model number: https://www.sony.com/electronics/sup...loads/W0006532
                                    • Malachi
                                      • Dec 2015
                                      • 1077
                                      • Usa
                                      Yes I tried a firmware update. Didn’t work. I corrected the model number in post #8. I couldn’t change the title.
                                        • 12323
                                        • U.S.
                                        Ok, didn't see post 8, what do you get if you have cable from powerboard to mainboard unhooked and plug ac into powerboard? Did you try the update with a different thumb drive? before anyone says it's a sony not a samsung, just don't.
                                        • NSkyLab
                                          Sony XBR-65X900F black and white image on one side (fading saturation)
                                          by NSkyLab
                                          I though I've seen all possible kinds of failures but this one is new...
                                          Colors saturation is gradual.y fading out on the left side of the screen (all colors are fading out). While B&W image is looking good.
                                          I tried replacing TCon but nothing changed. So this is looking like the panel failure. Is there a chance it can be fixed?
                                          Any useful measured can be done on the panel's narrow pcbs? Is there may be something similar to taping trick to fix this issue?...
                                          10-05-2025, 07:37 PM
                                        • Watson306
                                          6 Red Blinking lights (left side darker) on Sony KD-49XE8396
                                          by Watson306
                                          I've got a Sony KD-49XE8396 TV that will switch on show the Sony logo then the Android logo and then switches off, and then blinks red 6 times.
                                          I've read that this is the backlight, and during it showing the initial logos I can see that the left side is definitely darker.
                                          I've also read that you can bypass the error to get it working but I'd prefer to fix it if at all possible. Any help would be appreciated.
                                          Many Thanks in advance.
                                          11-01-2022, 05:33 AM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • ptcriserx3
                                          Sony trinitron crt bowed and side color issues
                                          by ptcriserx3
                                          Hi
                                          Ive got a vintage 2001 sony trinitron flat tube tv
                                          The image is slightly bowed and the left and right sides about 1-2in has fluctuating discoloration that comes and goes if i move or hit tv on sides
                                          See many images attached...
                                          Just windering if this is not fixable or something i can correct without getting too invloved
                                          Im trying to sell the tv
                                          06-17-2023, 07:27 PM
                                        • flibidy
                                          Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                          by flibidy
                                          I have here a Magnum IA.100 which belongs to my parents.
                                          The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                          Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                          What Ive done........
                                          01-01-2025, 01:26 PM
