Samsung UE55ES6800 - Vertical Lines (moving)
  • Billsy
    • Oct 2018
    • 53
    • United Kingdom
    Hi all
    I picked up a UE55ES6800 with bad colours to the whole screen and some faint lines on the left side. I found a burnt COF tab on the left/bottom so removed all the left side tabs. This fixed the colour issue but the vertical lines remain. The lines only appear in conditions where there's a bright object in the lower left corner area. All connections are clean and secure. I guess this is either a side effect of removing the tabs or there's a bad bond on the bottom edge? What do you think? Is there any hope for this panel?
    Many thanks
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4452
    • Italy - Milan
    Re: Samsung UE55ES6800 - Vertical Lines (moving)
    I think.you have to try reflowing the fartest tab's cof chip with the soldering iron gently under it on the amber side of.the tab.
    • Billsy
      • Oct 2018
      • 53
      • United Kingdom
      Thanks Davi.p but the TV is now stripped for parts.
      Saluti
      • Stanley1843
        by Stanley1843
        06-29-2024, 11:54 AM
      • x_orange90_x
        Samsung UN46C8000XFXZA vertical bars/horizontal lines
        by x_orange90_x
        I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
        The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
        09-04-2023, 12:09 PM
        09-07-2024, 05:50 AM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • Anonmis
        Samsung 55" UN55JS9000 - Pink vertical lines due to chipped LCD panel?
        by Anonmis
        Hello all, I was recently repairing my Samsung 55" UN55JS9000 tv from the common burnt backlight LED's and cracked light guide panel issue. After replacing the LED's and putting the TV back together, I tested the tv and all I was getting was sound but no image. Somewhere along the way (could be related to the next issue) the T-Con board became damaged and after replacing it I have made a little bit of progress but now have bright pink vertical lines and still no image.
        The bigger issue .... I took the TV apart again and realized that I likely didn't sit the LCD panel correctly...
        12-01-2023, 04:31 PM
