Samsung UE49MU6170UXZG not power up
  • Japanac
    • Aug 2014
    • 94
    • Serbia
    Has anyone had experience with a Samsung UE49MU6170UXZG that will not power up?
    No standby led, no sound, blank screen - dead.When you disconnect the system board backlight is running.
    Motherboard:BN94-1239C
    Powerboard:L55S6R MHS BN44-00807F
  • nomoresonys
    • 12222
    • U.S.
    Re: Samsung UE49MU6170UXZG not power up
    If "backlight is running with mainboard disconnected" means the backlight stays on, then suspect mainboard as the problem.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8290
      Main board failure like nomoresonys said. Look for a replacement main board, unless you are willing to try your skills to change the main IC.
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • mrtek
        Samsung UN43NU6950FXZA No power
        by mrtek
        Hi
        Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
        Main fuse = OK
        Back light LED = OK. Power them with aux power source
        LED output = OK 156V
        I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
        Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
        07-20-2025, 08:06 PM
      • hill01
        Samsung UE75MU7009TXZG Endless Power Cycle
        by hill01
        Hi everyone and thanks in advance for any help I might get here
        My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
        About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
        Since a few days, the TV won't turn...
        11-17-2021, 02:52 PM
      • Journey11
        Samsung TV won't turn on ... keeps cycling the power relay on & off
        by Journey11
        Hi All,
        First time posting here ... my name is Kevin but my friends call me Journey.
        I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
        After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
        It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
        07-04-2024, 02:44 PM
      • cheeky2
        Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
        by cheeky2
        This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
        I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
        Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
        06-15-2025, 05:12 AM
