Samsung UE55NU8000T Main Board GB only???
  • Billsy
    • Oct 2018
    • 53
    Hi All
    I sent a main board BN94-12926P to a chap in Italy. He has installed it and done a factory reset using the service menu. At initial setup, the only country options are Ireland and GB. Is there a way for him to change to Italy?
    Many thanks
    • 22119
    Re: Samsung UE55NU8000T Main Board GB only???
    Maybe flash the firmware .
    • yokoono
      • Apr 2010
      • 511
      It doesn't even work with software rewriting.
      Maybe with constructive changes but it is very complicated. Another motherboard.
      • Billsy
        • Oct 2018
        • 53
        OK thanks very much for your help
        BR
        • William1967
          • Nov 2017
          • 217
          • Netherlands
          Enter the service menu via a service remote, enter OPTION and select LOCALSET, set it to the correct country and do a FACTORY RESET. When installing the TV again the correct country will be selectable.
          • Billsy
            • Oct 2018
            • 53
            Brilliant thanks William. I just confirmed that Italy option is present on a set here. I'm using the "smarttv rc" app to enter the advanced service menu
            Thanks again
            • Asraf Atb
              Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
              by Asraf Atb
              Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
              Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
              I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
              01-27-2025, 05:02 PM
            • mrautom8
              Samsung TV UN75H6350AFXZC main board schematics?
              by mrautom8
              Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
              Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
              While relay is on, all voltage rails are present and steady (scoped) on main board.
              I love a good logic puzzle but getting lost without any schematics.
              No shorts on ANY capacitor main board.
              Thermal camera shows 3.3V inductor getting warm instantly but...
              10-19-2025, 06:32 PM
            • Dani_2024
              by Dani_2024
              10-28-2024, 05:06 PM
            • ygorsan
              by ygorsan
              🧩 Problem Summary:
              • I
              07-28-2025, 08:34 AM
            • Lee M.
              Samsung UN75RU8000FXZA bad main board?
              by Lee M.
              When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
              11-08-2023, 07:46 PM
