Pioneer Trap Switch
  • csmith
    • Aug 2014
    • 46
    Pioneer Trap Switch
    Have a PDP5071U which was originally giving me 8 blinks. Forgot to tape
    the trap switch now solid red and blue lights. How do you disable the trap
    shutdown when the set won't stay powered up long enough to access the
    service menu? Thanks
  • R_J
    • Jun 2012
    • 9623
    Re: Pioneer Trap Switch
    Not sure if this will work but it's worth a try
    1. Press the display button then release the display button.
    2. Wait between 3 and 7 seconds
    3. Press and release the <, ^, <, >, and power buttons in sequence.
    Panel will now turn on in service mode.
    4. Press muting button 3, 4 or 5 times depending on model you are working on.
    Until the display shows the initialize page.
    5. Press and hold the display button until the error indicator (red LED) on
    either the panel or the media receiver goes out.
    6. Exit service mode by pressing the power button on the remote.
    • csmith
      • Aug 2014
      • 46
      Thanks but i have tried that. The original shutdown problem is keeping
      out of the service menu!
        Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
        This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
        09-06-2024, 05:30 AM
      • Natob82
        Micro Momentary Push Switch?
        by Natob82
        Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
        12-21-2022, 05:22 AM
      • SluggerB
        Help making a switch work the opposite way with a relay
        by SluggerB
        I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
        I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
        It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
        02-07-2025, 07:57 PM
      • janos666
        Pioneer LX5090 - 2x Red blink after auto-shutdown
        by janos666
        I was trying to reset the Pulse Meter and re-adjust the Panel-1/2 settings in the SM on an exceptionally old Pioneer LX5090 (51k power-on hours according to it's SM). I did this many times on much less aged specimens (with 10-20k hours) without issues. After following the usual workflow, I noticed the darkest gray shade showed up black with bright sparkles. I tried to adjust some other parameters but it didn't disappear. Then I went on and restored the old values of the parameters I don't usually touch (although I did this from memory, so I might have made an error). After that, I started going...
        03-26-2023, 11:20 AM
        Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more cams
        Panel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
        ( needs more cam circuits for the machine to work correctly again )
        https://www.ebay.com/itm/275321870186
        To
        3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
        ( not 4 positions but the right amount of cams circuits )
        https://www.ebay.com/itm/274660439950
        I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around...
        03-18-2023, 05:12 PM
