LG 55EC930V black screen
  • xmandarkx
    • Dec 2013
    • 54
    hi all, thought i would start a new thread and see if i can get this sorted.
    I bought an LG 55EC930V for £50 at the weekend, i was told it was clicking and it went off, repair guy came out, hairdryered something and got it back on then fiddled with the relay and broke it.
    i have replaced the relay and have done all the tests suggested in the other threads i found and am getting all the correct voltages where and when they should be there. I am certain the fault is not on the power board.
    now i am stuck again and need some direction, when i press the power (tv or remote) i get a click and the lg logo glows for about 3 seconds then turns off. i have a service remote and using power only the tv comes on and stays on but i have seen no life from the panel.
    is there a way to test the panel somehow? im thinking my issue is T-CON or dead panel, i would like to rule out or confirm the panel before spending any cash.
    Thanks in advance.
  • Diah
    • Feb 2013
    • 6437
    Re: LG 55EC930V black screen
    list over here all voltage on socket 201 & 202 when the set remain on.
    also read the voltage on the T-CON F1 fuse from both side.. remember the reading of all voltage i mentioned the black probe of your DM on the TV chassis.
    • xmandarkx
      • Dec 2013
      • 54
      voltages when poweronly is active
      p201
      1. 3.42v
      2. 2.7v
      3. 3.54v
      4. 0v
      5. 3.54v
      6. 3.4v
      7. 0v
      8. 0v
      9. 24.5v
      10. 24.4v
      11. 0v
      12. 0v
      13. 11.7v
      14. 11.7v
      15. 11.7v
      16. 24.4v
      17. 0v
      18. 0v
      p202 GND is 0v
      24VD is 23.8v
      • Diah
        • Feb 2013
        • 6437
        how about the T-CON F1 fuse ?
        BTW when you turn the set with power only.... don't turn it off with RC. just plug it out from wall socket .... the next time when you plug it in again it should by pass the last state shutdown and acting to start on and remain on..
        if you reached this step andf your T-CON F1 okay read 12V on both side... plug airt mouse at any usb port and other usb drive put on its root any mp4 file. to wake up the set from deep sleep lock.. give eyes on screen always it you can see white color some where.
        • xmandarkx
          • Dec 2013
          • 54
          Sorry F1 fuse is 11.7v on both sides
          • Diah
            • Feb 2013
            • 6437
            do the air mouse and usb mp4 file test at dark room and report the result.
            • xmandarkx
              • Dec 2013
              • 54
              Do i need to try and click the mp4 file or just have it on the usb stick?
              • Diah
                • Feb 2013
                • 6437
                moving the mouse over and make many right or left click enough to wake it up... in case its blocked.. but do it in dark room to trace any light on screen
                • xmandarkx
                  • Dec 2013
                  • 54
                  right i an getting some light on the screen in both top corners. it doesnt meet in the middle and it is curved, not a block.
                  i can only see it in total darkness.
                  • xmandarkx
                    • Dec 2013
                    • 54
                    if i plug an hdmi cable from pc the computer detects the tv
                    • Diah
                      • Feb 2013
                      • 6437
                      try and follow this points one by one...
                      1- check if you have sound
                      2-trace the 24 V on the screen driver ( the left site of the T-CON where the 24v pin in )
                      3- use yours service remote and send command ( IN_STOP ) to reset the eeprom and the main boards to factory condition
                      4-tray with air mouse and usb mp4 file again and again..
                      • ducky29
                        • Dec 2015
                        • 369
                        • Europe
                        What does this test consist of? Is this something new?
                        • Diah
                          • Feb 2013
                          • 6437
                          nothings New.. i used this method to wake up the set always on LG OLED
                          read this threat post 45 & 46
                          • xmandarkx
                            • Dec 2013
                            • 54
                            None of that seemed to work, im still stuck with a black screen
                            • nomoresonys
                              • 12276
                              • U.S.
                              Well maybe hairdryer it yourself see if it starts up, do the powerboard first, you might just have a faulty cap, test your diodes too if you have not yet, did you notice which board he heated?
                              • xmandarkx
                                • Dec 2013
                                • 54
                                no idea what was heated. the powerboard is fine though it was well tested. might try and heat up the T-Con board as i think thats where the problem is. wish there was a way to bypass everything just to get the screen to light up or something so i can rule out a bust panel.
                                • Diah
                                  • Feb 2013
                                  • 6437
                                  did you trace down the 24V on the T-CON driver boards.. F70 from both side... also you have on the down side of the bards groups of FL need to check them too from both side ( some time one go to high resistances) not open...
                                  yours point now the 24 volts.. would be good if you take out the T-CON out side the set.. and feed it with external 24 Volts to trace it especially the first ribbon socket ( on the left side if you look from rear side of the set ) the first groups pin are power feed you can read the voltage of them.. if you nt sure just upload photo of the board to remark them
                                  • xmandarkx
                                    • Dec 2013
                                    • 54
                                    thanks, im away for a couple of weeks but will try that when i get back. i will respond here once ive tried it
                                    • HTR-Informatique
                                      Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                                      by HTR-Informatique
                                      YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                                      I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                                      On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                                      I also changed the screen because the PC fell and the screen was broken.
                                      I changed the battery with a new and original battery.
                                      I also had corrosion/oxidation on the...
                                      02-09-2025, 06:51 AM
                                    • howardc64
                                      by howardc64
                                      Problem
                                      08-04-2024, 10:36 PM
                                    • VcemPzd
                                      Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                      by VcemPzd
                                      Hello everyone !
                                      My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                      04-28-2025, 10:14 AM
                                    • DaniK
                                      Acer Aspire E5-574-52RH - black screen
                                      by DaniK
                                      I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                                      Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                                      Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                                      Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                                      The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                                      Symptoms are:
                                      - random black screen after displaying Acer logo...
                                      02-21-2024, 06:27 AM
                                    • Rensiee
                                      Panasonic TH-50PX8EA Black screen, only relay clicks
                                      by Rensiee
                                      I have been reading a few threads on here regarding Panasonic plasma tv's. I've found one thread which explains the same problem as mine, unfortunately the thread has not been completed.
                                      I got a free tv (TH-50PX8EA) from a friend which shows no screen. When plugged in only one red light shows up and when pushing the ON button, the red LED turns of and will only turn on again when pressing the ON button again.
                                      When plugging in the TV i hear two relays click fast and after a few seconds the third relay clicks.
                                      I have measured the voltage in the VSUS line, which...
                                      06-18-2024, 12:58 PM
