Toshiba 55L7453D - Vertical Lines
  • Billsy
    • Oct 2018
    • 53
    • United Kingdom
    All the best everyone
    Can anyone help with my first Toshiba repair?
    Was getting a good picture for a few seconds. I have successfully repaired the backlight and when re-assembled, was just getting funky shapes on the screen so gave all the ribbons a good clean and now there's no picture just vertical lines. I've re-cleaned the ribbons a couple of times with no effect. removing the tcon-panel ribbons just blanks the respective side of the display.
    Any tips for these sets?
  • Billsy
    • Oct 2018
    • 53
    • United Kingdom
    Re: Toshiba 55L7453D - Vertical Lines
    Can anyone point me in the right direction for this fault?
    • R_J
      • 9588
      You likely damaged the panel. either damaged one of the tab bonds, or maybe damaged the cof (chip on foil) You may have even damage the panels ic's with a static discharge.
      • Billsy
        • Oct 2018
        • 53
        • United Kingdom
        Many thanks RJ
        • budwich
          • Jul 2015
          • 3097
          the first picture appears to show "damage" that results from panel issues related to signals coming from the tabs at / near the bottom in that corner. As suggested by RJ, it is possible that the handling of the panel caused damaged. You might want to check around that area to see if there is any obvious damage but also check to ensure that there isn't any metal frame pieces touching the boards / panel areas where they should not be... this could be the result of "poor" assembly effort.
          • Billsy
            • Oct 2018
            • 53
            • United Kingdom
            Thanks for the help guys. I had another poke around and found the culprit. The ribbon that sits between the main board and whatever the central board is, needed recleaning. I must have introduced some muck first time round. Now works perfect
            Thanks again
            • Stanley1843
              by Stanley1843
              06-29-2024, 11:54 AM
            • visionbluedemon
              Help. Sony kd-65x85dj vertical lines
              by visionbluedemon
              First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
              Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
              tried blocking LC lines too, but same results
              is it lcd panel issue or tcon board issue?...
              07-25-2025, 04:56 AM
            • oxi1158
              Toshiba TV 55L6200U horizontal lines + vertical bands. Any hope?
              by oxi1158
              My TV had been showing for the last year some faint horizontal lines on all of its right side, about one out of each 4 of 5 rows of pixels. Not much of a bother, they were unnoticeable when watching a movie. Then, all of a sudden the horizontal lines became much stronger and crossed the whole screen, effectively making it a pain to watch.
              I watched some youtube video where some guy "fixes" it with some tape on the ribbon cable of the t-con, so I tried that, but to no avail. Actually, after putting the TV back together again things worsened: apart...
              10-09-2020, 08:37 PM
              09-06-2024, 05:27 AM
            • gpo23
              Sony KDL-40V3000 - Vertical lines
              by gpo23
              i order a t-con because i had bad colors on my SONY KDL-40V3000 :
              With the new t-con the color are good but there are vertical lines on all the screen :
              I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
              Is there a way to fix the vertical lines on the new t-con ?
              Thank you for your help
              gpo23...
              10-04-2023, 09:11 AM
