LG 55LS4600 powers on with backlight no image
  • woodman45
    • Aug 2015
    • 87
    • U.S.A
    LG 55Ls4600 as title says,powers on back lights are on no image.
    Are there any tests I can do?
    Is the main video board possibly bad?
    Also to mention there is sound just no video.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: LG 55LS4600 powers on with backlight no image
    There's a fuse on the tcon to check, measure for 12v each side of it.
    • woodman45
      • Aug 2015
      • 87
      • U.S.A
      Where is the fuse at on the tcon board
      • nomoresonys
        • 12123
        • U.S.
        Fuse is labeled F1 2A/125v, black negative probe on chassis/metal ground. red positive probe on each side of fuse.
        • woodman45
          • Aug 2015
          • 87
          • U.S.A
          Yes 12v on each side.
          • woodman45
            • Aug 2015
            • 87
            • U.S.A
            Thanks. Yes 12v on both sides.
              What do you get on the screen if you have only one cable between T-CON and LCD panel connected one at a time?
              • yokoono
                • Apr 2010
                • 481
                Measure the voltages circled in red and post the values found.
                • woodman45
                  • Aug 2015
                  • 87
                  • U.S.A
                  Left connector in pic did nothing,right connector unplugged showed half screen.
                  • woodman45
                    • Aug 2015
                    • 87
                    • U.S.A
                    The reading on vcc18 is 1.8
                    Vgl reading is -6.91
                    Vgh reading is 0.00
                    Vod reading is 0.19
                    • yokoono
                      • Apr 2010
                      • 481
                      You have problems with the part where there is no image. Connect the defective part and measure the resistance at the VGH point. You can compare with the good side.
                      L.E.
                      It's a short on the VGH rail. You can leave the good side coupled and measure VGH. It can be a short or resistive smd cond, a diode or, worse, the panel.
                      • woodman45
                        • Aug 2015
                        • 87
                        • U.S.A
                        L.E.
                        Those readings are with both sides connected.
                        I found a tcon board for $20, I think I'm gonna get it and if I get the same results is it safe to say the panel has a short?
                          It can be as simple as shorted out caps on the tab bonding board of the bad side.
                          • woodman45
                            • Aug 2015
                            • 87
                            • U.S.A
                            Should I get the tcon first?
                              I would start checking the caps first, you do want to damage T-CON board if you have shorts circuit on the tab bonding board.
                              • woodman45
                                • Aug 2015
                                • 87
                                • U.S.A
                                Thanks budm. Which caps should I check on the tab bonding board?
                                I have searched on internet but I can't find much info.
                                Any insight is greatly appreciated.
                                  All the SMD caps on the tab bonding boards, you need to check for very low resistance reading.
                                  You do know what the tab boding boards are, correct? You need to remove the LCD frame to get to the tab bonding board.
                                  • woodman45
                                    • Aug 2015
                                    • 87
                                    • U.S.A
                                    I'm assuming the tab bonding board is the board on the bottom that connects into the panel.
                                    With SMD caps how do you read the resistance?
                                      No power to TV, set meter to Ohm mode, 200 Ohm scale, then just check the resistance between the two legs of each cap.
                                      • woodman45
                                        • Aug 2015
                                        • 87
                                        • U.S.A
                                        Thanks again budm. I found a video of a guy with similar problem and it was a smd cap on the panel driver board.he shows how to get to it and do the tests.
                                        I will get back and report my findings.
                                        • Max514
                                          Samsung UN55H8000 sound but no backlight no video
                                          by Max514
                                          Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
                                          The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
                                          I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
                                          • Unplugging the main board cable at the power supply >>> backlights came on.
                                          • BLU_ON signal from the
                                          04-14-2022, 10:34 AM
                                        • Salem Aboshala
                                          820-00138-A got image but no backlight
                                          by Salem Aboshala
                                          Dears, this is my first post here and first try to fix my own laptop Apple MacBook Pro Retina 15-inch Mid 2015.
                                          I have some general electronics troubleshooting experience and still as my hoppy but this is my first laptop trying to fix.
                                          History: my laptop backlight stopped working without any reason.
                                          Symptoms:
                                          I have image on screen using my flashlight.
                                          I have fully working laptop with the help of my external SAMSUNG LED tv via HDMI cable.
                                          Keyboard backlight still working and can be adjusted normally.
                                          Since two days I tried to follow all similar...
                                          06-11-2024, 03:02 PM
                                        • zaurus81
                                          Yashi All in one model AY62409 (Quantum S 24'') no image (backlight works)
                                          by zaurus81
                                          This chinese all in one computer gives an image when connected to an external vga monitor but only the backlight with integrated monitor (no image). Initially I thought it was an edid problem on the eeprom of the screen but then I saw that the monitor works correctly with another identical motherboard (model th410-d4, read by bios). Unfortunately the motherboard is chinese and has no brand or codes on the pcb. The format seems ITX. Nothing can be found online. The official yashi site provides drivers but not the bios. The electrical diagram is obviously unobtainable
                                          The board is equipped...
                                          01-16-2025, 03:54 AM
                                        • Constantinos
                                          Macbook Pro A2442 820-02098 No image but has backlight
                                          by Constantinos
                                          Hi all
                                          I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
                                          He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
                                          Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
                                          Obviously, he decided against this and gave it to me so that I could have a crack at it.
                                          From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
                                          08-24-2024, 09:48 AM
                                        • ajgae
                                          HP Pavillon x360 14-ba174nz no image no backlight, LCD_VCC low (2.25V)
                                          by ajgae
                                          Hi everyone!
                                          First post on here so do tell me if i'm doing anything wrong. I have a laptop that came in with a broken hinge, but a healthy LCD. We replaced the LCD rear cover and now we do not get an image on the LCD anymore, though we get one via HDMI. There is sadly no schematic or boardview available for this motherboard (Bucks U42 DIS 17817-1) as far as i can tell, but I was able to identify which of the important pins on the LCD eDP connector (30 pin 2 lane) correspond to which pins on the motherboard display connector (which is 40pin, 30 for LCD and 10 for camera/face rec etc)...
                                          03-06-2025, 09:53 AM
