Samsung TV Model LN46C360K1FXZA vertical lines in picture
  • bfortune206
    Burkes
    • Sep 2015
    • 23
    Problem has been narrowed down to the main board BN94-2701G. Problem is I have not been able to find one. Can someone recommend a replacement for this module that might have fixed all the problems in this module. I have been told this module has been a major problem with TV. Thanks
    • 12331
    • U.S.
    Re: Samsung TV Model LN46C360K1FXZA vertical lines in picture
    Can you verify the model number?
      • 12331
      • U.S.
      • bfortune206
        Burkes
        • Sep 2015
        • 23
        Model No. LN46C360K1F Mfg.2-2010
          Can we see the screen shot of the image on the screen?
            • 12331
            • U.S.
            It's not LN46C630K1FXZA?
            • JJAAMM
              by JJAAMM
              Problem
              07-06-2023, 06:01 AM
            • Falki
              Colorful LCD Vertical Lines on Samsung ue55es8090
              by Falki
              Hello there, ive recently found an older 55inch Samsung SmartTV.
              A similar issue has been posted as well but also with no actual response ...
              08-12-2025, 04:19 AM
            • TR103
              by TR103
              - it keeps rebooting
              01-22-2025, 04:12 PM
            • noisykid
              Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
              by noisykid
              5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
              12-30-2024, 07:15 PM
            • afex
              Samsung Plasma TV with vertical lines (model PN50B430P2D)
              by afex
              This is my 2nd broken TV I'm trying to fix and haven't been able to figure out... currently going without any working TVs so am hoping to be able to fix one..
              This Samsung PN50B430P2D Plasma has this big block of vertical lines which will fade in shortly after turning the TV on. The lines will sometimes flicker a bit or fade in/out and sometimes it just stays present. The length of time it takes them to appear varies, sometimes its a few minutes and other times it appears immediately after powering on.
              I have attached an image of the TV with these bars displaying....
              11-08-2021, 09:23 PM
