LG Korean message
  • itelite
    • Aug 2016
    • 124
    LG Korean message
    LG 60UJ6300
    Anyone have any ideas on this one? Had HDMI no signal issues, swapped out main board. Now it boots to this odd message with a sleeping bird and in korean "Press ok on remote control" All buttons on 3 different remotes do nothing.
    Firmware IC is an EMMC BGA that i would rather not mess with.
    https://i.imgur.com/5H5M09G.jpg
  • neilc6
    • Nov 2015
    • 1550
    Re: LG Korean message
    Did you make sure you plugged in all the connectors back into the main board. You may have missed one. Is there a multi-way toggle switch? Try pressing that. Factory reset is done with a factory remote (with instop button and 0413 password). If you have a smartphone with IR, you can download an app. But seems like your IR sensor may be disconnected.
    • Diah
      • Feb 2013
      • 6563
      on LG Opera system this show when there are no LAN or WLAN connection.. and on Hisense show dog with Zzz .. but the question why its show in korean not english..
      • petehall347
        • Jan 2015
        • 4448
        • itelite
          • Aug 2016
          • 124
          You were 100% correct. Ribbon cable for IR/power button was just barely in crooked. Fixed that, then everything worked as expected. Wont make that mistake again....
          • rumpumpel1
            T490 error message 2203 Skip acknowledgement of an error message
            by rumpumpel1
            I have a T490 that displays the error message “2203: System configuration is invalid” immediately after the Lenovo logo every time it boots up.
            This message must be acknowledged with 'Esc'. On the one hand, I cannot eliminate the problem, on the other hand, I have not observed any other restrictions.
            Is it possible to change the BIOS so that this message no longer has to be acknowledged?
            MTM 20N3S19L00
            system SN PF1X4JP8
            board SN L1HF171000X...
            01-19-2025, 03:32 PM
          • Prabuth
            always showing this message AC adapter = Unknown
            by Prabuth
            The customer gave me this for changing the old battery, and then I replaced the new battery. always showing this message. I changed many chargers and programmed the new BIOS as well. Does someone have any idea for this message?
            08-28-2025, 01:26 AM
          • Scruit
            Does the Oak OTI067 have a splash screen / initialization message at bootup?
            by Scruit
            tl;dr ... Question: Does the Oak OTI067 have a splash screen / initialization message at bootup?
            More detail:
            Working on "Uncle Sherman", my Mitsubishi MP-3200 386 from 1988. Before I start up old computers I have a process where I disassemble, test for shorts, visually inspect, capture EPROM images etc.
            My T866II+ give me a "pins not detected" error on the EPROM from the Oak-based (OTI067 GPU but apparently a no-name card??) I assumed the EPROM was bad, ordered a replacement and figured I'd program a downloaded ROM image to it....
            04-17-2022, 06:03 AM
          • Francesc V.
            Technics SA-AX530 in protected mode. Overload message
            by Francesc V.
            I got a request from a friend of mine to have a look to his amplifier. When switching on "OVERLOAD" was displaying, however from time to time, message disappears and protection was removed.
            I took some time in visual inspection (no bold caps, no solder joins, no burnt components neither hot burnt areas). I took some time to measure transistors and diodes. Everything seemed ok.
            I realized that when OVERLOAD was on, pin 13 on IC601 (RSN307M44A-P) measured 5V. From time to time, when Amplifier was not protected pin 13 measured the right -1.5V
            (Pin 13 goes through...
            11-18-2024, 12:39 AM
          • tcpip
            IdeaPad 5 15ARE05 Possible BIOS message and doesnt boot
            by tcpip
            My Lenovo IdeaPad 5 15ARE05 only 2 years old shows this message when I start it:
            BIInializeLibrary failed oxc0000185
            then it doesnt boot and i have shutdown by holding the power button
            I did goodle but canot undertand what is wrong and where to start. I have reset bios and also upgraded to newer bios but it didnt make a difference.
            sometimes it boots to wondows but very often I it get the above message?
            03-19-2023, 10:18 AM
