Toshiba 37E200U gets power but no pic and no sound. No 12V and No 24V
  • AxelSpott
    • Nov 2019
    Hi and let me prematurely thank you for taking some time and looking at my post lol.
    What it does: Green LED turns on and optical audio port does light up red when powered on.
    It does get 5V standby out from power supply board to main board.
    Also no fluctuations on voltage regulator readings.
    What it doesnt: make any audible cue that its been turned on
    Get any back light or sound
    Show any 12V or 24v signal from power supply.
    Absolutely no bulging caps or any sign of them being off or burnt. What do i check for this lack of 12v and 24v?
  • ngth82
    • Jul 2015
    • 541
    Re: Toshiba 37E200U gets power but no pic and no sound. No 12V and No 24V
    Hi AxelSpott -
    Can you post a clear picture of your TV SMPS board? What is the SMPS board model number?
    Disconnect the power cable between the SMPS and the main board. Measure the resistance of +12V & +24V pins relative to ground, are they shorted out to ground?
    On the cold side, there should be some rectifying diodes, are any of those diodes shorted when you test them with your DMM in diode mode?
    If you can identify the PS_ON signal, can you jump it with a 100k resistor between +5V_STBY and the PS_ON pin? Does this make the +12V/+24V turn on?
    -Thomas
    I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
    • R_J
      • Jun 2012
      • 9588
      Also use the search▼ above, there are a few other threads on this model.
      Check if you have PWR voltage on P802 pin 13. It should be around 3.6 volts
      • nomoresonys
        • 12268
        • U.S.
        Can you post a good clear straight shot picture of your powerboard, and a good shot of P802 where connector goes?
        • AxelSpott
          • Nov 2019
          Hi everyone and thank you for the replies, i had a late Thanksgiving trip i was on. Do i need to post a new thread to upload my pics or is there a way to post them to the comments here?
          • ngth82
            • Jul 2015
            • 541
            Add a new post to this thread. Do not start a new thread.
            Attach photos, do not insert a photo into the post. Look at the Manage Attachments button. You should see this if you click on the "Go Advanced" when you want to reply.
            -Thomas
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
              03-31-2024, 02:12 PM
            • jord4231
              Toshiba 37AV500A Regza TV good power supply no sound no picture
              by jord4231
              Hi Everyone,
              I'm working on a Toshiba 37AV500A Regza TV.
              The issue:
              TV was working picture and sound went out. Green stand by light stayed on, It will respond to the power button being pressed (goes in and out of standby)
              The TV will very intermittently work for around 40 mins then stop. This doesn't seem to matter if its hot/cold unplugged for a while etc.
              I checked the PSU voltages and everything looked good.
              No bulging caps or signs of heat.
              24v aud = 24.41v
              12v = 11.98v
              5v = 5.062
              p_o/f = Goes high...
              03-29-2022, 09:21 PM
