SAMSUNG T-CON S120APM4C4LV0.4 faulty
  • bohaboha
    • Nov 2012
    • 1017
    • sweden
    Hi all is this T-Con faulty ? i did same nesurement and there is i think 2 resistor on pics no:13 and 14 looks not ok all the other have
    a good value .please some help thank you
    • 12330
    • U.S.
    Re: SAMSUNG T-CON S120APM4C4LV0.4 faulty
    What does the component descriptor start with, C or R or other? it looks like you have a capacitor there.
    • bohaboha
      • Nov 2012
      • 1017
      • sweden
      Hi 4R7 on them no other letter or number
      • bohaboha
        • Nov 2012
        • 1017
        • sweden
        Hi again no sorry nothing i can read on them even looking whith microscope
        • bohaboha
          • Nov 2012
          • 1017
          • sweden
          Hi there is an inscription under :CD64 and CD74 can this help
            • 12330
            • U.S.
            I meant the writing on the board next to the component.
              • 12330
              • U.S.
              I think those are capacitors, check them for very low ohms, meter in ohm mode.
                Tan/light brown color components are ceramic cap, MLC type. Check them with Ohm meter to see if they low resistance readings as suggested.
                • bohaboha
                  • Nov 2012
                  • 1017
                  • sweden
                  Hi Whith the T-con apart and blak to ground i have a vary flowting resolts:from 00.6 to 01.0 and then down to 00.4 with 200 ohm on the meter.compare to the other 2 cap ,MLC type in the botom of the same side they are more stabile from 180.2 directly down to 00.4
                  not floating.if i have to test some more things please let me know thank you
                    How about Ohm reading directly between the two legs of the caps?
                    • bohaboha
                      • Nov 2012
                      • 1017
                      • sweden
                      with the meter on 200 ohm nothing att all .on my meter i have allways 1 from start and it is what i get
                        Showing '1' on the meter means the resistance is higher than 200 Ohms, so the caps are not bad at this point.
                        So what is the TV not doing with this T-CON board?
                        • bohaboha
                          • Nov 2012
                          • 1017
                          • sweden
                          i have a pictures to explain .in an other treat someone recomended to reflow the processor on the mainborad but i want to be shure that the T-con is ok first if i you can help me i ll be very happy.there no possibility to add a pictures on quick reply?
                          the hall screen have vertical lines but there is sound and pictures
                            09-07-2024, 05:50 AM
                          • netgearnetgear
                            TCL 43S423 TCON OR PANEL FAULTY???
                            by netgearnetgear
                            Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                            08-20-2025, 06:04 PM
                            09-06-2024, 11:40 PM
                            09-06-2024, 08:40 PM
