LG 42" 42LD550 start up.
  • Pukehead
    • Nov 2018
    • 25
    My LG 42 LD550 started to glitch out. The screen flashed every 15 seconds like it was getting a bad signal. I turned it off and it would not turn back on. The red led just pulses. There is a blue led in the top corner, seen with the cover off, that lights up and then goes off. These are the voltages i recorded on the connector.
    NC 0.1 / Error 2.3
    12v 12.3 / P-dim 2.7
    12v 12.3/ A-dim 2.68
    12v 12.3/ inv on,off 0.05
    3.5v 3.4/ 3.5v 3.4
    3.5v 3.4/ 3.5v 3.4
    20v 23.6/ 20v 23.6
    On 3.2/ 20v 23.6
    I charged the INV pin with 3v and the back light did not come on.
    There is a back button on the main board that when pushed, the back lights flash for a second and then go back off.
    Any advise would be much appreciated.
    • 12201
    • U.S.
    Re: LG 42" 42LD550 start up.
    Check the fuse on the inverter board.
      • 12201
      • U.S.
      Can you do the test in #3 below? try to do it just as instructed. Be VERY CAREFUL what you touch on the HOT/DEADLY side of the powerboard, that connector is on the cold side.
      • Pukehead
        • Nov 2018
        • 25
        power on:
        NC 0.1 / Error 2.3
        3.5v 3.4/ 3.5v 3.4
        3.5v 3.4/ 3.5v 3.4
        20v 23.6/ 20v 23.6
        On 3.2/ 20v 23.6
        power Off
        NC 0.0 / Error 0.0
        12v 0.0 / P-dim 0.0
        12v 0.0/ A-dim 0.0
        12v 0.0/ inv on,off 0.00
        3.5v 3.4/ 3.5v 3.4
        3.5v 3.4/ 3.5v 3.4
        20v 0.0/ 20v 0.0
        On 0.0/ 20v 0.0
        fuse on pwr board is good.
          • 12201
          • U.S.
          " inv on,off 0.05" Needs to be 2.5 volts or more to turn on backlights, the inverter on signal comes from the mainboard so looks like a mainboard problem.
          • Pukehead
            • Nov 2018
            • 25
            Im thinking the same, but when i put 3v to the pin, power board side. Nothing happend.
            • Pukehead
              • Nov 2018
              • 25
              Do you know what that little black button on the main board does? Cuz when i push it in, back lights come on for 1 second.
                • 12201
                • U.S.
                You can jumper the powerboard to test it and the backlights, you MUST disconnect the cable from the powerboard to the mainboard for the test, I am not exactly sure which pins need jumpered on this paticular board tho.
                • Pukehead
                  • Nov 2018
                  • 25
                  i will try it with the connector off.
                    • 12201
                    • U.S.
                    It is suggested to use a resistor in case you get the wrong pins, so will be resistor to go from standby pin to power on then a resistor from standby pin to bl-on and might also need another to go standby to A-DIM and another from standby to P-DIM, not sure, so could need to use as many as 4 resistors to jumper standby pin to those.
                    • Pukehead
                      • Nov 2018
                      • 25
                      Without the connector plugged in, I have no voltages on any pin. The TV wont even go into standyby.
                        No Voltage On the power supply connector?
                        We are testing the power supply board without Main board connected, not testing the main board.
                        • Pukehead
                          • Nov 2018
                          • 25
                          Im not sure what board i should be testing now.
                          • Pukehead
                            • Nov 2018
                            • 25
                            BudM do know what that green and black button on the main board does? after pushing the green button and then the black button, the back light comes on for a second. Then the TV shuts down back into standby.
                              Post #6 ~ 11 are for testing the power supply board using resistors to force on the power supply and backlights.
                              • Pukehead
                                • Nov 2018
                                • 25
                                What size resistors would you suggest using?
                                  Any value between 470 ~ 1000 Ohms 1/4 W will be fine.
                                  • Pukehead
                                    • Nov 2018
                                    • 25
                                    OK. ill see what i have laying around.
                                    • Pukehead
                                      • Nov 2018
                                      • 25
                                      So I was able to charge the INV/ CTR pin with 2+volts and the back-light comes on. So the power board is working. The red led on front bezel still pulses tho.
                                      The highlighted switch in the schematic when pushed enables the back-lights to flash for one second when the INV/ CTR pin is not charged. I think the issue is somewhere associate in this circuit, but im still not sure.
                                        Remove all the test resistors then connect all the connector back in place then check the resistance between GND and INV on pin to see what it shows.
                                        • tennno`
                                          RCA LED46C45RQ,Sound but no Back lights
                                          by tennno`
                                          Sound no picture RCA LED46C45RQ,Power Supply Board RE46HQ1301.
                                          Has All voltages coming from main board.No voltage going to
                                          Back lights from power board.Have no Schematic.Back lights work when
                                          Led Back light Strip tester is used.Tester shows 110 volts from each
                                          side.Also if you use the side controls and use the vol +or- tv shuts
                                          down.
                                          Thanks for any help
                                          04-10-2022, 03:34 PM
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          by sam_sam_sam
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                        • Musictuff
                                          70UH6350 Back lights
                                          by Musictuff
                                          My LG tv started going dark a few seconds after powering on. I replaced the led back lights after doing the flashlight test. The problem I am having now is the bottom of the screen is really bright and the middle to the top of the screen is darker. I can actually see the individual leds at the bottom of the screen. Not sure why that is. I've tried lowering the backlight setting but I can still see the led's at the bottom, and the middle to the top of the screen gets even darker.
                                          04-09-2023, 11:45 AM
                                          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-12-2024, 02:30 PM
                                          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
