LG 42LV5500 TV, Backlights on, No picture
  • henryvrensburg
    • Oct 2018
    • 104
    Good day guys
    I picked this TV up from a friend.
    When you switch the TV on, the backlights switch on, and stays on. However there is no picture. Sometimes a small band on the top of the TV can be observed, about 1cm thick, and when the Home button is pressed, you can see the band changing, suggesting a change in the item displayed.
    My first thought were T-CON. I removed one of the bands going to the panel, and half of the screen lights up slightly, same result with other band removed. The voltage going to the T-CON however is only 10.02V. The T-CON fuse is functional. Voltages on both sides are 10.02V. Voltage at Mainboard LVDS connector is 10.02V (Ground probe on chassis)
    I could confirm the voltages as per P201 exactly as in the legend on the PSU. 12V on PSU going to Mainboard reads 12.01V
    Can someone please confirm my suspicion of a bad Mainboard, or can you suggest further tests I can do.
    Thanking you in advance
  • neilc6
    • Nov 2015
    • 1550
    Re: LG 42LV5500 TV, Backlights on, No picture
    LV and LS series suffer from bga failures on the mainboard. Lots of repair services on ebay if you search.
    • henryvrensburg
      • Oct 2018
      • 104
      Thank you Neilc6. Will try that.
      • yokoono
        • Apr 2010
        • 505
        It is very possible that the US1 integrated on the t-con may be defective.
        • henryvrensburg
          • Oct 2018
          • 104
          Hi guys
          With reference to above posts, I unhook the LVDS cable from the T-CON. The Voltage reading on the Mainboard side of the LVDS cable is 11.63V.
          Does this still suggest a bad Mainboard(these boards are very expensive)or can it be a faulty T-CON. The reading on the T_CON fuse is 10,02V.
          Is 11.63V good enough to power the T-CON
            • 12268
            • U.S.
            Seems like if it's coming out of mainboard at 11.63 which is ok and ending up 10.02 at tcon, makes me think it's a tcon issue, maybe try unhook tcon from panel and see if it's still 10.02.
            • henryvrensburg
              • Oct 2018
              • 104
              Hi nomoresonys
              I took voltages on the T-CON fuse with LVDS removed from panel. Still reads 10.02V. I'm going to replace the T-CON and see what happens.
              Thank you for the help
                • 12268
                • U.S.
                Ok, hope it works.
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  https://3.bp.blogspot.com/-Ex-aKMD06...2lv4500-03.jpg
                  check the cold solder joint. Problem on all these sets...
                  • henryvrensburg
                    • Oct 2018
                    • 104
                    Hi guys
                    As per previous posts, I replaced the T-CON but with no change. The backlights does come on, and stays on, but no display. Am I looking at a bad Mainboard?
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      maybe another faulty t con board on the top of the tcon you have two ribbon cables if you disconnect on side and turn tv on whats shown on the screen? try the same thing on the other top ribbon cable
                      • iglitare
                        by iglitare
                        09-04-2025, 07:13 AM
                      • Ierwin
                        by Ierwin
                        05-13-2025, 03:31 PM
                      • kca
                        by kca
                        Hello all ~
                        08-31-2025, 06:38 AM
                      • stylishconsultant
                        un60j620dafxza - Samsung No Display Problem
                        by stylishconsultant
                        Hi All,
                        Need help.
                        I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                        So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                        problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                        might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                        09-04-2024, 03:26 AM
                      • DXseekerMO
                        TCL 55US57 backlights, no picture.
                        by DXseekerMO
                        So here we go with another screen short TCL. For this exercise left and right will be reference looking at the screen.
                        The person I got this TV from said the color was bad in a vertical fashion about 1/4 of the way over the left side of the screen. Shortly after the symptoms below started.
                        Power Supply, main and T-CON board are working.
                        Symptoms: The TV has backlights but no picture with both FFC's attached to the T-CON and does not respond to the remote or buttons, and the TV appears to continuously re-boot.
                        Unhook FFC from left side...
                        09-18-2021, 03:56 PM
