Dell e152fpb no back light
  • PlainBill
    • Feb 2009
    • 7034
    Re: Dell e152fpb no back light
    Originally posted by Maluko75
    ah ok..
    Hold your horses!!! There is no need to replace anything AT THIS TIME. That may change within a few minutes. I'm going to redo the picture based on Bobdee's correction.
    OK, corrected picture is attached. Here is what you should do: Set the meter to the Diode check scale - often one of the lowest Ohms scales (this applies about 2 volts across the leads). Note that each of the transistors circled in red has the letters B C E near it. Probe the pins with the leads in both directions. I suggest doing this as follows: Hold the black probe on the leg labeled B. Note the readings when the red probe is touched to C and then E. Move the black probe to C and note the readings when the red probe is touched to B and then E. Lastly, move the black probe to E and note the readings for B and then C. Repeat for the other three transistors.
    A good transistor out of circuit would show open on all readings except when the red probe is on the B (base) and the black lead is on either the E (emitter) or C (collector) for the 2SC5707 and any other NPN transistor. Then it should read about .7 volts
    This may not be the case with the transistor in circuit, but you should get similar readings for all four transistors. Under no circumstances should you get a reading of 0 volts.
    PlainBill
    • Maluko75
      • Aug 2009
      • 36
      Well the one under the heat sink should it read cont?
      • Maluko75
        • Aug 2009
        • 36
        YOUR THE MAN......i took out the 2amp pico fuse and tested it out the board and got no contso, iwent aheah and swapped in another and Bam A Magician was Born.. it lit up the screen.But lets see for how long,i'll keep you posted....
        • PlainBill
          • Feb 2009
          • 7034
          Bobdee deserves credit for identifying the location of the fuse!!!! As thanks you should attach a picture of the working monitor.
          It would be an excellent idea to turn off the monitor, remove the power supply / inverter, and thoroughly resolder all the pins on the inverter transformers. Bad solder joints on these are a known cause of problems.
          PlainBill
          • Maluko75
            • Aug 2009
            • 36
            Well a big Presto thanks to Mr Dee and Mr Bill...and i'll send a fresh pic as soon as i get my freakin camera back,,,lol
            • Maluko75
              • Aug 2009
              • 36
              #26
              Here you guys go, and another round of thanks..............
              Ya'll be saved in my favorites...
              • abdo
                • Oct 2010
                • 6
                #27
                bonsoir
                je suis nouveau ici, j'ai le mème moniteur dell e152fpb , il a le problème eclairage je l'allume le voyant est vert,l'ecran noir quand j'eclaire l'ecran avec une lampe je vois l'affichage qui est normal,j ai besoin du votre aide pour reparer ce moniteur merci
                • PlainBill
                  • Feb 2009
                  • 7034
                  Bienvenue.
                  Il serait mieux si vous postez votre problème dans ce fil. En outre, alors que le français est la langue de l'amour, beaucoup d'entre nous sont limitées à l'anglais.
                  PlainBill
                  • abdo
                    • Oct 2010
                    • 6
                    #29
                    ok thank you
                    • ek2oo2
                      • Oct 2013
                      • 24
                      • Philippines
                      #30
                      I got the same board with the same problem. The 2A fuse blew and I did not know what caused it. After replacing the picofuse, I still got no picture and green led of Power switch still on a steady mode. I inspected the circuit and as was I expected, it has many cold solders and I even found some on the legs of xsistors on the soft start section that made me guess that made the trick...
                      Monitor is up and running now and I logged in to say thanks for this thread and commentors for leading me on to the right path.
                      Thanks,
                      Eugene
                        Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                        by sam_sam_sam
                        This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                        I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                        I am comparing them to a brand new one that I installed
                        The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                        I going to let it run for several days before I remount back on the wall next to the...
                        09-05-2024, 06:48 PM
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • PNI E.
                        tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                        by PNI E.
                        hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                        02-20-2025, 08:36 AM
                      • expertreader
                        Dell 5520 not booting up - on light comes on momentarily
                        by expertreader
                        Dell 5520 South peak 15 MB 213253-1 2TWTT$LA
                        Hi all, looking for some help to get started on troubleshooting without schematics
                        I have used Dell Latitude 5530 SouthPeak15 MLK 203102-1 schematics from forum although this board is a little bit different.
                        I am a bit lost on USBC PD circuit and what to measure - here is what i have done so far.
                        • no coils are shorted - one is showing about 15ohms but others are in kohms or infinite resistance.
                        • most of the coils are showing 5V, 1.3V, 3V etc except 2 of them.
                        • i have measured 16.5V available at the capacitor
                        10-19-2025, 08:20 PM
                      • multimesut
                        Dell 2007FPB Yellow Light Problem
                        by multimesut
                        Hello friends,
                        A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....
                        11-13-2024, 07:00 AM
