LG 50PS2000 plasma tv with double image
  • Erikswe
    • Aug 2019
    • 6
    • Sverige
    As the title says. The picture has a double image vertically
    I was wondering where to start the fault check.
  • R_J
    • 9540
    Re: LG 50PS2000 plasma tv with double image
    I would start by checking just the panel using auto_gen test patterns.
    Unplug tv, dissconnect the cable between the main and control borad, locate and short the two points on the control board labeled AUTO_GEN and plug it the tv a see if the fault is still there while viewing the test patterns
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Originally posted by r_j
      i would start by checking just the panel using auto_gen test patterns.
      Unplug tv, dissconnect the cable between the main and control borad, locate and short the two points on the control board labeled auto_gen and plug it the tv a see if the fault is still there while viewing the test patterns
      +100
      • R_J
        • 9540
        If the control board has a P6 plug (lower left on board) short pins 1~2 for Auto Gen. The fault could be a poor connection with the lvds cable also, (wide flat cable between control board and main) try re-seating this cable a few times if the autogen tests are ok.
        • Erikswe
          • Aug 2019
          • 6
          • Sverige
          Some additional information. The tv has not been used for a lo g time so when I turned it on the picture was perfect for a few minutes but then the double image returned and when on for a lo her time the screen continues getting worse with the double image flickering.and even a few thin horizontal coloured lines and on the top right corner some small shadows of red, but once in a while the screen becomes perfect for a few seconds.
          That's the auto gen plug. Just to be clear, is 1 and 2 to the left?
          • R_J
            • 9540
            Pin #1 is marked with a white triangle. If the tv has'nt been used for a while I would re-seat all the connectors and maybe even clean and re-seat the flat cables between the panel and buffer boards.
            • Erikswe
              • Aug 2019
              • 6
              • Sverige
              I tested the auto gen patterns. The pictures has less distortions but in some tests the double image is flickering but much less
              • R_J
                • 9540
                That test eliminates the main board and I can't see the power supply causing the issue. Try reaseating the y-sus to buffer board plugs. try tapping on the boards and see if the fault changes.
                • Erikswe
                  • Aug 2019
                  • 6
                  • Sverige
                  I clean all flat cables on the left side with alcohol and repeated them. At first I got 2 black horizontal lines, thin, and repeated them again and the lines disappeared. I cleaned and repeated the flat cables from the logic board and now it's almost perfect. Just a liiiitle small flickering left
                  • Erikswe
                    • Aug 2019
                    • 6
                    • Sverige
                    Update. After letting the tv stay on the flickering got back more and there is a sound...hard to explain..but humming sound coming from the board to the left. When I touch one on the flat cables from the logic board the sound disappeared and the screen looks a bit better. Maybe reset the cables again and clean them
                    • R_J
                      • 9540
                      The Y-sus board will make some noise, and pressing it might effect it, Remove the board and check for poor solder connections, I see from SJ images that the bottom of the Y-sus board likely has pads stuck to the bottom to reduce this noise.
                      Also check the ground contact points where the screws hold the board to the chassis, if there is any signs of black corrossion, clean both the board and the metal chassis, Then INSTALL ALL SCREWS before retesting.
                      • Cornito
                        Samsung UE55RU8000 reboot and then double image after heating up
                        by Cornito
                        Hello team,
                        I'm back with another tv and another problem.
                        I try to improve my knowledge on fixing TV, and all technics used until now are not fixing correctly the problem.
                        First, reboot issue, I use tape Method to find out the right side that cases the issue.
                        Then using this it's working for quite 1hour30, then at some point of time the image became double on the bottom for half the screen.
                        Then double image reduce in height and move to the top.
                        The image is like folded on around 1cm and the bottom has been moved to the top by 1cm.
                        When I...
                        03-31-2024, 01:37 PM
                      • piershs
                        Toshiba plasma 50WP16 wierd double image fault
                        by piershs
                        My 2001 Toshiba 50WP16 50" plasma TV has, after 20 years of trouble-free service, developed a wierd fault in the last 14 days during normal viewing - with no loud bang or smoke or any other excitement.
                        Every 15-30 secs the right hand half of the image has a "glitch" for about 1 second before reverting to normal. The glitch has two forms and also depends on the aspect ratio setting (see photos):
                        • 16:9 either a) a visible seam between LHS and RHS of impage or b) LHS image duplicated on RHS (photos 16x9)
                        • 4x3 either a) no image on RHS or b) RHS image offset by 1/6th
                        08-01-2020, 01:07 PM
                        HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                        This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                        09-12-2024, 02:20 PM
                      • jason123
                        Hisense 65R6E3 double-image / horizontal strips - TCON?
                        by jason123
                        Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
                        07-19-2025, 08:07 AM
                      • howardc64
                        TCL 49S405 double image
                        by howardc64
                        LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
                        This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
                        06-23-2025, 03:20 PM
