LG 60PB6900 ~ Relay with cyclical, repeated clicking upon startup
  • kca
    • Feb 2016
    • 548
    Re: LG 60PB6900 ~ Relay with cyclical, repeated clicking upon startup
    Thanks, R_J. That's what I figured. I did a little comparison shopping in the last hour and found a board that was/is an exact match for only $57 (shipping + tax included), so I decided to buy that one and go from there. Figured the extra $27 over the cost of the repair kit was worth it to save time. Should be here in about a week. I will keep you and anyone else reading this updated. I am going to check over the buffer boards even more carefully now, in order to make sure as best I can that nothing blew out on those and caused the Ysus failure in the first place. Not common in this model, according to the video I linked up above, but still could have happened. If you have any further insight as to what I can and should test while I wait for the new Ysus to arrive, please let me know. Thank you very much.
    ~ kca
    • Terzo
      • Jul 2020
      • US
      Thanks for the this post and comments
      I am living in Las Vegas, NV …..and
      I have the same LG plasma 60PB6900 with the same issue.
      I had short circuit on Y-sus .(I replace they-sus)
      All the power are present from Power board…
      I check for short lower and upper board…,but still no green on logic board…
      Can you tell me what happen at the end of that post…what was the solution …..
      Thanks in advance
      Alex
      • beetle1303
        Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
        by beetle1303
        I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
        On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
        01-13-2025, 08:49 PM
      • CoinCoin88
        Garage door RX unit (Cardin S38C) does not short relay to send opening signal
        by CoinCoin88
        I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
        Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
        09-15-2025, 03:36 AM
      • DodgyTech
        60" LG 60PB690V relay clicking issue
        by DodgyTech
        I require some help with my TV. The TV standby light blicks on and off with a clicking sound (relay?) from the back. After I opened up the TV, I set about troubleshooting by unplugging the boards to try and isolate the problem. My troubleshooting suggests that the logic board is causing the issue, but it could entirely be the YSUS board which is only activated once the logic board is connected.
        I have recorded a video which I thought would be an easier way to explain the problem and show the boards at the same time.
        I would like to try and identify...
        07-07-2023, 10:30 AM
      • GraphicMan
        Pioneer amplifier A-205 Relay not clicking after a mistake i made
        by GraphicMan
        Hello guys
        Because the unit is old (but only occasionally used) the loudness button causes some noise due to bad contact,
        sprays did not work, so i decided to solder the pins that it connects on the pcb at the on (loudness on) position
        i did that and it worked fine, i know from the bottom of my heart that the switch connects 2 pins and also d/c other 2 pins
        on every position it have (6 pin switch), so i was curious what would happen if i clicked the switch off while the pins are soldered at on (so basiclly on and off at the same time), when i did so the sound is gone, nothing...
        05-05-2024, 06:20 AM
      • Sisko
        Onkyo-593 No power and now clicking sound
        by Sisko
        Hi all!!
        Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
        10-03-2025, 02:18 PM
