Philips 55PFL8007K/12 , errore 53
  • amennone
    • Feb 2015
    • 63
    • italy
    QFU1.1ELA
    Difetto : Errore 53
    Telaio / Versione : QFU1.1E LA
    Power Supply : FSP197-4FS01 2722 171 90676 REV : 01
    Pannello : LTA550HQ19
    Main board : 3104 308 98314
    T-CON :
    Processore : Fusion P240 FNP202-B1E32
    7JA0 : MT29F8G08ABABA Flash Nand
    The TV is completely turned off.
    The voltages I read are 3v3s = 3v3 and STB = 3v1
    I reprogrammed the spiflash 7CT3 (M25P10),
    on pin 2 of connector 1M95 the power supply
    it has gone to a low logic level, from 3v1 to 0 volts.
    The 12 volt, now, is present,
    like the other feeds on the mainboard.
    But I get error code 53.
    I tried connecting to Hyperterminal at the service jack,
    I get this information (see attachment)
    I also enclose the Spi 7CT3 reading before programming.
    The trash, which I reprogrammed for SPI is for a processor,
    is a Fusion P240 FNP202-B1E32.
    Can this be the problem?
    Another question, why do I get this log with Hyperterminal?
  • markolino
    • Mar 2020
    • 108
    • Slovenia
    Re: Philips 55PFL8007K/12 , errore 53
    solved your problem with yours TV ??
    If so how are you?
    • reformatt
      Intel iMacs, 3rd party SSD failures and Fusion setups
      by reformatt
      I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
      As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
      So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
      12-18-2024, 10:34 PM
    • Jaymun
      Repair Philips 55PFL8007K/12
      by Jaymun
      Hi there, first things first i must say i'm new in electrican things so take me easy here. I got a TV not a long ago and i wanna repair it. Everyone said the TV doesn't even start untill i got it, i started it and the TV was functional for about 10-15m and that was it, it stopped. The LED light sometimes blinks twice while it's plugged in, sometimes doesn't start at all. Just tell me what to do and i'll reply anytime i can.
      08-12-2025, 06:57 AM
    • mailforwho
      Philips 40PFL7007T/12 debug and repair. Fusion chip or PSU?
      by mailforwho
      I've got a Philips 40PFL7007T/12 TV and it died spontaneously. Didn't go intermittent, just one day it wouldn't turn on (about a year ago, actually, but sometimes it takes a while to get around to opening things up!). This isn't really my world, so apologies if I've messed up on terminology or not provided anything important - happy to be corrected.
      Oddly, it doesn't seem to do a lot of the things other people on the forum get from their faulty Philips/TPVision TVs - notably I don't get any Blink Codes or really any sign it's alive at all. I've sat...
      12-28-2020, 04:17 PM
    • G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo
      by G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
      It does power up when pressing the power button.
      I already try the power button while plugin the plug with no result.
      Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
      Could this be an PSU or eMMC issue ?
      07-19-2025, 03:43 AM
    • double_DD
      Philips curling iron - is this a common AC cable?
      by double_DD
      Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
      As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
      Not sure if this is something Philips proprietary, or a standard, but the cable plug...
      08-18-2025, 10:04 AM
