Repair Philips 55PFL8007K/12
  • Jaymun
    • Aug 2025
    Hi there, first things first i must say i'm new in electrican things so take me easy here. I got a TV not a long ago and i wanna repair it. Everyone said the TV doesn't even start untill i got it, i started it and the TV was functional for about 10-15m and that was it, it stopped. The LED light sometimes blinks twice while it's plugged in, sometimes doesn't start at all. Just tell me what to do and i'll reply anytime i can.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4472
    • Italy - Milan
    it's the common problem for that series, the cpu balls needs to be replaced, someone solved for unknown time with a good reflow..
    • William1967
      • Nov 2017
      • 215
      • Netherlands
      Connect the SDM connector to ground and plug the TV into the power outlet. How many times does the LED flash?
      If 5x and 3x ( = layer 2 error 53 ) then reball the processor as Davi.P said.
      • Jaymun
        • Aug 2025
        oh, that means i'm screwet
        • Jaymun
          • Aug 2025
          as i said before, sometimes blinks twice with pause, sometimes doesn't even light up
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4472
            • Italy - Milan
            You have to solder a thin wire on SDM testpoint on main board, the other side to a negative of an electrolitic cap , power the tv, if it gives code 53 by blinks so it is as i said..
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4472
              • Italy - Milan
              • William1967
                • Nov 2017
                • 215
                • Netherlands
                That kit was for a 7008 and not for the 8007. All kits are sold out and will never be available again unfortunately.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4472
                  • Italy - Milan
                  sorry i entered the wrong thread
                  • alro7779
                    Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                    by alro7779
                    Hello, guys!
                    The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                    09-14-2025, 12:25 AM
                  • G33RT
                    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                    by G33RT
                    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                    It does power up when pressing the power button.
                    I already try the power button while plugin the plug with no result.
                    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                    Could this be an PSU or eMMC issue ?
                    07-19-2025, 03:43 AM
                  • double_DD
                    Philips curling iron - is this a common AC cable?
                    by double_DD
                    Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                    As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                    Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                    08-18-2025, 10:04 AM
                  • janos6662000
                    Philips 47PFS7509/12 LCD TV problem
                    by janos6662000
                    Hi
                    I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                    When i applied cable signal to check image, i had normal picture, but TV was restarting.
                    I downloaded original firmware and applied the update, but the problem remained.
                    From a colleague i received a "factory package software" which is a lot bigger.
                    I made another firmware update, but still did not solve the problem.
                    Somewhere on the way the error got worse, because at the moment the...
                    08-12-2025, 12:54 PM
                  • aidanmo
                    Philips 43PUS7506/12 - Loud blown out sound
                    by aidanmo
                    I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                    I thought maybe the speakers got damaged, so I replaced them - no dice.
                    • Using the internal speakers, it always happens.
                    • Using the headphone jack, it never happens.
                    • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                    02-28-2025, 03:13 PM
