SHARP LC-40LE833E 1 blink
  • kiko1
    • Apr 2016
    • 48
    • croatia
    I have SHARP LC-40LE833E with 1 blink (white triangle).
    I checked led bars and one led bar is bad. I can change that but, how to reset this TV? It has sensor touch keyboard, so neither procedure with buttons-sensors does not work...
    can't find SM
    anyone please?
  • kiko1
    • Apr 2016
    • 48
    • croatia
    Re: SHARP LC-40LE833E 1 blink
    I was playing a bit with buttons on the keyboard and found a solution
    so....holding VOL- and INPUT and then press POWER on the keyboard....set powers up, panel(backlight) blinks and goes in error again(normal, led bar wasn't changed yet).
    • ninja_zx11
      Sharp LC-70LE650U vertical black and red bars
      by ninja_zx11
      70" LED TV is Sharp LC-70LE650U.
      Initial problem was horizontal lines and slow motion lurrs on the bottom left of the screen. So I removed both the left and right ribbon cables from the T-con board and tried to clean it with alcohol and when I put it back, this issue appeared. I tried carefully reinserting the ribbon bon cables but same thing. I checked the traces of the ribbon cables with magnifying glass and everything looks good. I cleaned the small jumper ribbon cable on the left side of the screen which cured the horizontal line and slow motion blurs...
      07-07-2023, 11:27 PM
    • cloo
      Panasonic ZT60 plasma tv with strange behavior and 8 blink code
      by cloo
      I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
      It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
      So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
      After doing a factory reset this problem was gone and the picture was back to...
      01-06-2025, 06:02 AM
    • EazyBone
      Un50cu7000 2 blink oddity *partially solved
      by EazyBone
      I write this to maybe help another with this TV.
      So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
      The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
      03-18-2024, 10:24 PM
    • Akira81
      LG 55LF652V-ZA flashing led bars despite their replacement
      by Akira81
      I have this 55" LG 55LF652V-ZA smart TV which suddenly started flashing intermittently every 2 seconds with the backlight.
      If I aimed the light bulb of my cell phone I could see the underlying image even in those fractions of time when the LEDs were off and the audio instead came out continuously.
      Armed with a lot of space and patience, I decided to open the TV, immediately noticing that a LED had flamed out and also burned a portion of that reflective white panel behind the transparent LED diffusers.
      04-14-2023, 11:50 AM
    • Mitike
      SHARP LC-70UC30U starts up with RESET then turn off and blink 1 LONG 1 SHORT
      by Mitike
      Hello guys,
      I have SHARP LC-70UC30U which won't turn on and the stand by LED blinks the 1 LONG 1 SHORT error
      According to other sharp SM-s it is lamp error (I can't find SM for this model)
      And yes I checked other blink error threads on the forum about other Sharp models and still can't make it work.
      If I unplug the set and hold the POWER and INPUT buttons while I'm plug it back the set fires up and shows sharp logo and after that the Android logo and turn itself off again and starts the blinking and wont turn on again except if I do the RESET procedure again....
      02-16-2020, 08:11 PM
