Hot air machine question.
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    What temperature do i set my hot air machine to desolder 30f301 fets?
    I have a tnpa5335 to repair.
    Previously I used a heat gun but I bought a hot air station a while back. Figured I may as well get it out of the box.
  • petehall347
    • Jan 2015
    • 4450
    Re: Hot air machine question.
    should tell you on device data sheet .
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      What device data sheet?
      • diif
        • Feb 2014
        • 6978
        • England
        The temperature you set it at isn't necessarily the temperature you'll have on the board.
        Get a scrap board and play with the temperatures and air speed settings.
        • Malachi
          • Dec 2015
          • 1077
          • Usa
          Ok thanks. Any starting point?
          • diif
            • Feb 2014
            • 6978
            • England
            I'd guess around 330-340c. Maybe check YouTube to see if there are any tutorials for your station to give you a better idea.
            • Malachi
              • Dec 2015
              • 1077
              • Usa
              Ok thanks. Btw, don’t you brits sleep? Lol
              • diif
                • Feb 2014
                • 6978
                • England
                Yeah, sometimes.
                  ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                  This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  09-12-2024, 03:28 PM
                • CG2
                  Janome DC3050 Sewing Machine Pedal Resistance
                  by CG2
                  OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                  Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                  04-14-2023, 07:53 AM
                • Soulzink
                  Samsug washing machine. Power supply DC41-00189a board issue
                  by Soulzink
                  I am trying to fix a samsung washinmachine power supply main board.
                  I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                  Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                  The power supply board reference is the following: DC41-00189a
                  I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                  04-19-2025, 06:26 AM
                • unimatrix93
                  How to stabilize AC voltage to CNC machine
                  by unimatrix93
                  Hello there everybody, I'm not sure if it's the right topic to ask this but I hope so.
                  I have a CNC machine wired to 3-phase 230V AC.
                  It's a smaller CNC machine with a 3500W motor, do it does not uses much power.
                  The problem is, when the residents come home and put load on the network, the voltage can drop to around 207V which is fine for most household items but by CNC machine stops working from this.
                  I contacted the electricity company but they refuse to help me solve this problem.
                  So I started to look around for some DIY...
                  03-17-2025, 05:52 AM
                • xdever
                  820-01700 not booting, 4V PP2V5_NAND_SSD0 but 2.5V when the machine is off.
                  by xdever
                  I got a 820-01700 of a friend that doesn't turn on. I read that a typical issue with these boards is the TPS62180 generating the NAND voltages, so this is where I started looking. Sure enough, PP2V5_NAND_SSD0 is 4V when the machine tries to turn on (I try to determine this by measuring PP2V5_NAND_SSD1, which is 2.5V as it should in this case. The PP0V9_SSD0 and PP1V8_SSD0 power supplies for the SSD are on at the same time when PP2V5_NAND_SSD0 is 4V). The extremely weird thing is that when the machine is off (PP2V5_NAND_SSD1=0, PP0V9_SSD0=0 and PP1V8_SSD0=0), PP2V5_NAND_SSD0...
                  01-15-2025, 08:44 PM
