Samsung UN60H7150AF-has sound, no picture
  • bfordz
    • Aug 2011
    • 81
    We have a Samsung 60" LED flat screen that suddenly lost it's picture. We have sound but can't get a picture.
    No Picture what so ever, no menu, no smart hub.
    I have removed the back and I can't see any physical problems or obvious signs of a failure.
    I noticed the T-con board has 3 LED's; LED-1 comes on / off with the TV being turned 'on' / 'off'. LED-2 blinks one time real fast when the TV is turned on. LED-3 has never come since I took the back off. I don't know if that helps or means anything!
    After some research / reading I found that if I unplug the cable from the Main board to the Power Supply board(power plug disconnected), when I plug the power back in the Backlight LED's light up.
    They don't say what that means! Does that mean my "Main" board is bad? What should I check next?
    I checked the voltages at the CNM803 connector at the Power Supply board:
    CNM803 connector
    TV Off (all connectors connected)
    2-PWM-Dim4= 0.00, 1- - = .010
    4-PWM-Dim2= 0.00, 3-PWM-Dim3= 0.00
    6-PWM-Dim1= 0.00, 5-GND= 0.00
    8-OD-ON= 0.00, 7-A13V= 10.0
    10-OD-Level= 0.00, 9-A13V= 10.0
    12-BLU-On= 0.00, 11-A13V= 10.0
    14-PS-On= 0.00, 13-A13V= 10.0
    16-grnd, 15-A13V= 10.0
    18-grnd, 17-grnd
    20-Vamp= 10.0, 19-Vamp= 10.0
    22-grnd= 0.00, 21-Vamp= 10.0
    TV ON (all connectors connected)
    2-PWM-Dim4= .134, 1- - = .010
    4-PWM-Dim2= .132, 3-PWM-Dim3= .133
    6-PWM-Dim1= .136, 5-GND= 0.00
    8-OD-ON= 3.32, 7-A13V= 12.85
    10-OD-Level= 3.53, 9-A13V= 12.85
    12-BLU-On= 5.16, 11-A13V= 12.85
    14-PS-On= 3.32, 13-A13V= 12.85
    16-grnd, 15-A13V= 12.85
    18-grnd, 17-grnd
    20-Vamp= 12.85, 19-Vamp= 12.85
    22-grnd= 0.00, 21-Vamp= 12.85
    cable from Main to PS disconnected, power plugged in
    2-PWM-Dim4= 3.26, 1- - = .776
    4-PWM-Dim2= 3.26, 3-PWM-Dim3= 3.26
    6-PWM-Dim1= 3.26, 5-GND= 0.00
    8-OD-ON= 1.35, 7-A13V=12.86
    10-OD-Level= 1.34, 9-A13V=12.86
    12-BLU-On= 3.21, 11-A13V=12.86
    14-PS-On= 4.50, 13-A13V=12.86
    16-grnd, 15-A13V=12.86
    18-grnd, 17-grnd
    20-Vamp= 12.85, 19-Vamp= 12.86
    22-grnd= 0.00, 21-Vamp= 12.86
    While trying to get 'something' on screen using the remote, not sure what series of buttons I hit (possibly Smart Hub) I got music to play from the TV, so it kind of works just no picture.
    Not sure what to do / try next!
    Re: Samsung UN60H7150AF-has sound, no picture
    Please put the pin name for each pin reading of the connectors so we can easily tell what each is is for.
    If you have everything connected but not the 4 white flat cables between T-CON and the LCD panel, do the backlights come on?
    • bfordz
      • Aug 2011
      • 81
      I updated my pin labeling.
      NO, if I disconnect the 4 white flat cables I don't get any backlights on. TV on or off.
      • bfordz
        • Aug 2011
        • 81
        If I reconnect all cables (main to PS board) BUT disconnect the T-con to Power supply board; the backlights come on / off with the TV.
        If I turn the TV on, the backlights come on, If I turn the TV off the backlights go off.
        I still can't get anything on screen; eg., on screen menu. I haven't tried an external source.
          That small connector on the T-con that goes to the power supply board is for the Backlights dimming control signal PWM1 ~ 4. So there is problem with T-CON board at this point since you disconnect that connector and you get backlights.
          https://www.shopjimmy.com/catalogsea...ng+UN60H7150AF
          • bfordz
            • Aug 2011
            • 81
            Thank you very much 'budm'
            Part is on order, will update with repairs!
            • bfordz
              • Aug 2011
              • 81
              Thanks again to "budm" for his advise on my T-con board being my problem.
              These samsung parts seem to be in hi demand; I got on ebay and found a board from TVCHOPSHOP right here in MI., ordered and received it the next day!
              I attached pics of the old board and then the new board, there are 3 LED's on the board and only one was lighting up on the old board (hint).
                Thanks for the follow-up on the repair, since it is high demanded board I have a feeling that these boards are not reliable and have issue, hopefully your replacement board will last.
                • birdfeed
                  • Apr 2014
                  • 9
                  • usa
                  t-con can be repaired. look for smd caps. good luck.
                  • TR103
                    by TR103
                    - it keeps rebooting
                    01-22-2025, 04:12 PM
                  • Mgiffune
                    by Mgiffune
                    06-09-2024, 10:28 AM
                  • Ierwin
                    by Ierwin
                    05-13-2025, 03:31 PM
                  • jchang
                    Samsung UN70NU6900F no picture and no sound
                    by jchang
                    Hi all
                    I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                    Symptom:
                    No picture no sound.
                    When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                    No sound at all.
                    What I tried:
                    1. I tried unplugging the left or right ribbon...
                    01-09-2023, 06:28 PM
                  • Dodgethis
                    Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                    by Dodgethis
                    Hello all,
                    This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                    09-11-2024, 07:39 AM
