TV Main Board cross over
+ More Options
Posts
  • Beau28713
    • Feb 2018
    • 50
    My question is this. (Prob a stupid question).
    I have a RCA SLD65A55RQ that requires a main board. I have searched ebay and found boards for sell.
    But here is the question, I have also found boards listed for smaller TV's (also RCA models) that have the same form factor and look identical to my board but fit a smaller TV. EX 47 inch and 55 inch.
    Can I use these boards for my 65 inch tv or do i have to have to buy the board listed for my TV.
    Thank you for your time.
  • Hobby 1
    • Mar 2010
    • 86
    Re: TV Main Board cross over
    if the board is the same p/n, then the screen size does not matter.
    The model number should also be the same except for the size # in the model.
    I swap main boards all the time but I usually deal in other brands like Samsung, Toshiba, etc. You can go up or down in model numbers within the same series too. A higher number may just have extra inputs or features...usually applies to the brands I work on. I don't touch RCA so I can't be sure with them.
    • Beau28713
      • Feb 2018
      • 50
      Okay thank you
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Yes you can do a swap. I discovered this by accident when I couldn't find the exact Main Bd. and in desperation fitted a similar Main Bd I had and to my surprise it worked. The Replacement Bd had more inputs but all the connectors matched.
        • Beau28713
          • Feb 2018
          • 50
          This is good to hear!!!!
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • ygorsan
            by ygorsan
            🧩 Problem Summary:
            • I
            07-28-2025, 08:34 AM
          • jb_Bak
            by jb_Bak
            CN6401
            Pin 01 NC
            Pin 02 NC
            Pin 03 "BL_ON": 0V
            Pin 04 "N/C"
            Pin 05 "STBY 3.3V": 3.5V
            Pin 06 "GND": N/C
            Pin 07 "AC_OFF"...
            09-27-2021, 04:52 PM
          • JDC
            by JDC
            ONN 100012588
            Long answer:
            07-15-2022, 07:39 AM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
