LG 60PN5700 Powers on, No Video No Picture
  • saintlouis74
    • Dec 2013
    • 102
    I just acquired a LG 60PN5700 from a friend who didnt know what was wrong with it. The TV powers up and I see a small flash on screen but then it cycles back off then on. It seems to be on but no video or sound. I traced the 5v and 17v around the boards it seems to be getting around to every board.. I tried to use a heat gun on the main board and rework it, didnt have any effect. What should i focus my attention on?
    PB P/N: EAX64880001
    MAIN P/N: EAX64870004
    ### P813 ###
    M_ON = .61v
    PL_ON = 1.22v
    5.2V = 5.2v
    G
    G
    5.2V = 5.2v
    5.2V = 5.2v
    G
    17.V = 17.1v
    Auto_G = 4.1v
    AC_ON = 5.0v
    17V_DET = 2.357v
    VS_ON = .64v
    G
    VS_DET = 2.7v
    5.2V = 5.2v
    G
    17V = 17.1v
    ### J148 ###
    VS = 203v
    VS = 203v
    GND
    GND
    VA = 55v
    5V = 5.2v
  • R_J
    • 9556
    Re: LG 60PN5700 Powers on, No Video No Picture
    If you look at the control board you will see two test points labeled EXT_AUTO_GEN, unplug the tv, disconnect the plug going between the main board and the control board, short the two test points on the control board and plug the tv in, You should get test patterns on the screen, If you do, the fault is likely on the main board
    • saintlouis74
      • Dec 2013
      • 102
      Thank you, the self test worked, and some smoke came of a chip on the main board, so its pretty obvisouly the main board it damaged. thank you again for your time
      • R_J
        • 9556
        Doing this test would not have caused a problem with the main board. Which chip on the main board smoked? maybe the board can be repaired.
        • saintlouis74
          • Dec 2013
          • 102
          this is not the my actual board but a identical one. this is the chip that was burnt on the top and was smoking
          • R_J
            • 9556
            That would be the audio output ic. (STA380BWF), If it is killing one of the voltages you might be able to disable it and see if the rest of the tv works. If the 3.3 volts is being killed, trace that pin and there should be a small smd coilyou could remove to disable the ic, same goes for the P_17v
            • saintlouis74
              • Dec 2013
              • 102
              Im sorry, after taking the TV back out of storage and getting the board out, i realized i circled the wrong IC..
              • R_J
                • 9556
                That looks like the hdmi ic, I can't make out the number, look up the number, find the pdf and locate the vcc pin so you can disable the ic in case it is shorting one of the voltages, again the board should work with the ic disabled, just no hdmi.
                • saintlouis74
                  • Dec 2013
                  • 102
                  Ok will do thanks again.
                  IC3303 is the chip location.
                  i cant make out any numbers on the ic because its burnt
                  Sil1292CNUC
                  • saintlouis74
                    • Dec 2013
                    • 102
                    Which one would be the vcc pin?
                    • R_J
                      • 9556
                      In this case it's VDD5, pin10 5v
                      • saintlouis74
                        • Dec 2013
                        • 102
                        ok... It still comes on, and i notice after the 2nd relay click it lights up for a sec then goes dim
                        • R_J
                          • 9556
                          There are other voltages on that ic, see if they are there or are being loaded down, +3.3v & +1.2v, if the ic is badly shorted it could be killing the clock or data lines also
                          On plasma's you will get that first precharge flash, if the hdmi chip is burnt there may be other damage on the board.
                          • Pionex2020
                            • 8
                            Sil1292CNUC
                            Does anyone know where this ic ( SIL1292CNUC ) may be purchased.
                            • charlesjudd
                              • Mar 2020
                              Hi, Do you have a schematic for the SMPS power board (EAX64880001) ?
                              During servicing the one I'm trouble shooting, I remove a couple of what appear to be tiny diodes on the back of the board near IC801.
                              The diodes are marked:
                              33
                              BE
                              15
                              BG
                              (no way to read them unless under a microscope).
                              Now I have them pulled off and realise they are different components with different values, I have idea which one goes in which spot, or which way around the diodes should be. A schematic would help out with this.
                              Any chance you can help with either measurements from your board (OHMS value for each, and Diode test so I can identify the values and placement direction?)
                              I've marked the read board view attached image with red box and blue box indication their location on the board.
                              Rookie error
                              • charlesjudd
                                • Mar 2020
                                33
                                BE
                                15
                                BG
                                Rookie error
                                Should read "I have NO idea which one goes in which spot, or which way around the diodes should be. A schematic would help out with this."
                                • R_J
                                  • 9556
                                  What is the number on IC801? that might help, I don't think there is a schematic for this board. The two diodes are zener diodes, one is 15v one is 33v, The anode end of each diode likely connects to hot ground.
                                  If it is a L6599a?
                                  I suspect one (ZD804) connects to pin 12 vcc line.
                                  I would think ZD805 (blue) would be the 33v zener and ZD804(red) would be the 12v zener.
                                    HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                    This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                    09-12-2024, 02:00 PM
                                  • csmith
                                    Vizio D50u-D1 Powers up no picture
                                    by csmith
                                    I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                                    Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                                    supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                                    issue. Set will power up with remote but not power off....
                                    07-11-2025, 11:52 AM
                                  • gl4709
                                    Samsung un55cu7000d with backlight and sound No Video / Picture
                                    by gl4709
                                    I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
                                    01-23-2025, 06:21 PM
                                  • sergio_av
                                    Acer Aspire E5-571G-52NH powers on, no picture. PCH_ENVDD goes off and on.
                                    by sergio_av
                                    Hi, I'm unexperienced with troubleshooting and I'm not sure how to proceed with this laptop.
                                    Motherboard is A5WAH LA-B991P I think, i5-5200U and nvidia 820m.
                                    When I received the laptop, CMOS battery had 0V. I took it out and all the testing has been done without a CMOS battery and without the main battery plugged in, I haven't been able to see physical damage, burnt or missing components with a quick visual inspection, and no shorts were found.
                                    Laptop charges the battery, powers on when ON button is pressed when powered from charger and when powered from the battery, but...
                                    01-01-2025, 05:27 PM
                                  • KYBOSH
                                    Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                                    by KYBOSH
                                    Saved this beast from the landfill this weekend.
                                    Manfactured July 2013 in Mexico.
                                    I love working on plasma TVs.
                                    Its been a while but I was lucky enough to find 2 this week.
                                    The TV powers on and stays on but no picture. Havent checked for sound yet.
                                    No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                                    Will start troubleshooting tonight.
                                    10-17-2024, 01:17 PM
