Vizio E701-A3 Backlight Question
+ More Options
Posts
  • Tjp444
    • Sep 2009
    • 20
    This TV would turn on, you could see the Vizio logo for a few seconds and then shut down. Stripped it down, found one led on one strip that was bad, replaced the strip with a used one, now the tv won't start up the backlights.
    I tested each of the strips individually with an LED tester, two are at 170v fully lit, the used replacement is at 171v. Is that enough of a difference to stop it from starting?
    The power supply starts to ramp up the voltage, seems to get to about 60 and then ramps down with the LED strips connected. Since not all of the pins on PS board are available from the top I'm not sure if I can test across all of the V+ and V- connections. The other voltages on the PS and main board are within spec.
    Wondering if there is a reset procedure - I know some TV's after hitting so many attempts at starting the backlights lock up. This is a Sharp TV branded as Vizio.
    Any thoughts on next steps? Thanks.
  • Tjp444
    • Sep 2009
    • 20
    Re: Vizio E701-A3 Backlight Question
    I have determined there is 3.2V at the "BL ERR" pin, this voltage is present immediately upon pressing the power button. Is this sent from the main board to the PS or is this the PS sending it to the main board? It seems almost too quick for it not to be a "remembered" error.
    • budwich
      • Jul 2015
      • 3097
      you have to go into the service menu to reset the error counter. There is a force on sequence... something like vol + Chan down at the same time while plugging in the set. Search for the exact sequence.
      • Tjp444
        • Sep 2009
        • 20
        I've read through all the threads I could find, I've tried:
        Vol-, input, plug in.
        CH+ CH- press power, release power, release other buttons
        Vol+ CH- then plug in
        No success so far.
        • Tjp444
          • Sep 2009
          • 20
          Reading through other Vizio and Sharp posts, it looks like it may be a PS problem. I'm only getting 165v across the legs of the filter capacitors, circled in orange in the attached pic. Is that low?
          Thanks for any input.
          • budwich
            • Jul 2015
            • 3097
            I think the bl-er is generated towards the main board by the power board. If I see the picture of the power board correctly, all the pins going to the leds are visible and available (with care). You should be able to measure across each pairing just like you did with your tester. Note: the voltage may appear and disappear quickly.
            There is a technique using a resistor to feed the ps-on line (resistor going to 3v supply somewhere on the board / connector) with the power supply to main cable disconnected. Then the light will stay on / light "forever" and you can see what the result is... maybe you have some additional leds gone. Lots of people replace whole strings as the "act of playing" causes issues for the "leftovers".
              If the PS-ON is present (all the boards are connected) when TV is turned on then the DC V measured between the two legs of any of those 3 main filter caps should be 380 ~ 400VDC if the PFC boosted Voltage is working.
              • Tjp444
                • Sep 2009
                • 20
                Thanks Bud. PS ON is high, BL ON is high, the voltage between the legs of the filter caps never goes above 168v. I ordered a tested replacement PS board with a warranty, apparently these can be repaired (shopjimmy sells a repair kit) but doing the math it made more sense to buy a board with a warranty. I just hope I didn't damage the panel taking it apart, I was extremely careful but you never know. Will report back.
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • howardc64
                  Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                  by howardc64
                  Failure Symptom
                  No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                  Where is the short?
                  Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                  Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                  05-27-2025, 02:56 PM
                • Yanleb
                  Vizio M70-D3 4K with dark spots backlight issue
                  by Yanleb
                  I have a Vizio M70-D3 4K with a dark spots backlight issue. It is using the Y8387248A backlight driver board.
                  On this model each of the 64 transistor powers 2 LEDs. Using my TKDMR TD3H backlight tester I've determined that the backlight LED strips were the issue, and the backlight driver board was just fine. Some LED pairs required 5.9 volt at 155mA, some required 9.5 volt and some were completely open.
                  I've removed the LCD panel and once the LED strips were exposed I've tested them again by connecting my LED tester directly on the test pads. To my surprise all, I've...
                  03-22-2022, 01:06 AM
                • smort
                  Backlight Polkadarks
                  by smort
                  Soooo, I found someone giving away their 70" Vizio TV because it wouldn't turn on. Hoping it would be just some bad caps, I snapped it up. No dice. No bulging caps. TV would start consuming about 7W immediately after plugging it in, but no response from the remote or power button. Thermal showed the main chip on the mobo getting warm and nothing else. Power supply appeared to deliver stable 12V to the mainboard.
                  I ordered a replacement mobo(actually both mobo and PSU just to be sure) and popped it in. Picture! Sound! Endorphins! Then I noticed three long dark strips. Hmmm, had...
                  03-11-2025, 12:33 AM
                • JaquesPratt
                  Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                  by JaquesPratt
                  I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                  This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                  07-16-2024, 01:04 AM
