Samsung UE58MU6125K flashing standby led only
    • 12079
    • U.S.
    #41
    Re: Samsung UE58MU6125K flashing standby led only
    • Diah
      • Feb 2013
      • 6343
      Originally posted by london-freddie
      Thanks for that Diah, changed wifi-ext to wifi_int reset again and now have wifi detected and connected
      Now just to sort the channel order out
      what do you mean with this ( sort the channel order out )
      which source of signal you are receiving T or S or C
      if your region correct and country correct no problem you have
      • london-freddie
        • May 2015
        • 472
        Re Sort the channel order out
        After reset and after re scanning for digital channels it finds 197 digital, 141 tv, 49 radio,7 data/other, 4TV Plus
        However these channels are not in any logical order
        Normally BBC 1 would be channel 1, BBC2 would be channel 2, ITV would be 3, Channel 4 would be channel 4 etc. etc.
        On mine BBC1 is on channel 51, BBC2 channel 77, ITV channel 131, Ch 4 96 etc. etc.etc
        • Diah
          • Feb 2013
          • 6343
          you know what.. one man with one son ( Samsung his name ) his wife dead. friends tried to help him to find other mother to his Samsung Sons .. he agreed. and got new Mother board to his Sons Samsung. after while he start to complain. his dead one was blond and good at arrangements my favorite channel.. but this new at house don't. LOL
          yours new mother boards ( replacements) came from Spain not UK. you teached her the language already.. but you need to change her blood type to be as your like.. lol
          its all about region in SM. if it set correct she will be look to you as the old blond one you know.
          this comments just for fun only had nothings to do with any color or region
            • 12079
            • U.S.
            #45
            LOL, I thought 420 was over.
            • london-freddie
              • May 2015
              • 472
              Hi
              Still no joy in sorting these mixed up channels on this tv
              Have found someone with same tv and have compared every page and every setting of the service menu between his and mine and every setting is the same
              Did find that the Samsung account that I created when I set up the tv gave my location in my personal profile as being in Madrid, So have deleted that and created account on laptop with UK as Location. Not worked
              Next step I shall try is to export his channel list on to a USB stick and import his channel list to my tv, fingers crossed
              TV is working fine but these mixed up channels are really annoying as cant find what I want without searching
              I will beat it
              • london-freddie
                • May 2015
                • 472
                Just used this Samsung channel editor @ Samychan.com SamyCHAN is your channel list editor for SAMSUNG televisions. ✓ All Series (D, E, F, H, J, K) ✓ web based ✓ channel sorting ✓ renaming ✓ favorites
                This has sorted it, I now have channels in a logical order
                TV is now sorted
                Thanks everyone for all your help once again
                • Michael Long
                  No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                  by Michael Long
                  I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                  Dead / No Power / No Standby Light results after power company had three
                  consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
                  After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
                  09-13-2022, 06:55 AM
                  09-07-2024, 05:50 AM
                • tvguy12012012120
                  by tvguy12012012120
                  02-07-2025, 05:13 PM
                • 7ony
                  Samsung plasma - flashing standby light
                  by 7ony
                  The TV is a 2013 Samsung plasma, model # PN60F5300AFXZA.
                  Snagged it up in non-working condition a couple years ago. Previous owner said that sometimes he could get it to come on after repeated tries but other than that he couldn't get it to turn on.
                  Personally I haven't been able to get it to turn on at all. The standby light comes on solid when plugged in, but pressing the power button results in the standby light flashing once every 4 or so seconds. No "click" noises, no light from the panel at all. Just the flashing standby light.
                  No visible...
                  08-31-2020, 05:18 PM
                • ChristianBr01
                  LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                  by ChristianBr01
                  I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                  The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                  What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                  04-23-2025, 01:48 AM
