BN44-00499A Capacitor values / Ratings
  • jason123
    • Oct 2015
    • 1068
    I just picked up this 55" Samsung (UN55EH6001F) and the symptoms are described as "Shuts off on its own and can be restarted by unplugging from wall and waiting a few minutes"
    It ran when I got it for a while without a glitch, but I decided to open it up anyway. Looks like the power supply board has had few repairs, and the obvious one is the capacitors around the connector that goes the main board look like they've been replaced. I'm trying to find the original / correct capacitance and voltage ratings for those.
    See photos below. CS852, 851, 855, and 853
    Thank you
  • R_J
    • 9546
    Re: BN44-00499A Capacitor values / Ratings
    I don't have a schematic but based on a picture I found,
    CS853 = 2200µf/10v
    CS855 = 470µf/10v
    CS851 = 1000µf/25v
    CS852 = 47µf/50v
    • jason123
      • Oct 2015
      • 1068
      Thank you.. this board has the right values with higher voltage ratings.. should be ok!?!?
      • jason123
        • Oct 2015
        • 1068
        So the issue with this TV is that after 5 minutes or so of turning on, it restarts on its own. Chime and all. After that, it works like a charm. I tried to wiggle cables, connectors,... see if there is something loose, but doesn't seem to be. Any thoughts on what it might be?
        • R_J
          • 9546
          My first guess would be an issue with the main board, likely it it uses a large bga chip, that could be the cause of restarting
          You could try and monitor the voltages and see if they drop when it restarts, or maybe try unpluging the main board from the power supply, and plug in the tv, this should turn on the power supply and backlights (no video) and see if runs for a longer time.
          • jason123
            • Oct 2015
            • 1068
            Perfect.. I will give that a shot.. Thanks R_J
            • jason123
              • Oct 2015
              • 1068
              Ok, it does shut down with the main board disconnected. Power supply issue.
              Only thing I noticed is the large cap voltage goes from 389 V when good and on to 405 V while it's in the reboot cycle. Means anything? I'd love to fix the power board. Any thoughts where to begin?
              • jason123
                • Oct 2015
                • 1068
                Also, the 13 V (12.7V nominal on the connector that goes to the main board) drops to 0V when it's rebooting with the main board disconnected. The A5V stays solid at 5.29V, but B5V drops to 0 during the reboot cycle (maybe this is normal as it goes to 0 naturally when the set is off - Backlight is off)
                • neilc6
                  • Nov 2015
                  • 1550
                  Restarts could be caused by a bad wifi module. Try disconnecting it.
                  • jason123
                    • Oct 2015
                    • 1068
                    Thanks... this tv is not a smart Tv- no network access
                    • jason123
                      • Oct 2015
                      • 1068
                      Anyone by any chance has or know where I can get the schematic for this power supply board? seems that there is a solder joint or broken trace as when I apply pressure on the board it seems to work fine. I inspected under a microscope and touched up suspect nodes, but I can't seem to pinpoint it. Thanks
                      • R_J
                        • 9546
                        I would start by resoldering any of the transformer rivits/connections, and also all prts mounted to the heatsinks, don't just look at them, resolder them. they usually are the first to fail.
                        check the voltages to see which ones quit when you press the board IE: is the standby voltage still there? when it quits.
                        • jason123
                          • Oct 2015
                          • 1068
                          Yes R_J A5V is solid does not dropout
                          • Byte_76
                            Understanding capacitor ratings
                            by Byte_76
                            Hi, I have some capacitors that I need to replace on a graphics card.
                            I've attached pictures for reference.
                            Please help me to understand the ratings so that I can order the correct replacements:
                            1. G7 560 2.5E - I believe these are for vcore
                            • Is this 560uF and 2.5V?
                            • What does the "E" mean?
                            • Is there any relevance to the "G7"
                            2. ECX 17 560 2.5V - I believe these are on the memory phase
                            • Another 560uF at 2.5V?
                            • This is on the same graphics card. If the caps are rated the same as those above, why are they a different type?
                            05-10-2024, 07:56 AM
                          • rashidjafar
                            Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
                            by rashidjafar
                            I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
                            Values for :-
                            PC43 : Capacitor [3x1.5mm]
                            PL7 : Inductor [2x1mm]
                            PC39 : Capacitor [1x0.5mm]
                            Any ideas would be appreciated.
                            I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
                            08-07-2025, 05:10 PM
                          • proxneo
                            Recapping Sony ICF-SW55 - verifying cap values
                            by proxneo
                            Dear reader
                            I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                            At the moment, I have selected replacements based on the following list of values:
                            3 x 470uF 10VDC
                            3 x 4.7uF 35VDC
                            4 x 47uF 50VDC
                            8 x 22uF 6.3 VDC
                            1 x 220uF 6.3VDC
                            5 x 100uF 6.3VDC
                            Which...
                            06-21-2023, 12:38 AM
                          • mrkmpn
                            Capacitor values in boardview
                            by mrkmpn
                            I am trying to determine the value of a blown capacitor, and the boadview shows the values for many of the capacitors and other components on this board, but all of the information blank on others.
                            Is there any relevance to the fact that some of these values are left out, or is it just inconsistency by whoever created the boardviews?
                            Is there any way to deteremine if one without infrormation matches one that shows those details?
                            05-25-2022, 12:03 PM
                          • chth96
                            If I replace with inferior capacitor, Is it No harm to other IC components at all?
                            by chth96
                            I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                            Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                            It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                            So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                            I know that these capacitor will not last as long as nichicon capacitor...
                            12-22-2023, 04:34 AM
