Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
  • R_J
    • Jun 2012
    • 9535
    Re: Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
    maki and hulko, start your own threads that way you are more likely to get answers.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4297
      • Italy - Milan
      #82
      hulko don't hijack other one's thread with different issues.. open your own discussion
      sorry, i see R J's post now..
      • Chungalin
        • Jul 2014
        • 422
        • Spain
        #83
        Originally posted by Maalobs
        The debug-port 1CV5 is unpopulated but I soldered in wires on TXD-SERVICE and TXD-STANDBY so I could monitor them with serial adapters.
        Is there any difference between those two serial ports? While I can get clear communication from TXD-SERVICE (with expected parameters of 115200-8bit-1stop-no parity-no flow control), I just get garbage from TXD-STANDBY. I assume that signal level is 3.3V in both cases.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4297
          • Italy - Milan
          #84
          check if there is a level translator like MAX3232 or others..
          • Maalobs
            • Jun 2016
            • 120
            • Sweden
            #85
            Yes, the levels are 0-3.3V TTL on both ports.
            It said in the service manual that the main processor was set to 115200 8N1, and by simply testing other speeds I discovered that the standby processor was set to 57600 8N1.
            I used a USB-to-TTL serial-adapter:
            https://www.adafruit.com/product/954
            This one with the blue casing from Adafruit uses an original chip, so the device works with the official Windows-driver.
            If you find one that's half the price or cheaper, then it's most likely using a pirated chip, which the signed drivers in Windows will detect and refuse to work with.
            The pirated ones still work in Linux, though.
            I learned this the hard way.
            I also got a 5-pack of small test hook clips with a male Dupont connector on them:
            https://www.electrokit.com/produkt/t...klamma-5-pack/
            I soldered a short piece of bodge-wire onto the relevant pads on the PCB and then hooked the test clips to the wires I wanted to listen on.
            I left the bodge-wires on the PCB with the ends tucked between a couple of layers of kapton-tape, ready for use the next time.
            • Chungalin
              • Jul 2014
              • 422
              • Spain
              #86
              Thanks. I tried other lower speeds without luck, but not this one!
              I use a USB serial adapter with FTDI FT232BM IC and a Sipex SP213ECA IC for standard serial voltages. I disabled the second IC (Enable to GND), and changed FT232BM signaling voltage from 5V to 3.3V connecting VCCIO (p13) to its own 3V3OUT (p6).
              The problem is that I tried TXD-STANDBY first, and as it wasn't good looking (due to the speed difference you point out), I blamed my modifications of serial adapted, but after giving up with that port I tried the SERVICE port and it worked fine!
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4297
                • Italy - Milan
                #87
                Why you're trying to access standby ser.port? I think it has no useful info in it, i have tryed with a Chinese board theese days, st.by serial only prints few characters at boot and 2 char. at shut down. It is a the port of the st.by processor that has a simple software, not much to communicate..
                • Chungalin
                  • Jul 2014
                  • 422
                  • Spain
                  #88
                  Well, I just wanted to check that I get exactly the same log outputs in both ports than Maalobs. Also, I wanted to make sure that my mods on the standard serial USB adapter were working fine.
                  I have ordered a programmed NAND and I’ll report results after replacement.
                  • Maalobs
                    • Jun 2016
                    • 120
                    • Sweden
                    #89
                    I still have the dumps of all the flashroms from the TV, even the NAND which is too big to post in the dump-thread on this forum.
                    Let me know if you need it, I can arrange an sftp link for you.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4297
                      • Italy - Milan
                      #90
                      Which is your symptom?
                      • Chungalin
                        • Jul 2014
                        • 422
                        • Spain
                        #91
                        Error 2 / 53.
                        Thanks Maalobs. I have an XGecu TL866II Plus that can read/write these NANDs, but I don’t have a TSOP-48 adapter, so I’ve prefered to order an already programmed NAND for this chassis.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4297
                          • Italy - Milan
                          #92
                          Chungalin you are wasting time/money,the problem is the same always, cpu soldering.
                          • Chungalin
                            • Jul 2014
                            • 422
                            • Spain
                            #93
                            But, what caused the first improvement in Maalobs TV? CPU reflow or NAND replacement? Since he did both things at the same time, it wasn’t clear to me which one was the root cause. I admit that I’ve chosen the NAND part first because CPU reflow is out of my reach.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4297
                              • Italy - Milan
                              #94
                              No doubts, the problem is very common and always the soldering.
                              • Maalobs
                                • Jun 2016
                                • 120
                                • Sweden
                                #95
                                Does your TXD-SERVICE output end on <020>K like it did for me and Alpengeist?
                                If that's the case then you probably need to reflow the Fusion processor, and I'd suggest that you wait until after the Fusion reflow before you replace the NAND.
                                With the Fusion processor running, you can record and inspect the output from TXD-SERVICE to see how bad the existing NAND is.
                                Then if you replace the NAND, you can record the output from TXD-SERVICE again and compare it to the previous output.
                                It's easy to compare the outputs with a diff-tool like WinMerge, the boot sequences will be a lot of mostly similar lines, this way it's easy to spot the differences.
                                The reflow was what got my TV working, as described in this post.
                                It was when I got that far and had the Fusion booting properly, that I discovered in the proper TXD-SERVICE output that the NAND had multiple bit errors too.
                                So I decided to replace the NAND to extend the useful lifetime of the TV.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4297
                                  • Italy - Milan
                                  #96
                                  If you have still some errors in mem. after succesful reflow and you gain access to linux prompt you can do fsck on it..
                                  • Maalobs
                                    • Jun 2016
                                    • 120
                                    • Sweden
                                    #97
                                    Have you been able to gain root access on any TV with a current software image installed?
                                    Back in April 2019 I read through a several years long comment thread on neophob.com about it as I mentioned in this post.
                                    That page only remains in the Internet Archive now, but as I recall, it had been fairly trivial in the early days to gain root and then pick out the crypto keys from the filesystem for the upg-releases (the publicly downloadable encrypted archives that contain upgraded factory images to all internal memories in the TV).
                                    Over the years however, Philips incrementally locked down the security until eventually no one in the thread was able to get root again.
                                    RXD-SERVICE and RXD-STANDBY were totally dead on my TV so I couldn't write anything into the terminal, and I think I remember from the neophob-thread that the last thing Philips had done was to encrypt one of the filesystems in the NAND, so it wasn't even possible anymore to manually binwalk the NAND-dump to identify and mount that particular filesystem, and Philips hid the crypto keys in there for the upg-files.
                                    I don't remember the details anymore about all the hacker stuff, but I read through all that for a possible way to get hold of a factory clean NAND-dump from the upg-file, since my running theory for my TV's 2-53 problem at that time was bit errors in the Flashmems or the EEPROM.
                                    • Chungalin
                                      • Jul 2014
                                      • 422
                                      • Spain
                                      #98
                                      My Service log is identical to yours (except the very first 32bit hex number, that looks like a boot cycle counter). This determinism lead me to rule out broken CPU solder points, because something like that is not very deterministic, but rather random (broken solders will be in a given zone, but you can’t tell which one will broke first).
                                      • Maalobs
                                        • Jun 2016
                                        • 120
                                        • Sweden
                                        #99
                                        I'm afraid I don't follow your reasoning; if you have the identical symptom in the TXD-SERVICE output as me and Hermann Alpengeist, how do you come to the conclusion that your problem is not identical to ours?
                                        See his results here:
                                        https://alpengeist-tvrepair.blogspot...fu-12-cpu.html
                                        I don't think it has to be the same BGA-pads that disconnect when the PCB flexes from the overheating; just any data-, address-, control-, power- or whatever pads get loose and now the processor won't boot anymore, or the 8051 standby-processor doesn't allow the Fusion to boot if it doesn't pass the power-on-self-test as a consequence of any of these loose pads.
                                        Reflowing a big BGA-chip like that was daunting to me too, I was just lucky in that I got help from an experienced professional who did the reflow for me.
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4297
                                          • Italy - Milan
                                          #100
                                          Yes Maalobs i did it in some Chinese boards like Akai and brothers.. often if you press enter or ctrl+c you can access prompt. Obviously if the failed partition is the system or something with programs in use the part. is locked and the job gets bigger a bit. Chungalin i've seen so many of them failing with cpu, usually the fault worsen with time, first there are random crashes or no boots, this is a proof of soldering prob. Last but.not least also the software problems are random.
                                          Chungalin is the name in Spain for the cartoon of your icon?
                                          • ngml
                                            Repair of an LG split AC system indoor unit PCB
                                            by ngml
                                            I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                                            This indicates an error in the communication between the outdoor and the indoor unit.
                                            The outdoor unit is fine, so the problem is the indoor PCB.
                                            The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                                            I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                                            Does anybody have the schematics of this board,...
                                            02-01-2025, 12:55 PM
                                          • nobbnobb1
                                            Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
                                            by nobbnobb1
                                            Hi guys,
                                            Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
                                            When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
                                            02-03-2022, 11:14 AM
                                          • BC_TechForum_drb
                                            Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
                                            by BC_TechForum_drb
                                            Sub: Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
                                            Ref: 1/ MacPro6,1 Late 2013/A1481 MD878LL/A (3.5 GHz 6 Core Xeon E5-1650v2)
                                            Gfx-B: APN: 661-7548 PPN: 820-3533-A AMD FirePro D500-B 3GB Vmem
                                            2/ Figure 1 Gfx-D500-B Front Facing
                                            3/ Figure 2 +5v supply (zoom-in)
                                            Intro:
                                            While troubleshooting a Mac Pro(6,1) referenced above I discovered the +5v secondary supply did not stand up on the D500-B graphics card as a result of a missing enable signal. The +3.3v secondary rail was the only rail that did standup. I tried to perform...
                                            12-07-2023, 09:55 PM
                                          • Gjackson
                                            Air-conditioning unit power supply failing to power up
                                            by Gjackson
                                            Hi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
                                            01-08-2022, 09:24 AM
                                          • Duranitron
                                            Asus x512dk rev 2.1 power on problem
                                            by Duranitron
                                            When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                                            Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                                            11-26-2024, 10:22 PM
