Samsung TV On Off Cycle Bad Capacitors, PLEASE READ, I need your help guys
  • tmwalsh
    • Jan 2009
    • 119
    Re: Samsung TV On Off Cycle Bad Capacitors, PLEASE READ, I need your help guys
    From the NESDA-Ohio site, one of their recent Speaker articles was about manufacturer provided training. I wrote down the names of manufacturers that do actual training for the independent repair crowd.
    If they respect their product enough to provide training on its repair and maintenance, they are likely to be in business next year, and have parts available, and maybe even schematics and repair manuals.
    Here's the list of trainers:
    LG
    Mitsubishi
    Philips/Funai(!!!!)
    Samsung
    Sony
    Toshiba
    You don't see vizon, vison, Panasonic, Polaroid, etc showing up. The companies that play the odds with minimal warranty and 'ship it back if it dies' repair policies will likely take the money and run. You may be left with a pretty doorstop when the smallest of parts fails and cannot be found.
    Oh, and be careful cleaning the LCD and bzzzt brain fade - electronic screens. They are easily damaged - PERMANENTLY. Be sure to read the mfg recommendation.
    tom
    • Wizard
      • Mar 2008
      • 2296
      You got that right. Samsung and Philip did run us by on training sessions so that's consistent.
      We USED to do Panasonic/Mitsubishi/Toshiba till they just put us under their heel and not train at all, hassling us for any warranty stuff paperwork, all the works. Then finally dropped us. Same with JVC (which I regard as another excellent TV to have).
      Cheers, Wizard
      • weirdlookinguy
        • Sep 2007
        • 1638
        tom
        Don't put Panasonic in the same category as Vizio/Polaroid. They make the good stuff. Just because companies don't have training doesn't mean they don't make junk, and vice versa. Samsung is on that list, and wasn't it a failure of one of their televisions that started this thread in the first place?
        • tmwalsh
          • Jan 2009
          • 119
          WLG,
          You're right. Panny was put there by mistake on my part. Brainfade comes more often as you get older. I am not a fan of their TVs, but they do have a decent rep, so far.
          tom
          • louald
            ive replaced the bad caps on the power supply board of my samsung dlp hl50a650c1f 13 mo old tv. two of them were samwa 470uf@200v,three others also samwa2200uf@25v.one other on the ballast board 47uf@450v which was leaking a brownish substance out of the top which i could wipe off.this was done over two hours ago and everything seems to be working fine.i will not bash samsung everyone else is doing plenty of that. i will only say that i buy products according to the service i get and leave it at that.thank you for your forum i dont thik i would have attempted this repair without it, also thanks to digi-key who supplied me with good caps at a total of a little over $12.00.thanks again.louald
            • Wizard
              • Mar 2008
              • 2296
              #26
              Good service. I don't care what others have spurned the brands for various reasons but I like Samsung for service and their TV line especially series 4 and up is excellent for picture processing is not too bad excepting the tuner side. I do have very specific reasons for other brands that we have hard time with.
              Cheers, Wizard
              • Lfischer
                • Jun 2010
                #27
                I paid $450 about 6 months ago to fix the very same problem on my Samsung LNT5271FX/XAA model--at that time, I did not think to go on the internet to research problem--Service tech came out to my house and said he had to "Replace the entire board" due to bad capacitor. (TV was about 14 mos old--just out of warranty.)
                Then two days ago the same problem appeared on my other Samsung (LN26A450C1D). Went on line to find ALL KINDS of issues with bad caps--also to find out that the caps can be replaced--entire board does not have to be replaced. I am not handy and would not even PRETEND to think I could open up the TV and replace (God forbid resolder!) caps back on, but at least when I take it to get repaired, I know it should not cost $450 ....
                Thank you for your informative posts.
                • PlainBill
                  • Feb 2009
                  • 7034
                  I hope you understand that like many other tasks, soldering ranges from very easy to extremely difficult.
                  On a scale of 1 to 10, with 1 being soldering two 18 gauge wires together, and 10 replacing a 244 pin IC, replacing these caps would rate about a 2. The tools would run under $20, the caps under $10. The feeling of accomplishment - Priceless!!!
                  PlainBill
                  • arct
                    • Jul 2010
                    #29
                    I just stumbled upon this site as i was researching about the apparently common issues with the Samsung LCD TVs. My particular model is the LN46-650.
                    I took the unit apart (it was already out of warranty) and examined the caps and there were a total of 4 for my particular model. There were two 1000uF 10V rated caps and two 1000uF 25V rated caps. The two 25V had noticable swelling at the top. My question is, should i replace them all with higher voltage caps or just replace them with better quality caps, same voltage? I was gonna solder two 35V caps to replace the 25V caps and then two 25V caps for the 10V. Is there anythign else i should pre-emptively replace. I don't want to have to spend about 20 minutes taking this thing apart again! Thanks in advance for the help guys!
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #30
                      Replace all the caps whether they swell or not. They don't have to swell to be bad.
                      You can go higher in voltage or stay the same. If you go higher in voltage, make sure the diameter and height fit on your TV. Higher voltage caps are sometimes bigger.
                      Use high quality low ESR caps like Panasonic FM/FC series or Rubycon MCZ.
                      --- begin sig file ---
                      --- end sig file ---
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Certain models of Samsung TVs were notorious for containing Samwah caps from bad production lots. Wizard has mentioned this; I ran across the problem on a 46" Samsung LN-T4665F LCD TV. I checked all the caps in the power supply with an ESR meter and found only those particular caps were bad. All others read much better than the spec.
                        Again, the general rule of thumb is to replace all caps from a known bad manufacturer. In the case of mine, I checked all the caps and did not replace those that tested good.
                        PlainBill
                        • jwhgg
                          Banned
                          • Oct 2010
                          #32
                          I work for a law firm that is investigating Samsung LCD and plasma TV power supply problems. We have spoken with several Samsung TV owners who have similar experiences to the ones described in this thread. If you would like to share your story with us to help with our investigation, SNIP!
                          Thanks,
                          John
                          Last edited by kc8adu; 01-04-2011, 08:03 AM. Reason: contact info removed.you will not troll for customers here!
                          • PlainBill
                            • Feb 2009
                            • 7034
                            Originally posted by jwhgg
                            Thanks,
                            John
                            Why on earth would I want to help a bunch of sleazy lawyers? Are you hoping to move up from chasing ambulances to filing class action lawsuits; or are you so well known in your area you can't even get clients for pro bono work?
                            PlainBill
                            Last edited by kc8adu; 01-04-2011, 08:04 AM. Reason: contact info removed.you will not troll for customers here!
                            • smason
                              • 1652
                              How the eff did a lawyer get in here?
                              • PlainBill
                                • Feb 2009
                                • 7034
                                They're like cockroaches. Scuttle around in the dark, feed on waste, generally foul anything they come in contact with, and make a delightful crunching sound when you step on them.
                                Perhaps I'm being too harsh. Cockroaches do have fill an important ecological niche.
                                PlainBill
                                • lbeck
                                  • Jan 2011
                                  #36
                                  It may have gotten lost in the thread, but I'm assuming that we're still talking about Samsung PS board, right? I've got the on/off cycling problem on a Samsung 52" LCD and will talk with samsung tech support rep this afternoon and hopefully they will come and repair my unit (2.5 years old) at no cost,even though it's out of warranty. If I can't convince them to do this, then my next step is to replace the caps myself, but I was only planning to work with the PS board. I haven't opened the unit yet, but I'm assuming that there are many other caps throughout the set, and I hold the "if it ain't broke" philosophy.
                                  Also, if anyone has some advice on negotiating with Samsung, I'll appreciate that also.
                                  • kc8adu
                                    • Nov 2003
                                    • 8832
                                    • U.S.A!
                                    #37
                                    these sort of class actions rarely help the injured parties.no benefit except lining the pockets of these bottom feeding scum.go back to chasing ambulances!
                                    Thanks,
                                    John
                                    • uk115083
                                      • Jan 2011
                                      #38
                                      Hi, I've just joined the forum after searching the web and drawing a blank for an answer to my particular problem. I'm not a technician but it sound's like this thread might have identified the problem with my TV. I have a Samsung WS-32Z306V which keeps switching to Standby. It is approx 4 years old from new. There is no pattern i.e. it happens at different times but it will switch on again straightaway. If bad caps are the problem, coulds someone please me help me by telling me which caps specifically will need replacing.
                                      Many thanks, Paul (UK)
                                      • Scenic
                                        o.O
                                        • Sep 2007
                                        • 2642
                                        Samwha and Sam Young caps are usually what's in those Samsung LCD Monitors and TVs.
                                        if you see any of those 2 crapcap brands, replace all of them..
                                        (the Rubycon in the pic is just to keep the blue Samwha from rolling away Rubycon is a good brand)
                                        • Behemot
                                          • 4845
                                          • CZ
                                          #40
                                          Bad is not only they replace whole board (well maybe they replace the caps than back in factory and give it to somebody else next time), but even that making such a board cost what, 50 bucks at most? And they sell it for 450? This is theft for me.
                                            09-07-2024, 05:50 AM
                                          • ctroxtell
                                            Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
                                            by ctroxtell
                                            I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
                                            01-03-2025, 08:57 PM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
