Tx48CX400b Panasonic backlights
  • Maveriksam
    • Feb 2019
    • 3
    • United Kingdom
    I know this is a popular subject but I was wondering if one of the LED's on my backlights could cause the backlights to all go out after 5-10-15mins?
    The TV turns on fine, then after maybe 20mins the backlights go out. Then turning the TV off and back on again the backlights go out after a few minutes.
    Each time I can turn it off then back on and they work for a few minutes and then off.
    Re: Tx48CX400b Panasonic backlights
    Yes. Try turning down the backlights level as low as possible to see if it will stay on longer. You also need to provide the pictures of the whole backside of the TV showing all the boards.
    • Chrissygizmo
      Panasonic TX-48CX350B backlights but white screen , blank screen
      by Chrissygizmo
      Hi all, I’ve got a problem I hope someone can help me fixi.
      I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
      01-11-2025, 03:18 PM
    • BigPete
      Panasonic Heatpump Dryer Repair
      by BigPete
      I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
      The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
      In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
      Unfortunately the whole machine has to come apart to fix it.
      I have...
      11-01-2025, 06:40 PM
    • Amraks
      Panasonic SA-MAX770 (not turning on)
      by Amraks
      Hey all its been awhile since I have needed to post here.
      Panasonic - SA-MAX770: Symptoms not turning on
      Power Supply
      C1403 has 330v
      IC1402 Looks perfectly fine no blown out holes.
      C1601 has 3.3v
      CN1851 Has its 3.3v but no 15v all I am getting is on the 14v rail is 0.400v
      Not sure where I should be looking next for this any help would be appreciated...
      10-04-2022, 12:12 AM
    • Andre Gilbert
      by Andre Gilbert
      Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
      Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
      11-20-2024, 08:52 PM
    • max789
      Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
      by max789
      Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
      I made the following tests:
      1. Disconnected the main board from Power Board = backlight works.
      2. Connected the main board and disconnected the T-Con = backlights does not work.
      So I ordered a main board from Ebay also BN41-02156A but from...
      01-18-2024, 06:56 AM
