Toshiba 37XV500A low backlight intensity
  • dkneyle
    • Dec 2013
    • 445
    Have set backlight intensity to 100%. Output intensity of backlight is about 30% would be my guess. Unsure of history of this set. What is likely to be the cause? Worn out CCFL tubes or an inverter not putting out the required voltage?
    I haven't yet opened her up. If CCFL tubes then I'll write it off and cannibalise.
  • Kg74
    • Feb 2013
    • 67
    • Usa
    Re: Toshiba 37XV500A low backlight intensity
    Hard to tell without seeing the board. Does the unit have 1, 2, 3, or 4 bulbs? Maybe one side is out - not sure if possible but maybe 3 out of 4 bulbs are out. Open it up and post some pics.
    • dkneyle
      • Dec 2013
      • 445
      Haven't got the set with me at the moment, so I can't send pictures. I opened it up and was presented with one of the most complex LCDs I've ever seen. Many, many circuit boards.
      I can only see two high voltage leads going to the CCFL tubes in the panel. So I assume they are just wired in parallel. The low voltage supply to the inverter is solid at 24V.
      I'm assuming TV's had a very hard life and the tubes are simply worn out.
      • DanPoka
        by DanPoka
        02-15-2025, 05:05 AM
        Design of CCFL Backlight Inverters with Frame & Bar Cores
        Summary
        Portable devices, such as notebook computers and personal digital assistants are developed rapidly nowadays, which places an increasing demand on display technology. The LCD with cold cathode fluorescent back lighting satisfies the requirements on display performance, size and efficiency.
        The backlight inverter plays a crucial role in supplying the power to the lamps of these flat-panel displays.
        The frame and bar ferrite cores, described in this brochure, are especially designed...
        10-07-2024, 04:26 AM
      • triplefour
        by triplefour
        09-13-2023, 10:43 PM
      • Boyxba
        TOSHIBA BACKLIGHT MAINBOARD C55-a-1h9
        by Boyxba
        I have a toshiba laptop satelite series c55-a-1h9 with a burnt item on pcb motherboard which is responsible for backlight display. the short came after installation of cable lvds and broken the leg with the v+ of backlight and made this short . the lvds cable replaced and i have working display now but not backlight. the problem is i dont know what was the component that burned in order to change it. voltage i have in this points of burned item at up side 19v and dropping and from down i have steady 19v . can anyone help me? i shall post some photos to see....
        05-13-2023, 11:47 AM
      • Comp_Pro
        No Backlight Macbook A1990 820-01041
        by Comp_Pro
        Hello all,
        Am trying to figure out this backlight issue with this A1990 Macbook Pro.
        Tests performed:
        There is no backlight even with a good screen.
        Backlight IC is receiving the correct support voltages.
        Fuse F8400 ok
        Current sense resistor R8400 ok
        Backlight IC is receiving 3.3V on enable pin.
        Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
        Backlight IC receiving 5V from PP5V_G3S
        Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
        I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
        05-06-2024, 10:23 PM
