Hisense LHD32D50TUK
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Hisense LHD32D50TUK
    Hello, all I've been having an issue with my tv,first off it starts up ok can go through the menus, then it freezes,then carries on until it completely freezes.
    then on switch on gets stuck on the Hisense welcome screen.
    The board number is tp.ms6308.p83 freeze, Around two years old no warranty,Any ideas ?
    • 12330
    • U.S.
    Re: Hisense LHD32D50TUK
    Messed up eeprom?
    • tmhobadcap
      Hisense 58H6550E - Freezes/Won't turn on
      by tmhobadcap
      I have another tv to fix for my friend. It is a Hisense smart tv. After turning on, it will freeze or stuck on certain screens. However, when it is connected to a tv box, it will automatically connected to it and play without any problem. I wanted to go to the menu and reset the tv. But it just freezes before I reach the reset menu. I have tried the hard reset methods, but no luck. I guess the main board is with problem. Will reflowing one of the chip may fix the problem? If yes, which chip should I try reflowing?
      The followings are some videos showing how it freezes.
      https...
      02-12-2023, 09:19 PM
    • NYKing
      Hisense TV 32D33 - Replaced EEPROM, now menus have no text
      by NYKing
      The TV initially had a steady (not flashing) red standby light but did not turn on when power button was pressed. I tried all the usual “fixes” but nothing worked. TV would not turn on. After researching the issue, I concluded the cause was a bad EEPROM chip. I ordered the appropriate chip from ShopJimmy:
      https://www.shopjimmy.com/hisense-32...hoCOcUQAvD_BwE
      I took off the old chip using my hot air station and soldered on the new chip. I tested...
      10-07-2021, 05:06 PM
    • N3Star
      ASUS ROG G15 G513QY random freezes
      by N3Star
      My laptop recently started freezing randomly - it usually freezes after a few minutes, sometimes after 2, other times 10 minutes.
      So far I kind of ruled out software problems, as the problem persists on live booted Linux, installed Windows and also while installing Windows. My first thought was that it was overheating, so I checked the temps and they are fine, as You can see on the screenshot, never the less I opened it up and reapplied LM on both cores, also using some more thermal putty on the VRM, obviously didn't help.
      While live booting Linux it usually freezes...
      11-16-2025, 02:48 PM
    • tomketcz
      schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ
      by tomketcz
      Does anybody have schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ ??
      10-01-2025, 03:13 AM
    • Coolgoodman
      Faulty Hisense 85Q6NAU TV
      by Coolgoodman
      85” Hisense TV
      Greetings,
      Request for Technical Assessment – Faulty Hisense 85Q6NAU TV
      Dear TV technicians of forum, I hope this message finds you well.
      I am writing to seek assistance regarding my 85-inch Hisense Smart TV, model 85Q6NAU, which is currently experiencing a fault. The unit is approximately two years old, and I am not sure if it has a warranty.
      I have attached a photo showing the issue for your reference. I would appreciate it if your experienced technician could kindly review the image and provide some insight...
      07-24-2025, 03:02 AM
