lg 60pz550 black screen, no power, etc
  • budwich
    • Jul 2015
    • 3097
    Re: lg 60pz550 black screen, no power, etc
    :-).... you certainly need to be "good" with your testing / eyes since "our internet end" can't see anything else. Since the "new values" are more expected, you should probably go thru the latest suggestion by unspun01 and go from there.
    • legonch
      • Feb 2019
      • 49
      Originally posted by legonch
      Okay. power board installed. no flat cables attached anywhere. Do not get the red light in front of the tv, remote doesnt work
      Plugging in the tv while reading the 5v pin shows an initial voltage of 3.7, then drops to Zero
      Reading the Va pin, i get voltage numbers all over the place. 137volts to 0. Meter voltage is constantly moving. Same readings while plugged in, and while powering up.
      The bottom Vs pins register 0 volts.
      This is my response to unspuns suggestions. Wondering if power board has a big issue with the lack of voltage, etc.
      • budwich
        • Jul 2015
        • 3097
        BUT... you didn't read his "request" carefully... he did NOT request that ALL ribbon cables to the power board are disconnected.
        • Unspun01
          • Jun 2011
          • 349
          Originally posted by budwich
          hmmmm.... I would expect any kind of resistor in / around any FET's or "switch transistors" to be in the 5-20 ohm range....
          Good observation budwich - I skipped over the decimal.
          Most of those resistors that I highlighted in red are 15 ohm or parallel 27 ohm resistors which would read 13-15 ohm. If someone measures in "resistance" mode they should appear as 13-15 ohm. If someone measures in "diode/continuity" mode the display may show 0.015 which corresponds to 15 ohm...
          Legonch: can you please re-measure all the gate resistors I highlighted on ysus and zsus boards? They should be about 10-15 ohm or close to it.
          • legonch
            • Feb 2019
            • 49
            will do!!!
            • legonch
              • Feb 2019
              • 49
              Im attaching a pic of the zsus board.
              All of the resistors on the zsus tested around 15 ohms. The one tested 48 ohms.
              How do I test these little chips you have highlighted?
              The ysus board, all the resistors checked at around 15 ohms.
              What do I test next?
              Thank you again for your help!!
              • budwich
                • Jul 2015
                • 3097
                BUT... I think you need to EXACTLY do the test that unspun01 specify with the cabling as suggested... if in fact to ensure that there is no question as to what is connected and what isn't, post a picture of the "test setup".
                • budwich
                  • Jul 2015
                  • 3097
                  if that resistor is labeled / looks the same, then that it is a problem.
                  • legonch
                    • Feb 2019
                    • 49
                    yeah, that resistor is pulling that many ohms. Probably a stupid question, but can one single resistor cause the picture to not show at all? Seems like a tiny part for all that
                    • legonch
                      • Feb 2019
                      • 49
                      Reading the Va pin, i get voltage numbers all over the place. 137 volts to 0. Meter voltage is constantly moving. Same readings while plugged in, and while powering up.
                      Okay, attached is a pic of how everything is installed. Everything hooked up except the ysus and zsus boards. I still get the same voltage readings as before.
                      Where to now? Power board dead?
                      • legonch
                        • Feb 2019
                        • 49
                        bump
                        • Unspun01
                          • Jun 2011
                          • 349
                          Wow, there are a whole bunch of replies to this thread that did not show up previously so my apologies if some of my replies are not timely or out of order.
                          Legonch:
                          Originally, you had a semi-working TV that stopped working after you re-soldered coil connections on the YSUS and ZSUS boards.
                          We started testing the YSUS and ZSUS boards because there was no reason to suspect the power supply until now.
                          You must have damaged something by accident so we must find out what.
                          Based on the YSUS and ZSUS tests I asked you for, I think those boards look ok for now.
                          HOWEVER, please post CLEAR pictures of the actual soldering you did on the backside of ZSUS and YSUS boards.
                          The photo requested by budwich is exactly what he and I want to see. All of the cables and boards are installed and connected except for the PWR-to-ZSUS and PWR-to-YSUS which is good.
                          ******With this arrangement, please measure 5V, VA and VS with reference to TV chassis (ground) that I described in post #33.
                          Press power button and measure each voltage for 5-10 seconds. Let us know if you 1) measure a voltage?, 2) what is the voltage?, 3) whether that voltage stays on?, 4) if the voltage goes away?.
                          • legonch
                            • Feb 2019
                            • 49
                            Legonch:
                            I did post a pic of how the boards are connected now on the back of the tv. the ysus and zsus boards do not have the power board connections connected.
                            I did measure the voltage, the 5V i get an inital rise to 3.8 volts, then goes to zero. Va i get voltage all over the place, as high as 138, and low of zero. This cycle repeats constantly and never changes with the tv on. The VS pins register zero. I measured these voltages on both of the connectors to the sus boards on the power board.
                            • Unspun01
                              • Jun 2011
                              • 349
                              Please read my reply.
                              I am asking for clear photos of the ACTUAL soldering you did on the rear of the YSYS AND ZSUS boards.
                              You had a working power supply, but something you did to the YSUS or ZSUS may have burned out the power supply.
                              The VA and VS pins on the power supply should rise to the voltages stated on the label on the back of the panel. These voltages should remain constant.
                              The fact that you have no VS voltage tells me that you now have a power supply problem.
                              Since you did not touch the power supply, you may have damaged it by accident with something you did on YSUS or ZSUS boards.
                              • legonch
                                • Feb 2019
                                • 49
                                Here are the pics of my soldering on the sus boards.
                                The last pic, the board looks discolored for lack of better terms on the back side, is that the way it is supposed to look?
                                Thanks!!!
                                • Unspun01
                                  • Jun 2011
                                  • 349
                                  legonch:
                                  Thanks for your pictures of your soldering. They are very helpful.
                                  The slight discoloration of the board is normal and may be from operating in a war/hot area of the TV, or may be present from manufacturing. Not an issue here.
                                  Now for bad news.
                                  Your soldering is not good. The coil soldering was not cleaned properly, and it looks like you did not use flux or enough solder.
                                  These coils expand and contract a lot throuch heating and cooling, and therefore the solder connections break over time due to the brittle ROHS lead-free solder used at the factory.
                                  What you need to do is remove the bad dark oxidized solder from the coils and the solder pads on the circuit board.
                                  Then you have to use LOTS OF FLUX and a good soldering iron to "re-tin" the coils and the solder pads. You need to use a good amount of solder and ensure that you have good solder flow between the board and the coil legs.
                                  What you have now is poor solder connections, and possibly no solder connections at all in a few of them.
                                  The clean/new solder appears to remain clumped to itself and no adherence to the coil, or the board in some places.
                                  To clean the crusty bad solder use de-soldering braid or de-soldering wick, and possibly gentle scuffing with an X-Acto blade to scrape off bad solder. When you have nice silver surfaces then you can re-apply solder.
                                  Unfortunately, it looks like not one of the coil solder connections is good, and I suggest re-soldering every one of them.
                                  Also, please re-solder the HEATSINK solder tabs and maybe the transistor legs because from the cracked pad with a black circle around it in your first picture, you also have poor solder connections at other locations on the board.
                                  • legonch
                                    • Feb 2019
                                    • 49
                                    okay, thanks!! i didnt remove the old solder, i just heated the pins up and melted new solder on it.
                                    Would these have anything to do with the power board voltages not being correct? I do get continuity through all of these new soldered joints if that means anything.....
                                    • legonch
                                      • Feb 2019
                                      • 49
                                      I didnt even see that until you mentioned that!!! Nice Catch!
                                      • Unspun01
                                        • Jun 2011
                                        • 349
                                        You still have a power supply issue, and it could be related to improper ZSUS or YSUS repair but I don't see any locations where your soldering created a short circuit - only incomplete repairs due to the soldering.
                                        You definitely want to fix these YSUS and ZSUS issues because they will only cause you problems.
                                        Regarding the power supply, please check fuses for continuity and test all diodes and transistors for shorts. There is an issue here that is causing your no voltage issue.
                                        • legonch
                                          • Feb 2019
                                          • 49
                                          Update.
                                          I ordered a new power board. I couldnt find anything off following your instructions.
                                          New power board installed. All cables hooked up except the ysus and zsus boards.
                                          Redid all the solder I initially did. Totally clean nice solder job now.
                                          I still have the same condition. The voltages measured at the 5v, Va, and Vs are exactly the same as when the other power board was installed. Also the voltages on the fuses remain the same. Lower fuse on power board reads 120, the other two read 62-62 volts.
                                          Where do we go to now?
                                          • grimacelord
                                            HP 15-EH1070wm - Black Screen With Power LED.
                                            by grimacelord
                                            I have an HP 15-eh1070wm laptop that came to me for the same reasons I am starting this thread. The charging LED appears when the laptop power adapter is connected and the power LED appears when pressing the power button, but nothing appears on screen.
                                            First thing I did was take off the bottom panel and remove the battery and then press and hold the power button for 30 seconds and then reinstall the battery and power on. The fan spins and this time, the back light illuminates and a brief message appears on the screen for about 1 second saying something along like,...
                                            01-28-2023, 10:50 AM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • burntonnerings
                                            Acer K272HUL blue power light but black screen, power supply is ok
                                            by burntonnerings
                                            Have had two Acer K272HUL monitors die with the same symptoms:
                                            - Blue power light is illuminated while the monitor is plugged in
                                            - Black screen (no splash screen, etc.)
                                            - Power button doesn't do anything
                                            Opened it up and checked for bad caps and components, evidence of burns, etc. - everything looks fine.
                                            Power supply voltages are fine.
                                            There are some signal lines on the power supply harness that goes from the power supply to the logic board, not sure what these should be at.
                                            Anyone have any ideas?...
                                            12-09-2023, 10:22 PM
                                          • rybby
                                            Acer Aspire 5 A515-51 power on but black screen
                                            by rybby
                                            I have an acer aspire 5 a515-51 that turns on but has a black screen.
                                            This laptop has the same symptoms as https://www.badcaps.net/forum/showth...er+aspire+a515, however mine is a different model Acer Aspire A515-51 (without the 'G'). There is no onboard ram on this laptop.
                                            Description of the problem is the same: I press the power button, the fan spins for a few seconds and then stops, the computer stays on all the time (led blue), the cpu and gpu are lukewarm. If I leave the pc on for a few minutes the fan starts...
                                            06-16-2023, 09:41 AM
                                          • samolo75
                                            Asus Laptop GL702VS black screen power LED on
                                            by samolo75
                                            I am fighting with this laptop and I am suspecting of the GPU, but it would be great to know your opinion.
                                            The laptop originally does show black screen (no back light) but the power button LED turn on and off when pressing it.
                                            I did the next trouble shooting with no changes
                                            - Disconnected the battery and try just with the power supply
                                            - Disconnected all power sources, even the CMOS battery and held the power button for 40sec.
                                            - Disconnected hardrives
                                            - Deplaced the RAM
                                            - Disconnected the Wifi module
                                            - I connected a external monitor to the...
                                            03-31-2021, 03:16 PM
