Samsung UN55F6300AFXZA appears dead, stand-by present, main board suspect
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    #41
    Re: Samsung UN55F6300AFXZA appears dead, stand-by present, main board suspect
    I was able to successfully de-pin both B5V terminals from the main board connector....piece of cake! I was sure to isolate them from the chassis and each other before taking readings.
    B5V is still absent from the PSU
    They call me......."threadkiller"
      B5V and B13V are switched power supplies that will not be present until PS-ON from the main board is present to the power supply board to turn them on.
      The power supply board has pull-up resistor to keep the PS-ON pin of the power supply HI, but when the MD is connected to the PS board, that PS-On line is kept LO by the MB, it should let the PS-ON go HI when TV is turned on but that is what the MB not doing right now..
      • MASTER_TECH_101
        • May 2018
        • 12
        No need go through all this nightmare of troubleshooting.
        99% of time this board has bad Flash IC
        • DXseekerMO
          • Feb 2018
          • 1119
          • US
          #44
          Sorry I had them backwards. A5V is the stand-by line. Thanks budm. No luck on a schematic for this board here either.
          Are you referring to the main EEPROM?
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            #45
            Nope - flash IC is the NAND flash. The square chip right above the optical connectors if I'm not mistaken.
            Wattevah...
            • DXseekerMO
              • Feb 2018
              • 1119
              • US
              #46
              That chip looks like its BGA. If this is bad and that is the case it looks like I'm SOL for fixing this one without a re-work station?
              Has anyone come up with a schematic for this or have any further pointers? Thanks everyone
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                #47
                Yes it is BGA, but even if you had a rework station, obtaining a similar chip + programming it would probably outweigh the price/effort of a new board entirely. Common fault, not worth bothering IMO.
                Wattevah...
                • nomoresonys
                  • 12272
                  • U.S.
                  #48
                  55 inch, nice size, worth a board I would say.
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    #49
                    Yes.
                    Wattevah...
                    • DXseekerMO
                      • Feb 2018
                      • 1119
                      • US
                      #50
                      Yes.
                      I agree with both of you, completely. The TV itself is in premium condition, not abused and super nice otherwise. It is missing the remote tho.
                      Here's my issue, I bought it this way not knowing if the flap is any good. I can tell when the backlights come on it isn't cracked, but I've never seen it work. The board is big $ for an old TV, about $170.00 laid in minus the core charge. On the other hand....at least it's still available new! lol I'm not sure I'd trust a used board unless it was from my own stock and got a good trial run before selling it.
                      https://encompass.com/item/9820929/Samsung/BN94-06969A/
                      Add that to the $20 I gave for it and another $10.00 for a remote and this would be my cash investment.
                      I believe at best this TV is worth no more than about $250.00, even though its 240hz and smart, but those features aren't as valuable as 4K and faster processing. With some of the new pricing I'm seeing that $250 is more likely going to be $225 or even $200 locally.
                      When I look at risk v. reward I think the risk is too high to pay any more than $50.00 for a good working board. The two used ones I found online are twice that and none of the repair services offered seem to cover this symptom. Finding a whole TV with a busted flap and a good main board are long odds.
                      The first three commandments in what I do are "Thou shalt use integrity with wisdom", "Thou shalt use Flux" and "Thou shalt double their money". I don't want to sound like a greedy jerk or nothing but in my opinion if I can't double up it may not be worth it.
                      Does anyone feel my opinion of the TV's value is under or over the mark? Does it make sense to everyone else to double up or go home?
                      At the present I'm inclined to put it back together, wait for a parts TV and see if there's a greater power than odds to help me out. It wouldn't be like this hasn't happened before.
                      Like the odds of finding a 2011 Samsung B650 plasma for parts right when I was working on another one, add the longer odds for it coming from McAlester OK some 225mi away, being a fully working TV with the exact part number main board I needed, all of it's original stickers still in place and a stand in surprisingly perfect condition considering it came from a recycle house.
                      I've faced the longest of odds before....more than anyone knows....yet it always works out and here comes an answer.
                      Does anyone have further advice, other than to replace the main board? I tried heating the chips, maybe I'll try some freeze spray on them and see if there's any change. I'd hate to throw in the towel if someone might have an idea!
                      • nomoresonys
                        • 12272
                        • U.S.
                        #51
                        I agree, the used market is tight, might be better off parting it out, definitely doesn't justify a new board at 170, like you said no meat left on the bone.
                          I believe Nick's TV offer repair service for the main board, you may want to contact him.
                          • monybito
                            • Apr 2019
                            Hi all, I am looking for a bit of help. I have a Samsung UN55F6350 LED. The Screen will not turn on, I have audio. Already replaced the Tcon board, that wasn't it.
                            I was checking the standby voltage and wasn't getting any on the Power Board harness (plugged in)
                            while still plugged in, but tv OFF, I unplugged the harness from the Power Supply board to the main board, as soon as I did that the SCREEN turned on - that means my LED's are good... what is wrong, Main board or Power Supply board? assistance would be greatly appreciated.
                            • Dannyx
                              CertifiedAxhole
                              • Aug 2016
                              • 3912
                              #54
                              So BL_ON is not present at the pin when the main board is connected and TV is on (has sound) > bad main board I would say. Depending on your skills and how much effort/time you wish to invest in this board, you could try searching for a schematic for the board and tracking down the BL_ON signal.
                              Alternatively, as a quick and dirty "fix" you can "cheat" by pulling out the BL_ON pin from the plastic socket at one end so the pin is floating. That way, you'll have the backlight on all the time Do this first to check if all other functions are working correctly.
                              Wattevah...
                              • DXseekerMO
                                • Feb 2018
                                • 1119
                                • US
                                #55
                                I still have yet to find a main board for mine. They're scarce as hens teeth!
                                • monybito
                                  • Apr 2019
                                  check shopjimmy.com they have both the powersupply and main boards.
                                    +1 on the quick and dirty fix, if everything else are OK then you can use other control signal to simulate BL-ON.
                                    • DXseekerMO
                                      • Feb 2018
                                      • 1119
                                      • US
                                      #58
                                      Just wanted to update this thread. I ordered a main board that should be here tomorrow, so I got the TV on the bench and figured "what the hell, let's bake this turd"...so I pulled the main board and baked it for 10 minutes at 380 degrees. Low and behold the stand-by light came on. Not only that it responded to the remote. The TV did not turn on fully but when I hit the power button on the remote to turn it off the stand-by light quit flashing and went solid on.
                                      I just baked it again at the same temp for 12 minutes. Guess we'll see what happens.....
                                      • DXseekerMO
                                        • Feb 2018
                                        • 1119
                                        • US
                                        #59
                                        No taco. Will update when the board goes in.
                                        • diif
                                          • Feb 2014
                                          • 6978
                                          • England
                                          #60
                                          It's not a cake, it is not being baked you are trying to reflow the solder under the processor.
                                          Lead free solder needs a bit more than 200c to melt.
                                          Not that I suggest putting a board in the oven especially one for food.
                                          • SkishyIshy
                                            Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                            by SkishyIshy
                                            Hey All,
                                            I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                            I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                            I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                            03-17-2021, 11:44 AM
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • ShadowAi12
                                            ASUS ROG STRIX B550-F GAMING — Board not powering on properly
                                            by ShadowAi12
                                            I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
                                            • The board enters a "ready to power on" state after plugging in the PSU.
                                            • Pressing the power button increases power draw.
                                            • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
                                            Measurements:
                                            (taken after pressing the power button, while the board is attempting to start)
                                            • H_SKTOOC#
                                            06-11-2025, 01:05 PM
                                          • fharris1977
                                            Vizio D50u-D1 Dead Set No Standby
                                            by fharris1977
                                            Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                            12-28-2023, 10:25 AM
                                          • ChristianBr01
                                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                            by ChristianBr01
                                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                            04-23-2025, 01:48 AM
