Many burnt leds
  • Nawual
    • Jul 2016
    • 65
    • Spain
    Many burnt leds
    I have a TV that turns on and can be heard but it does not give an image, although the lcd is fine since I have been able to see it with a flashlight.
    The PSU gives the correct voltage, 168 volts, and when checking the backlight it has more than 30 faulty LEDs.
    What do you think of this failure and I could protect the LEDs so that it does not happen again?
    Thanks.
  • capwizard
    • Jun 2016
    • 1991
    Re: Many burnt leds
    Que tv es ? The model no. and make of the TV?
    If TV has more than 30 faulty LEDs. You podria use this method.
    Keep the bad leds and add more leds strips inside the panel. entiende Ud.
    https://www.badcaps.net/forum/showthread.php?t=74583
    • electomech-fixer
      First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
      by electomech-fixer
      I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
      I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
      09-15-2025, 01:42 AM
    • ohren
      Samsung ue55nu7096u - no backlight - faulty LEDs?
      by ohren
      I'm looking at a Samsung model ue55nu7096u that I've only ever seen in a non-working condition, i.e. I don't know if the failure was progressive or instant.
      Symptoms
      No backlight at all — LCD and logic board are working normally. Resetting all settings and installing system updates has no effect.
      I tried reseating the connectors between PS and logic board, and PS and panel. No difference there.
      I could not find a service manual.
      Measurements when powered on
      Bulk cap: 388 V. Stable....
      04-04-2022, 02:58 PM
    • Pipolups
      Corsair K70 LUX RGB dying LEDs
      by Pipolups
      Hi there !
      I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
      Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
      10-08-2024, 11:58 AM
    • spintop
      Toshiba 39P2300VE, faulty backlight LEDs
      by spintop
      Hi
      No backlight issue with the TV.
      Opened up panel and found 3 bad leds in the panel.
      LED is about 3mm x 3mm, i assume they are the 3030 type. Label on the strip is :AG-D1 94V-O 1345 ( 6 leds in a strip )
      Thinking of buying and replacing the individual SMD leds. Found some online, but they have both 3V and 6V. Not sure which one i need, any idea how to tell ?
      Thank you....
      08-22-2020, 09:43 PM
    • dicky96
      Zotac GTX 260 burnt component - can anyone identify?
      by dicky96
      Hi guys
      This Zotac GTX 260 had a high side MOFET on one Vcore VRM phase short circuit Drain to Gate (Not short Drain to Source)
      This has burnt out the drive IC L3E (ADP3110A) and also an SOT-23 device very close to the driver IC. According to the PCB markings 'Dxxx' this is likely to be a diode.
      Basically the VRM has 4 phases, two powered from one 6 way connector and two powered from the other 6 way
      I would assume each pair of phases are basically identical, the burnt out phase has SOT-23 devices WW1 plus the burnt one.
      The good phase...
      12-01-2021, 01:02 PM
