LG 42LB5600-UZ No Backlights, All Test Good
  • philtvman
    • Jun 2016
    • 94
    • America
    Getting no backlights with this one. Checked LED+ to chassis when plugging the TV in and the voltage spikes to 260ish then drops down to around 100 signaling to me it has an open LED circuit. Opened it all up, but all the LEDs turned on just fine.
    Any suggestions where to go from here?
    Edit: Guessing one of the LED cables wasn't secured all the way into the connector. Pushed it in when testing the LED voltages and now it seems to be working fine now.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8126
    Re: LG 42LB5600-UZ No Backlights, All Test Good
    yeah, just wanted to say to check the cables and connectors.
    • philtvman
      • Jun 2016
      • 94
      • America
      Spoke too soon. Tested fine for about 15 minutes, then backlights all turned off.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Bridge the interconnectors (if that applies) or just solder the wires in place.
        • philtvman
          • Jun 2016
          • 94
          • America
          Double checked all LEDs with a tester, all checked out fine. I hooked it all back and up and set the backlight brightness to zero. The set worked fine for a couple hours, then the backlights turned off. LED voltage was around 84 after they shut off.
          Ideas?
            84V is the feeding Voltage to the LED driver boost converter circuit, so if you leave the black probe on the chassis and Red probe on the LED+ and then turn on the TV you will probably see the Voltage jumps up over 200V, sounds like you have open circuit some where in the LED string or bad LED's to me.
            Tester only puts out 30mA so it is not 1005 real test as compare to real LED drive current of 300 ~ 400 mA range and that is when bad connection (bad contact resistance), or bad LED will show the symptom.
            • mecha1166
              KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
              by mecha1166
              KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
              11-25-2024, 05:22 PM
            • SluggerB
              Help with trying to fix phone that is not charging (Pics inside)
              by SluggerB
              I have two TCL A30 phones.
              Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
              New Phone: Works fine, bought as a donor board to try and repair Old Phone
              My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
              08-12-2024, 08:11 AM
            • cappernicus
              Acer Spin 5 - Lenny_ICL (19771-1) -- Dead - PM_SLP_S3# held low
              by cappernicus
              Laptop model: Sp513-54n-74V2
              Testing power rails (separated by chip) reveals:
              19V_DCBATOUT - (active)
              5V_AUX_S5 - (active)
              5V_S5 - (active)
              3D3V_AUX_S5 - (active)
              3D3V_S5 27Ω - (good) - enabled by Nuvoton chip
              1D8V_VCCIN_AUX - (good) - enabled by 1D8V_S5 PG signal -- (dependent on 3D3V_S5)
              1D8V_S5 41Ω - (good) - enabled by 3D3V_S5 PG signal
              1D05V_VNN_BYPASS - (good) - enabled by 1D8V_VCCIN_AUX PG signal...
              09-25-2024, 05:19 PM
            • triplefour
              ONN 100012588 Has fluctuating Voltage on PSU 12v
              by triplefour
              Hello all got another TV here im puzzled by. why cant they all be easy fixes that just need a little love and some tape???
              anyway i go to this guys house to look at an ONN 100012588
              this is my first time looking at one of these brand of TV's.
              TBH i have low expectations because i see ONN as the cheap walmart brand that suddenly popped up selling the cheapest version of all kinds of tech things. and someone sent me a ONN flash drive with some data on it with some recordings they wanted me to check out and it immediately broke and corrupted the data and i was unable to...
              09-14-2022, 07:41 PM
            • FuzzyOwl
              Denon AVR-X3600H No sound even to pre outs in direct analog mode. Help please!
              by FuzzyOwl
              Hi, I have a Denon AVR-X3600H I'm trying to repair. I have no electronics repair experience but I have a multimeter, service manual and a will to fix it (https://device.report/m/d5de8c00e617...f63147aba9.pdf)
              Everything seems to work except for no sound even through the pre outs. However I will get sound using Zone 2 pre outs.
              Only digital symptom I can tell is it will soft lock when in the Speakers/Test Tone menu and be unable to adjust +/- db during the test tone.
              I've followed the trouble shooting guide, audio check...
              12-05-2024, 11:54 AM
