40pft4100/12 bootloop
  • Acca
    • Jul 2017
    • 47
    • Italy
    Hello, I got this philips TV (chassi "tpn15.1e la"), that when plugged in tried to boot up, shows the philips logo (the old one, completely blue background, not hte newer white on black) and then just reboots.
    I tried
    1)updating its firmware with the one from the website
    2)using a couple of emptyburn firmwares
    3)contacted philips to ask if there was a new emptyburn firmware and they sent me a couple links but they didn't work.
    The mainboard uses a nand for the firmware and I don't (yet??) own a nand programmer.
    I tried a couple different usb drives, tried fat and fat 32.
    Some days afted I got this tv someone brought in another philips tv and my flash drive and update file worked flawlessy, so I take the issue is not there.
    Has this happened to any of you, have you found a solution (other than buy a new motherboard) ?
    The files philips sent me are:
    TV from 2015: https://app.box.com/s/tsrq6lnyzedopdw3k78hzu1htmkvp04y
    TVs from 2016 and 2017: https://app.box.com/s/omze9q11q2iizvjqd51ev82kbaswox7d
  • MF ELETTRONICA
    Hitachi 32HB4W56I NAND Firmware
    by MF ELETTRONICA
    Hi guys, have a nice day. I wanted to ask if anyone has the bin file for this nand MT29F4G08ABAEA. I'm attaching the model of my TV, the motherboard and the panel number. Please, if anyone can help me, thanks.
    11-28-2024, 02:35 AM
  • duwane
    A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
    by duwane
    Hi All.
    Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
    The issue:
    Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
    10-26-2022, 07:02 AM
  • tranquility
    Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
    by tranquility
    i want to repair an Onkyo TX-NR809 receiver.
    symptoms:
    on power on, display appears and i hear one click. enue functions is given.
    - no hdmi output
    - audio output not tested, but i think it is not there
    - usb sticks are not recognized
    if i read out the chips with display+standby button + tone+
    both dts show only ????
    chip is D830K013BZKB4
    things i have done:
    - reflow of the dts chip without taking off and reballing
    - changed the aluminium caps without the big one with 25v because i dont...
    08-25-2025, 01:04 AM
  • zklgfs
    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
    by zklgfs
    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
    08-11-2025, 02:14 PM
  • TheUser
    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
    by TheUser
    Hello to everyone ,
    This is my first post here, and i would like to share with you a small story in case you can help me.
    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
    02-10-2024, 02:07 PM
