Samsung UE55KS9000 Picture Jumping / Cycling
  • googereviewinguser
    • Jan 2019
    Hey guys
    Bit of a last ditch attempt this, but figure it's worth the question.
    Picture is jumping on the tv. As per video :
    https://www.youtube.com/watch?v=j4ZFHuxx3vw
    Then leave it going for a while and it starts to cycle :
    https://www.youtube.com/watch?v=vhq2-czrEI0
    Replaced the main board.
    Replaced the power board.
    Replaced the ribbon cables to the tv.
    No change, so I think this pretty much confirms it's the Panel (unless I've been very unlucky in picking up new boards with the same problem)
    Any other suggestions ?
    (bin it, I know ...)
    Thanks!
  • nomoresonys
    • 12206
    • U.S.
    Re: Samsung UE55KS9000 Picture Jumping / Cycling
    Could be a tcon issue.
    • nomoresonys
      • 12206
      • U.S.
      Don't see any tcons for sale, guessing it's integrated and not replaceable.
        • Jan 2019
        Yeh I cant see any tcon board in there.
        • nomoresonys
          • 12206
          • U.S.
          Could try a system reset and a firmware update if available.
          • budwich
            • Jul 2015
            • 3097
            post a picture of the back to show the boards / interconnections.
            • capwizard
              • Jun 2016
              • 1991
              I bet you it is Chip-on-film (COF) one of the IC chip on PI film has problem or tcon-on-screen.... one of the synchronization signal has intermittent problem.
              I think you can use the freeze spray to locate the problem.
                09-07-2024, 05:50 AM
              • TR103
                by TR103
                - it keeps rebooting
                01-22-2025, 04:12 PM
              • JJAAMM
                by JJAAMM
                Problem
                07-06-2023, 06:01 AM
              • high-tech
                Samsung UN55F7050AFXZA ver. TD01 power cycling
                by high-tech
                Hello everybody, I could use some help on this one... It's got me guessing...
                I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
                (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
                (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
                (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
                (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
                9. ground (PWM2) 10. 0.9 volts cycling...
                09-15-2020, 03:39 PM
              • Dodgethis
                Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                by Dodgethis
                Hello all,
                This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                09-11-2024, 07:39 AM
