Sony KD-55X9005C repair manual
  • Alschepmist
    • Jul 2018
    • 70
    Hi to all i have that tv sony Sony KD-55X9005C with backlight problem have anyone repair manual or can you tell me if i have to open the lcd ? Thanks and best regards
  • R_J
    • 9626
    Re: Sony KD-55X9005C repair manual
    Measure the voltage going to the leds's
    • Alschepmist
      • Jul 2018
      • 70
      Thanks for the reply but i know that led are defective because i see no backlight on 3 cm display is black
      • Diah
        • Feb 2013
        • 6614
        you have Edge LED BL. not easy for you to repair if you are not familiar with electronic and soldering.. suggest you living with it as its
        • Alschepmist
          • Jul 2018
          • 70
          I have already repaired backlight before but not on sidelight and i want to know if in this model i have to open the display or not.
          • Alschepmist
            • Jul 2018
            • 70
            Or service manual
            • Diah
              • Feb 2013
              • 6614
              yes you need to take the LCD out and all plate until you reach the bottom and then you need to screw out the Aluminum base plate where the LED string mounted on it. no need any service manual for this
              • Alschepmist
                • Jul 2018
                • 70
                Ok thanks
                • R_J
                  • 9626
                  This model seems to use the GN1T chassis, search for that chassis number and you may find a service manual for a different model that is close, but you will find they are not of much use and rarely have the power supply schematic.
                  • Alschepmist
                    • Jul 2018
                    • 70
                    So i have opened the backlight i had not to open entyre lcd panel only the back i have test the led and they works perfekt could be the led driver board?
                    • Alschepmist
                      • Jul 2018
                      • 70
                      I think i have the problem found one led is not soldered how that could be possible ? I just gonna try tho solder that
                      • Alschepmist
                        • Jul 2018
                        • 70
                        Here is a picture
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          Are you certain it has not burnt and overheated and fallen off. The black spot on one of the leds next to the empty space looks a little suspect.
                          • Alschepmist
                            • Jul 2018
                            • 70
                            The black spot is from me to mark the leds and i have all the leds tested they works all i have yet only to tray to solder the led it can be a little complicate
                            • Wilderone
                              • May 2018
                              • 76
                              You will not be able to use a standard soldering iron, you will need a hot air station or heating plate.
                              • Carlos#2003%
                                Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                by Carlos#2003%
                                Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                02-15-2024, 07:52 PM
                              • kramer826
                                Sony KD-55X8500F service manual BL-on signal
                                by kramer826
                                Hello , I am looking for a service manual or schematic information to find out where to measure BL-on signal backlight on signal from the mainboard.
                                I have a tv which works fine and a spare main board that Ii am trying to fault find that is not turning the backlight on,6 flashes.
                                The backlights work ok with other main board.
                                Thankyou for any information
                                07-14-2023, 03:50 AM
                              • dkneyle
                                Sony KDL-46HX850 Can't upgrade/update firmware
                                by dkneyle
                                Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                09-25-2024, 10:44 PM
                                Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                09-06-2024, 05:27 AM
                              • Xenon-Codex
                                Need service manual for Sony STR-110
                                by Xenon-Codex
                                I can't find from anywhere. All channels are not tuning perfectly even with the roof antenna, and the sound is distorted.
                                Sound from AUX is good....
                                02-23-2023, 01:56 PM
