Bush idlcd26tv22hd 17PW15-8 issue
  • CuriousJohn
    Ordained
    • Dec 2018
    • 134
    • Great Britain
    Hi folks, I hope somebody out there can clue me up on this 17PW15-8 i have been reading lots of threads on it and already repaired the STBY 5v as obtained this set dead. Its an older tv now but still tidy and the audio is nice has big speakers compared to modern tvs.
    Anyway, as I said repaired this psu 5v STBY and had it running for a day noticed a bit of whine fromthe TV on the day it was running but thinking it was from cold cathode inverter thought about stripping it down to check prob should have oplayed with turning it down to see but the next day poweredthe set to the mains first thing and sure there was a pop, thought did I really just hear that... Standby light on would not power up..
    The set will not come out of stby now and when mains is applied the 33v 12v
    and 24v comes up for a second during the test but then off leaving just STBY 5v and 3.3v. Cant see any obvious damage and already applied a repair kit replacing the following caps:
    C801
    C901
    C892
    C817
    C877
    C878
    Before it went pop the day after I repaired the STBY 5v the psu was working fine even when disconnected and forced on all outputs where good. Today not so good, the primary will not come on and stay on connected to mb or not.
    Now wondering what has gone on with it where did that pop come from, IC802 seems ok it has vcc 11.13v, Q803 drain sits at 331v and gate is 0 all way to pin 7 of IC802 so obv not coming on some reason? Vcc1 and Vcc2 are present with IC828 also having 13v on its ip and 11.27v on its output with 10v fed back to adjust via the resistors dropping by roughly 1.25 from 11.27 to 10 volts as a LM317 is supposed to behave. Mainboard is pulling pl803 pin 6 to ground when power button is pressed.
    The weird and annoying thing i noted was that the the 33v + 12v on pl803 and 24v on other outputs only come up intermittently at start when mains is applied during the self test, something like 1 in 5 times sometimes less or more so obv something is wrong I hate intermittent faults.
    Does anybody here have any ideas about where to look next also i cant find the source of Vcc1 or what value VF main should be it is coming into IC828 as 13v with PSU in standby...
    I admit this is a complex psu any help appreciated.
  • petehall347
    • Jan 2015
    • 4450
    Re: Bush idlcd26tv22hd 17PW15-8 issue
    Originally posted by CuriousJohn
    Anyway, as I said repaired this psu 5v STBY and had it running for a day noticed a bit of whine from the TV on the day it was running but thinking it was from cold cathode inverter thought about stripping it down to check prob should have of played with turning it down to see but the next day powered the set to the mains first thing and sure there was a pop, thought did I really just hear that... Standby light on would not power up..
    was it not on mains to start with ?
    pop has likely left a visual mark .
    did you check standby light voltage ?
    • CuriousJohn
      Ordained
      • Dec 2018
      • 134
      • Great Britain
      after replacing Q809 stby 5v regulator which was in fact the ic version the tv ran fine for a day then was turned off over night, first time plugged in the next day, thought i heard a pop but cant be sure and no signs of any pop like damage on the psu and the set would not power on. STBY 5v present and red led remains on, stby 3.3v also ok. MB is sending 3v to pin 6 pl803 and dropping to 0 when power button pressed but comes back up to 3v after a second or so psu not playing?
      Just had another look at it now and seems that the 33v, 12v and 24v do not come up on the self test any more when mains is applied so things getting worse or maybe better from the point of view of getting to the bottom of it. Mosfets seem to test ok using multimeter basic test. Its late, maybe gremlins will vacate as quickly as they came overnight but i doubt it.
      till the morning my friend...
      • R_J
        • Jun 2012
        • 9625
        Check the voltage across C819 (220µf/450v) It should be about 400v If its only about 340v, The pfc circuit is not working.
        Check Q803 and R829/830.
        If you have 400 volts, check the resistance of Q813, Q814 & R971.
        Using hot ground as ground (- of C819), check for VF_MAIN voltage on ic828 pin 3, then when power is pressed check for voltage on ic828 pin2. This is the VCC voltage for IC807, pin 15
        • CuriousJohn
          Ordained
          • Dec 2018
          • 134
          • Great Britain
          Hi and thanks for response, to confirm V across C819 remains steady at 331V the pfc circuit is having issues as per op. Since testing yday as per my last post the primary outputs have totally vanished now so something was failing bad and has now totally failed imo which i prefer tbh from a fault finding perspective.
          So yday was not a good day I had raging headache all day as a result seemed to have mixed up IC 828 and Q835 dont know what i was thinking as result my op should be disregarded when it comes to the measurements.
          Today following your advice i retested IC828 and found it to be ok, the results are below in case i am mistaken All measurements taken on hot side are with ref to hot GND on C819.
          Self test means when mains is applied to psu
          power on when on button pressed
          IC828 LM317T
          __Pin____Self test__Standby__Power on
          2 (Vout)-----13---------1.26------13 > 1.26 (drops back after a second)
          3 (Vin)------15.3-------16.5------16.8 > 15.3
          If VF main is supposed to be around 16.5v in standby mode then its ok.
          I could not find Vcc1 source as diagram shows it coming in to top of IC828 pin3 but i am now seeing this as diag error as it comes out of there from IC828 going by what your saying about it being IC807 Vcc, i cant find anywhere else on this diagram where Vcc1 is generated from makes sense it supplied from LM317.
          R830 47Ω tests in circuit as 60Ω both ways so seems ok to me. R829 not fitted.
          R971 47Ω tests in circuit as 60Ω both ways
          Im going back to test Q803 and then will start sniffing around IC807 theres a diode on Vcc1 into it so first port of call that...
          • CuriousJohn
            Ordained
            • Dec 2018
            • 134
            • Great Britain
            Q803 measures ok with multimeter same readings as Q813 + Q814 being 470Ω across +S > -D, -S > +D = <>
            Im now happy to wiggle my finger at IC802 because there is Ov come out of pin 7 at all times so nothing turning Q803 on although there is some inputs on IC802 to check before im 100%.
            On a side note IC807 is getting Vcc1 at both pins 13+15 and theres 5v ref on pin 16 and i checked TR804 all windings intact.
            • R_J
              • Jun 2012
              • 9625
              Can you recheck R830, the schematic lists it as 0R47Ω which is 0.47Ω (close to zero ohms) also R971 is listed as 0R47, so check what is printed (or color code) on the resistors
              VCC1 source for ic807 is from IC828 which is normally off but turned on with ON/OFF signal from main board
              The ic828 (regulator ic) also supplies vcc2 for IC802 (PFC circuit) When you push power on, you should have vcc2 voltage on ic802 pin 8, and if the pfc circuit is working the voltage on C819 will go from 340 volts to around 400v, this circuit needs to work as circuit with (q813/814) requires 400v
              You may not see any voltage on pin 7 of ic802, it will be a pulse (you would need a scope to see it)
              • CuriousJohn
                Ordained
                • Dec 2018
                • 134
                • Great Britain
                Hi and thanks for the correction and info, was wondering if Q803 was driving or just switching the primary to ground in a brutal way i will probably realise soon how stupid that thinking is/was ha!
                I confirm both R971 and R830 are indeed 0.47 and each measure around 0.6 out of circuit both in good condition so put em back in.
                Vcc2 is present breifly at mains on and when power on is pressed.
                As a bonus went to Mosfet checking school this afternoon and pulled Q803, Q813/814 and all test proper out of circuit so put em back in.
                So earlier also looked at pins 1-4 of PFC IC802
                Data sheet: https://cdn.badcaps-static.com/pdfs/...1fdeef964c.pdf
                when mains applied to psu, Pin 1 (inv) is around 2.12V steady but according to datasheet needs to get to 2.465v min and pin 2 seems to be intermittent showing 6v briefly dropping but only now and again at other times it sits at 0.5 ish so floating, not sure if symptomatic of bad IC802. Looking at pin 3, c805 and R803 seems to be signs of past solder flux on the pcb, R803 measures fine at 27K, C805 doesnt look to clever has burnt flux or crud on it tests in the high M Ohms, charges up tho, I may well take them off circuit and test proper whilst waiting for replacement IC802 to arrive but did re solder them just to be sure as initially found the ground side to be floating at 0.2 ish so cured that.
                Cheers
                • R_J
                  • Jun 2012
                  • 9625
                  So IC802 is a L6562 and not a IRF7314 as on the schematic? Pin 1 will likely be low as the voltage comes from +400v but since the pfc booster is not working, that voltage would only be around 340v
                  If those C805 & C870,C808 are small electrolytics, they could be bad.
                  Q803 is driven by ic802 at 70khz, so yes it does switch the primary of TR806 to ground BUT at 70khz, that action boosts the 340 volts to 400 volts on the other side of D824, Thats why the voltage on C819 is important to check as it wil tell you if the pfc is working or not
                  • CuriousJohn
                    Ordained
                    • Dec 2018
                    • 134
                    • Great Britain
                    Yeah IC802 is a L6562 not the dual mosfet shown on schematic.
                    You just answered my next question lol as was wondering what freq it was switching at, going to get an old scope out later been a few years its time I got smarter only so much can do with a multimeter!
                    • CuriousJohn
                      Ordained
                      • Dec 2018
                      • 134
                      • Great Britain
                      When I was training at college over 20 years ago now for City & Guilds 224 nobody ever mentioned PFC it just did not exist to us, we had lopt frequency drilled into us instead lol and psu regulation ofc. I understand pfc circuits now required as an efficiency measure so interesting to see how things have moved on and why less power stations are needed haha, btw did three years at college and got the full C&G 224 prob obsolete now but never went into industry with it went off in a totally diff direction for 20 years as you do....
                      • CuriousJohn
                        Ordained
                        • Dec 2018
                        • 134
                        • Great Britain
                        Good news today replaced IC802 but the set still would not turn on however the self test voltages returned. Also noted pin 1 of PL807 should be 2.5v fed from 3.3v via two diodes but was spiking at 8v varying from 6-8v even with PL807 unplugged but the 3.3v line was steady put it down to meter error i just dont know. After investigating couldnt find much wrong tho bit of a mystery did find two almost dry solder joints and retouched here and there.
                        After that first application of mains heard a high pitch squeek during self test, got excited if honest and tv then powered up fine
                        I dont like the level of high pitch whine coming out of TR06 maybe a new C819 maybe bit bigger any thoughts? Not sure if I just got really sensitive hearing but sure is audible to me even from a foot or two away good job this tv's audio setup is meaty!!
                        • CuriousJohn
                          Ordained
                          • Dec 2018
                          • 134
                          • Great Britain
                          Scrap that it will not start again only left it unplugged for an hour.
                          • chopduel
                            Bad mains power causing TV malfunctions?
                            by chopduel
                            I've been living in the same apartment for about 5 years now, and moved into it with my old Samsung plasma TV (PS51F5500).
                            Ever since we've moved in, we would sometimes see strange power-cycling behavior. For example:
                            • TV would randomly turn off then back on.
                            • TV would turn off and the LED light would blink for a while (over a minute sometimes) until eventually it went back to a regular off state and could be turned on
                            • Sometimes it would require disconnecting the mains cord from the TV, waiting several minutes, then putting it back in and turning the TV back on. This had limited
                            12-29-2024, 03:20 AM
                          • FlailingEngineer
                            Help with Bush Tv (Vestel 17mb95m Mainboard)
                            by FlailingEngineer
                            Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                            Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                            05-31-2023, 06:52 AM
                          • tyler123456
                            Need help identifying an IC chip on a Bush DAB radio (BD-1801)
                            by tyler123456
                            Not sure whether anyone can help but I'm trying to identify the IC chip in the photo below.
                            I purchased a faulty Bush DAB radio (model # BD-1801) and identified that an IC chip was blown on it. Unfortunately, I couldn't read the manufacturer name / model number of the IC chip.
                            I purchased another (working) BD-1801 so that I could open it up to find out the IC details - but the IC chip details are missing (as you can see in the photo.)
                            Given the two huge blobs of solder either side of it I'm guessing it regulates power(?)
                            Anyone...
                            08-16-2024, 12:51 PM
                          • Johnny.p
                            Bush WI-1810 Internet Radio
                            by Johnny.p
                            I recently bought an internet radio Bush WI-1810, it came with a power supply that when plugged in promptly damaged the radio. I discovered too late that the radio was 6v and the supplied adaptor was 12v. The radio still powers on but the wifi is not working. I have attached a few pictures- Image 2 showing the board with damaged component top right labelled U8. There are several other similar components like U9 (image 3) that I'm wondering could be a replacement.
                            U9 has a code on it S5EJI- I have searched several smd code sites and the nearest I can find is for a mark of S5E -listing shows...
                            11-25-2023, 04:18 AM
                          • JohnML1975
                            Panasonic TH-P65ST60A no STBY light no backlight no power
                            by JohnML1975
                            Hello All
                            Started working on this TV today
                            As I remove the back will share some photos and findings
                            The problem I am having is in the title of this thread
                            I still need to proceed my trouble shooting
                            Started a thread so that I can share with all
                            Any inputs are welcome
                            10-25-2025, 04:50 PM
