55ln620v LG flash then no backlight
  • wreksta
    • Aug 2013
    • 508
    • england
    as above took set apart down to leds all leds light using
    multi meter
    any ideas what I should check
    next please
    cam test voltage from led connector on power board ?
  • Diah
    • Feb 2013
    • 6435
    Re: 55ln620v LG flash then no backlight
    as you take the LCD apart, you can start your LG with out Panel, then with eyes at start up you will find that one or more LED wont light on. this best way to you narrow which LED Fault at start up
    • zomi
      • Nov 2011
      • 509
      test the leds
      check the connectors sometimes these go faulty, hard wire connectors..
      if any failing led found
      best to buy a full set of new strips.
        You need to upload good clear pictures of the whole backside of the TV showing all the boards and also good clear straight shot of the top and bottom side of the power supply/LED driver board.
        • wreksta
          • Aug 2013
          • 508
          • england
          hi all I've tested all the leds I've even swapped power supply with a known working one and logo flashes then no light so I'm thinking main board
          is there a fix for the main board
          thanks I'll upload voltages soon
          • wreksta
            • Aug 2013
            • 508
            • england
            hi there just an update
            led+ volts shoot to 125v dropping to 82
            led- volts shoot to 42v dropping to 5v
            same for the other 2 + /-
            both same on two power boards
            all leds light with tester even individualy
            • zomi
              • Nov 2011
              • 509
              Jump all the connectors directly with wire
              is not an issue with mainboard.
              • wreksta
                • Aug 2013
                • 508
                • england
                which connectors mate thanks
                • zomi
                  • Nov 2011
                  • 509
                  where the 2 strips connect together hard wire those.
                  and also maybe the whole wiring harness
                  its either an issue with the wiring
                  or a failing led that is not showing up with the led tester as its not supply enough current.
                    Can you verify the model number of the TV?
                    • wreksta
                      • Aug 2013
                      • 508
                      • england
                      yes it's LG 55la620v
                      • wreksta
                        • Aug 2013
                        • 508
                        • england
                        bottom 3 rows flash top 4 don't
                        I've checked all condunity for all connectors and test good
                        could it still be faulty?
                        • zomi
                          • Nov 2011
                          • 509
                          check resistance between all points.
                          look for any with high resistance
                          and u have tested all leds and they have tested good ? thats correct yeh ?
                          • triplefour
                            TCL 75S421 has sound but no backlight not even a flash
                            by triplefour
                            TCL 75S421
                            PSU BOARD: 40-L402H8-PWD1CG
                            it shows not even a flash of backlight when powering up.
                            but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
                            testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
                            unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
                            i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
                            with mb connected, PSON...
                            11-17-2023, 09:54 PM
                          • hollox123
                            ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                            by hollox123
                            Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                            1. Laptop keyboard doesn't work
                            2. The backlight on the laptop keyboard doesn't work
                            3. The x2 side LEDs (red) on the laptop don't work
                            The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                            I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                            But I am strongly aiming that it is somehow a BIOS-related problem,...
                            05-11-2025, 08:05 AM
                          • ekozeko333
                            by ekozeko333
                            🧠 What I’ve Done So Far
                            Flashed...
                            06-21-2025, 02:48 AM
                          • signal.quest
                            Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                            by signal.quest
                            I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                            03-17-2024, 10:14 AM
                          • corrize
                            Nikon D800 camera - flash don’t work and capacitor don’t charge
                            by corrize
                            Hello, I'm stuck in troubleshooting…
                            The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                            In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                            When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                            10-01-2022, 10:02 AM
