LG 43UJ670v blue patches on screen
  • sordids999
    • May 2013
    • 2161
    • uk
    Hi guys
    Any ideas what's causing the dark patches on the screen
  • nomoresonys
    • 12332
    • U.S.
    Re: LG 43UJ670v blue patches on screen
    Looks like the dreaded worn out leds that turn blue.
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • jean luc ferre
      acer aspire v5 571p touching screen cracked led blue of power indicator blinks 1s lighted 3s off.
      by jean luc ferre
      on this laptop acer aspire v571p the led of the power indicator blinks blue for periods of 1s lighted and 3s off after switch on and this indefinitely.
      i tried the hard reset, cmos reset, changing the ram without results.
      in order to reach the cmos battery i disassembled the laptop and did several mesures with my multimeter.
      The 19v, 5v, 3v are well established after the chip 5v-3v. the following signals : 3d3v_aux_kbc (which supplies the sio chip) and 3d3_s5 are well established also.
      but the signals: 3dv3_s0, pw_slp_s3# and pw_slp_s4 oscillate at the same...
      11-22-2025, 03:54 PM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • ulthi
      Samsung QE50Q60TAU - Flashes black/blue screen
      by ulthi
      My tv is not able to turn on. I flashes between black and vague blue screen (see video)
      I have tried different resets and have also replaced the main board - but nothin has changed.
      Any suggestions?
      https://youtu.be/acYQ-ImmhWA
      10-14-2025, 01:48 PM
    • gbbradshaw
      Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
      by gbbradshaw
      Hi.
      I have the Samsung TV Model: UE65TU7000KXXU VER:02/UTU7000 which has developed the following issue: blue screen while the sound it's still working. This happened after the screen developed some horizontal lines at first and then the next day suddenly turned into blue background. the screen was not damaged or anything. I can't access the menu. I have taken the tv to a local tech to have a look and he said that he thinks that it might be the pcb board as the back-lights are working and the sound aswell . I was hoping maybe you can guide me if I should buy the pcb board or not? Thanks
      02-22-2023, 01:31 AM
