UN49KU7000, has sound but no picture
  • hamlin86
    • Jan 2019
    • 12
    Re: UN49KU7000, has sound but no picture
    Originally posted by budm
    You need to test with LED (Load) in place, exposed pins on top side of the board are ODD number pins, not even number pins.
    2 and 4 read 362. As I held the multimeter on 10 and 12 together the left side of thebacklight stays on but once I remove the multimeter it goes off again.
    • hamlin86
      • Jan 2019
      • 12
      Well now the sound doesn't work. I can see the picture with the flashlight but now there is no backlights and no sound. I am feeling defeat here..
      • sordids999
        • May 2013
        • 2161
        Just a update for anyone having issues with no backlight and led voltages are reading 365v dc samsung ue49ku6470 same backlight as the model number in this post and when I stripped the screen the left side strip totally burnt out possibly water corrosion
        • hemant_2222
          Yamaha 2064 No sound but Test audio working
          by hemant_2222
          Hello Guys,
          Greetings!
          Hope you all are doing well.
          I am looking for suggestion on Yamaha 2064. The problem with this receiver is that it has no sound however when the test tones are activated it does outputs from all the speakers. It is working in two channel stereo mode but when you select other sound modes, it doesn't. The last time it had a problem, I had replaced the DAC
          PCM1681DBQR - IC263 and it worked fine.
          Other issue with it is one of the STK ICs is getting more heated then the other one but that can be looked at later.
          11-01-2025, 11:20 PM
        • Mgiffune
          by Mgiffune
          06-09-2024, 10:28 AM
        • Ierwin
          by Ierwin
          05-13-2025, 03:31 PM
        • jchang
          Samsung UN70NU6900F no picture and no sound
          by jchang
          Hi all
          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
          Symptom:
          No picture no sound.
          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
          No sound at all.
          What I tried:
          1. I tried unplugging the left or right ribbon...
          01-09-2023, 06:28 PM
        • ChaosLegionnaire
          by ChaosLegionnaire
          09-13-2022, 09:02 AM
