Samsung LA32B650 standby led flashes after TV on.
  • saddle_au
    Waste Warrior
    • 121
    I have a small Samsung LA32B650 that operates perfectly, but the standby led just keeps flashing it's startup on/off sequence. Nothing else seems wrong with the TV at all. Image is good, back lights are stable, both the free to air and HDMI inputs work fine, touch panel on the bezel works good.
    In an attempt to clear it, I put the TV through a factory reset from the service menu, and that did not clear it either.
    Other than this flashing standby led, it's good to go. The are no menu options for the control of the standby led that I can see in the normal menu system for it.
    Do you have any ideas?
    • 12330
    • U.S.
    Re: Samsung LA32B650 standby led flashes after TV on.
    Observe the flashing closely, are there any pauses, example does it blink 6 times then pause a bit then six more blinks and repeat?
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Samsung TVs do not have SOS signals and so the blinking light could very well be a loose/cold solder somewhere in the Standby light circuitry. For now if everything else picture quality, color, remote functions, audio, etc are working. Which means all operating voltages are present. Don't go poking around, just cover the Standby light with a piece of tape and block it out if it is absolutely annoying.
      • R_J
        • 9623
        Have you checked the software version? current seems to be Ver. 2001.1 It could be that it is not detecting that the backlight did turn on. Is this your own tv? or did you get it this way... maybe it had an issue with the backlights and its been bypassed to stay on.
        • saddle_au
          Waste Warrior
          • 121
          Thankyou for the responses.
          The TV was given to me to look at for a women in a retirement home. The aerial connection was broken which didn't take much to do.
          She has another no-name rebrand TV at the moment, but it doesn't pickup all of the new free to air channels properly and the son gave me this one to see if it could go. Funny, it's not a case of him being cheap, the room for the TV is limited and it's hard to get a small "branded" TV with good sound here anymore. Easy to get a 50 inch though.
          The Sammy 32 inch screen was good (after a clean) and it looked like it hadn't been opened. I said sure, since the B650s were always a reliable unit (still think the image looks better than most new units) and the sound is good (also important).
          Thanks for the backlight suggestion, I will check out the inverter connections and the protection circuits. It cannot be a bad solder joint causing the flashing, the standby is solid while off and the flash rate is exactly the same as the normal turn on sequence, it just doesn't stop.
          The current no-brand TV is a Changhong 32 inch which doesn't pickup all of the stations all of the time. The unit has a hassle with two channels where it cannot decide which format the data is coming down. When it's in quality display mode, those channels sit around 84% signal (same as all of the other channels) with nothing on the quality bar and you can see it flipping between two formats trying each over and over without locking onto one. After a while, it gives up. I've looked for firmware fixes, but that brand has a firmware page with "coming soon" on it for the year or more. 84% signal should be enough to lock on to. Sonys and Sammys lock in on at 35%-40% around here.
          • R_J
            • 9623
            Some tv's pick up dtv channels better than others, also do you know how far the transmitter is from the tv's location? The two channels could also be brodcasting at a lower power or have a different transmitting pattern. Channel percentage is just a number, where one tv will work at 50% another likely won't.
              • 12330
              • U.S.
              Try
              Plug & Play
              to add available channels to the channel list. Go to
              MENU
              Setup
              Plug & Play
              and wait for all available channels are stored.
              Verify Antenna is positioned correctly.
                • 12330
                • U.S.
                https://www.samsung.com/au/support/m...A32B650T1FXXY/
                  • 12330
                  • U.S.
                  Didn't see anything about blinking light, could try email or call m and ask why it's blinking.
                  • saddle_au
                    Waste Warrior
                    • 121
                    Issue was related to TCON. Replacement TCON works fine but original one runs (works) but continues to blink. Obtained a T370HW02 TCON spare (by accident), swapped in and TV is now ok. There are two sizes of that TCON, one that is about 6 inches by 5 and the other 2.5 by 5 inches. Both have the same model number on them. Suspect bad eeprom on first TCON because mainboard is confused about what is read back.
                    I have found since then by playing around with various panels (frames) and mainboard combinations that the B650 mainboard will also run on a B550 panel (and visa-versa) as it has the same power supply and TCON connections, but will keep flashing the red led because it's a completely different TCON board. Image on the 550 panel with a 650 main is good, just the cpu is unhappy. Method of driving the signals must be exactly the same. The 550 panels are Samsung manufacture and the 650 panels are AUO. There is a method of telling the B650 main board it's on a different panel via the service setup but seems to be no option in there to choose a 550 panel by panel name or stamp code.
                      09-07-2024, 05:50 AM
                    • Bloopeta
                      Samsung UE43KU6400U Flashing Red Standby Light
                      by Bloopeta
                      Have a Samsung UE43KU6400U that will not turn on, just continuous flashing red standby light.
                      Power button does nothing
                      Have unplugged the mainboard, and backlights illuminate.
                      Have tried removing panel ribbon cables one at a time, and that makes no change.
                      With mainboard unplugged, all voltages from powerboard seem ok, but with mainboard connected, they never quite reach full voltage, and drop and raise in a constant loop (in time with click noise from mainboard.
                      Using backlight tester, I get 63.6v on both sides, so seems like no bulbs...
                      09-11-2023, 02:34 AM
                    • Robby-Gr
                      TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
                      by Robby-Gr
                      I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
                      However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
                      The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
                      Additional issues:...
                      09-27-2025, 12:02 AM
                    • tvguy12012012120
                      by tvguy12012012120
                      02-07-2025, 05:13 PM
                    • fuxxy
                      Samsung UN55D6000FXZA - Won't stay on, standby light flashing rapidly
                      by fuxxy
                      This is a set I posted about a few years ago. Replaced LED strips and worked fine until now.
                      Plug the set in, and it will turn on and functions with no issues.
                      After a while, (sometimes hours, sometimes minutes, sometimes immediately) the tv shuts off. When I approach the TV I notice the standby light is flashing rapidly, but the pulse of each flash is not long enough to notice from afar.
                      Other than the standby light, the unit is completely unresponsive until the power is removed and reapplied, then the cycle starts over. It does appear that the time it takes...
                      08-02-2022, 09:44 AM
